Test/review of Internal Resistance Tester YR1035
15 posts / 0 new
HKJ
HKJ's picture
Last seen: 55 min 57 sec ago
DSC_7156
This is a meter designed to measure internal resistance in batteries.
DSC_7146
I got the meter in a random shipping cardboard box, it contained:
The meter, 4 terminal probes with extra pogo pins, 4 terminal clamps, 4 terminal battery holder and a manual in Chinese (It is possible to order with the accessories that you want).
DSC_7155
The meter has a recharge battery inside and is charged from a micro usb connector.
DSC_7160
It uses a round metal connector for the four terminal connection. The connector is locking, i.e. the plug cannot fall out. Pulling the ring on the plug will unlock it can be pulled out.
DSC_7161
DSC_7162DSC_7163
DSC_7410
The meter has Chinese text in the display and it is not possible to select English.
DSC_7409
For just using it as a milli-Ohm meter it is not really an issue.
DSC_7398
When not used for some time, it will go into standby mode, this requires a button pres to leave.
DSC_7414
There is a couple of buttons:
Power is used to turn on/off the device.
Hold/Zero is used to freeze the ohm reading, I did not have much luck with the zero function.
Range R is used for manual range select on ohms (20m, 200m, 2, 20, 200, auto).
Range U is used for manual range select for volts (1V, 10V, 100V, auto).
DSC_7148
Four terminal probes made with pogo pings in aluminium tubes and some shrink wrap.
The wires are soft silicone.
DSC_7150
A closer look at the business end.
DSC_7147
If a pogo pin is damaged, it can be pulled out and a new one pushed in, the pack included four spares.
DSC_7149
The plug looks like a fairly good quality.
DSC_7151
The clamps are a cheap Chinese four terminal model.
DSC_7152
The battery holder is a fairly standard four terminal holder (I use same type for my battery test). It is not the fastest way to connect a battery, but gives stable connections.
Measurements
  • The ohm meter is 2200 count display
  • The voltmeter is a 100000 count display.
  • The AC used to measure ohms are 1kHz at up to about 100mV rms, it will vary with range and measured resistance.
  • Output voltage when open is about 2.5Vrms.
  • Power consumption while off: 5.1uA
  • Power consumption while on with light: 65mA
  • Power consumption while on with light and shorted probes: 140mA
  • Power consumption in standby mode: 15mA
ohm
Due to the way the meter works it do not need a battery to measure resistance, but can be used as a general milliohm meter.
Here I am testing on some resistors and comparing to a very precise meter.
The precision is very good.
volt
The same with voltage, again the precision is very good and it has lots of digits.
10ohm
The meter is using a 1000Hz sinus for measuring the resistance
21.9ohm
The maximum AC voltage is about 30mVpp when measuring 22 ohm.
220ohm
The maximum AC voltage is about 300mVpp when measuring 220 ohm.
unloaded
With unloaded outputs the voltage will be considerable higher at about 5.3Vpp
Tear down
DSC_7415
I had to remove four screws to open the box.
DSC_7416
it is a standard project box with some machining and a custom frontplate.
DSC_7417
The circuit is on two circuit boards, one for the display and one for everything else. The used battery is a LiIon 18350 cell marked with 900mAh.
DSC_7418
Four more screws and I could remove the circuit board.
DSC_7425
Markings has been carefully removed from nearly all the chips.
DSC_7419
DSC_7420 DSC_7422
DSC_7421
DSC_7423
DSC_7424
DSC_7426 DSC_7427
Before removing the display board I unsoldered the battery (Only one connection).
DSC_7428
There are two mechanical relays and space for a usb interface chip (U7). There is 5 trimpots to calibrate it with.
DSC_7429
Conclusion
This milli-ohm meter is very good and can both be used to measure internal resistance in batteries and to measure small resistors with. Because it uses AC it will give too high reading on anything inductive, but measuring resistors and small metal pieces works fine.
When using it as a milli-ohm meter the Chinese text is not a big problem, but it is a bit tricky to change any options or use the more advanced functions.
Notes
As reference I used my Keithley DMM7510, it can do 4 terminal ohm measurement.
Vapcell Internal Resistance Tester YR1030
Internal impedance/resistance of batteries
HKJ
HKJ's picture
kiriakos wrote:
For 15$ retail price with out any accuracy specification’s I think of it as toy full of trim-pots.
That is silly, at $15 it is a steal, but I doubt you can get a new one for that.
HKJ
HKJ's picture
kiriakos wrote:
You seem unfamiliar with Chinese pricing policies.
Actually you may get it for 12$ USD
https://www.ittsb.eu/forum/index.php?topic=966.msg3466;topicseen#msg3466
YR1030 and YR1035 is not the same meter and you did not provide a link to your price, only to a silly guy listing specifications.
HKJ
HKJ's picture
kiriakos wrote:
Now delete your lies about 100000 digits volt measurement.
The YR103*5* uses 100000 volt display, I would not expect the precision to be that good.
If you look in the review you will see a photo of the display showing all the digits.
HKJ
HKJ's picture
kiriakos wrote:
I can not see something that is not there, take a picture at 1V DC operation.
Why, there is a picture showing the number of digits and a table showing how precise it is.
Anyway asking about 1V would not show the full 5 digit resolution.
wolfdog1226
wolfdog1226's picture
Last seen: 1 day 15 hours ago
Thanks for the review!
I think kiriakos must be related to Gauss!!! Facepalm
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Venom
Venom's picture
Last seen: 18 hours 28 min ago
Is this tester the same as the Vapecell YR1030?
HKJ
HKJ's picture
No, it is an upgraded version of it.
Venom
Venom's picture
Thanks for the reply!
s5610
Last seen: 1 day 7 hours ago
But it is, actually. I ordered YR1035 yesterday for $40, will leave a link on Ali seller if the item will be all good.
That kiriakos is crazy, he copied all eevblog forum and made himself admin there. That’s shocking… )
HKJ
HKJ's picture
If you look at my table you will see it is not (I used a meter that is way better than Fluke 287 for comparison).
It is easy to make a fairly precise meter today, but maintaining precision over temperature changes, time, etc. is much harder.
s5610
I agree.
Unfortunately I don’t have access to serious metrology equipment, but I got these readings with AD584LH (+-5mV 10V) on my YR1035 item:
10,004 V
7,4995 V
5,0020 V
2,4966 V
Sure higher priced meters tend to have lower drift, but any precise equipment needs to be calibrated time to time )
HKJ
HKJ's picture
Calibration is verification, it do not include any adjustment, this is, of course, required if you need to know that your meter stays precise.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 7 min ago
Does this device measure the impedance or the resistance of a battery? I'm just wondering as the 1kHz AC method is called "impedance" and this device seems to measure the same way the SM8124A (impedance meter) does.
HKJ
HKJ's picture
Lux-Perpetua wrote:
Does this device measure the impedance or the resistance of a battery? I’m just wondering as the 1kHz AC method is called “impedance” and this device seems to measure the same way the SM8124A (impedance meter) does.
It is the impedance.
