Test/review of Fonken 5 port USB charger QC3 5U01Q3
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 32 min 15 sec ago
DSC_6674
Official specifications:
  • Type: Phone charger
  • Brand: FONKEN
  • Material: Aluminum and ABS Plastic
  • Item color: Black/White
  • Standard: Quick Charge 3.0
  • Input: AC 100~240V 50/60Hz
  • Output: 1~4Port:DC 5V/2.4A, 6.4A total Max.
  • 5Port: DC 5V/2.4A 9V/1.2A 12V 1.5A
  • Quality Certification: CE/FCC/ROHS
  • Size: 91*58*26mm
  • Net Weight: 142g
It is from Aliexpress dealer: FONKEN Store
DSC_6494
I got it in a card board box.
DSC_6673
The box contained the charger and a mains cable, no manual or instruction sheet.
DSC_6675DSC_6678
DSC_6676
DSC_6677
DSC_6679DSC_6680
Measurements
  • QC output is Auto coding with DCP, Samsung, Apple 2.4A, Huawei-FCP, Samsung-AFC in addition to QC3
  • Other usb outputs are Auto coding with DCP, Samsung, Apple 2.4A
  • Power consumption when idle is 0.25 watt
  • All normal usb outputs are in parallel.
  • All usb output shares minus.
  • Minimum QC3 output is 3.8V
  • Weight: 144g without accessories.
  • Size: 90.4 × 58 × 27.1mm
Fonken%205%20port%20USB%20charger%20QC3%20%231%20230V%20load%20sweep
This usb port can deliver more than 4A
Fonken%205%20port%20USB%20charger%20QC3%20%234%20230V%20load%20sweep
Same with this port.
Fonken%205%20port%20USB%20charger%20QC3%20QC5V%20230V%20load%20sweep
The QC port is limited to about 3.6A at 5V
Fonken%205%20port%20USB%20charger%20QC3%20QC9V%20230V%20load%20sweep
And also at 9V
Fonken%205%20port%20USB%20charger%20QC3%20QC12V%20230V%20load%20sweep
And 12V
Fonken%205%20port%20USB%20charger%20QC3%20230V%20load%20sweep
The charger can deliver about 1.2A on QC and 8A on the normal usb before it starts to shut down.
Fonken%205%20port%20USB%20charger%20QC3%20120V%20load%20sweep
It is the same at 120VAC
Fonken%205%20port%20USB%20charger%20QC3%201.5%2B8A%20230V%20load%20test
It was a bit optimistic to try 8A load test. The QC dropped to 5V after a short time.
Fonken%205%20port%20USB%20charger%20QC3%201.5%2B7A%20230V%20load%20test
Testing for one hour with: 7.2A at 5V and 1.5A at 12V worked much better.
The temperature photos below are taken between 30 minutes and 60 minutes into the one hour test.
Temp5151
M1: 66.4°C, M2: 59.2°C, HS1: 71.6°C
HS1 is the heatsink for the two rectifier transistors, M1 is the transformer and M2 is the mains switcher transistor.
Temp5152
M1: 52.1°C, M2: 40.2°C, HS1: 53.3°C
HS1 is from the QC switcher, M1 is the mains capacitor transfering heat.
Temp5153
M1: 66.7°C, HS1: 67.5°C
M1 must be the snubber network and HS1 is from the two rectifying transistors.
Temp5154
HS1: 63.1°C
Again the rectifying transistors.
Temp5155
M1: 57.7°C, HS1: 67.4°C
10ohm
At 0.5A output the noise is 8mV rms and 160mVpp.
5ohm
At 1A the noise is 36mV rms and 180mVpp.
2ohm
At 2.5A the noise is 20mV rms and 282mVpp.
1ohm
At 5A the noise is 26mV rms and 366mVpp.
10ohmQC
On QuickCharger at 0.5A the noise is 5mV rms and 105mVpp.
10ohmQC12V
At 12V 1.2A the noise is 7mV rms and 111mVpp.
Tear down
DSC_6849
A bit pressure with my vice and I could break the front off with a screwdriver.
DSC_6850
At the mains input there is a fuse (F1: 3.15A) , inrush current limiter (RT1: NTC), two common mode coils (LF1 & LF2), a bridge rectifier (BD1) (Some of it hidden under the heatsink). On the heatsink it the mains switcher transistor. Beside the transformer is the blue safety capacitor. The big smooting capacitor is glued to the circuit board to prevent it move to touch the QC inductor (L1).
On the low volt side is two synchronous rectifier transistors (Q3 & Q4). Between the usb connectors are the auto coding chips (U6 & U8: D1524).
The QC uses the inductor to reduce the 15.2V, and there is q QC and more controller near the usb connector (U7: Fitipower FP6600Q).
DSC_6852
On this side there is space for an extra safety capacitor.
DSC_6853 DSC_6855
DSC_6854
DSC_6851
On this side is the main switcher controller (IC1), the opto feedback (U9: EL357N) with a reference close by (U3: 431). Not surprisingly there is a synchronous rectifier controller (U4: SP6016E) and it looks like this chip controls both rectifier transistors. The next chip is a buck converter (U5: HX1314G) for the QC voltage.
DSC_6856
DSC_6857
The isolation distance looks fine.
Testing with 2830 volt and 4242 volt between mains and low volt side, did not show any safety problems.
Conclusion
Four normal usb outputs that can deliver more than 7A with auto coding and a QC and more output, low noise. No safety problems with mains, but I could have wished for individual port protection.
I will call it a good charger.
Notes
Index of all tested USB power supplies/chargers
Read more about how I test USB power supplies/charger
How does a usb charger work?
Edited by: HKJ on 04/13/2018 - 12:37
travis
Last seen: 2 days 53 min ago
Found it on Aliexpress. (Model # starts with “5”, Not “s”)
But I cannot see anywhere to ask the seller if t is available with the US mains plug ?
https://www.aliexpress.com/item/Fonken-USB-Charger-Quick-Charge-3-0-Cert...
A well regulated Militia, being necessary to the security of a free State, the
right of the people to keep and bear Arms, shall not be infringed.
travis
Ok—found the little orange button for “Contact seller” on the left hand side
HKJ
HKJ's picture
I have fixed the title.
It is not that important, the mains cable is a standard cable, you may already have a couple at home.
