Review - Lumintop ODF30 XHP70.2 3500lm 19600cd 280m - by Lock
44 posts / 0 new
lock
lock's picture
Last seen: 17 hours 35 min ago
Hi guys…in this review i will speak of the Lumintop ODF30, a flashlight that utilizes a high power Cree XHP70.2 LED, and runes on one high capacity 26650 Li-ion battery. It emits a max output up to 3500 lumens and a max burn time of 250 hours.
Here the company’s website and here product’s link.
Package
Strong and degradable box package that includes: • ODF30 Flashlight • Holster • User Manual • Warranty Card • 2xSpare O-ring • Laynard The battery is not included
A quality Nylon holster for a perfect protection of the flashlight
High Visability Orange Laynard
Features
  • Utilizes Cree XHP 70.2 LED with a lifespan of 50,000 hours
  • Powered by one rechargeable and economical 26650 Li-ion battery
  • 5 output levels plus Strobe with a max 3500 lumens output and a 280 meters throw distance
  • High efficiency circuit with a max runtime up to 250 hours
  • Solid and compact (length:120mm, N.W.: 133g), easy to carry with the additional holster
  • Aluminum alloy orange peel reflector and floodlight design creates a wide and balance flood beam
  • Stainless steel ring on the head protects the key elements from eternal force
  • One side switch control, fast and convenience
  • Toughened ultra-clear glass lens with anti-reflective coating, max 99% light transition
  • Lock-out function prevents accidental activation
  • Enhance cooling fins ensure a comfortable holding
  • Low voltage indicator reminds to change or charge the battery in time
  • Flat tail cap with tail standing ability to serve as a candle
  • Made of aerospace-grade aluminum alloy, premium Type III hard-anodized anti-abrasive finish on the surface
  • Waterproof to IPX-8 (2 meters underwater), impact resistance to 1.5 meters
  • 5 years free repair, limited lifetime warranty
Specifications
  • Emitter: Cree XHP70.2
  • Max Output: 3500 Lumens
  • Max Beam Distance: 280 m
  • Beam Intensity: 19600cd
  • Max Runtime: 250 h
  • Battery: 1x26650
  • Working Voltage: 3.7 v
  • Modes: 5 Normal + 1 Special (Strobo)
  • Waterproof: IPX8 (2 m)
  • Impact Resistance: 1,5m
Dimension e Weight
  • Height: 120 mm
  • Head Diameter: 42 mm
  • Body Diameter: 32 mm
  • Weight: 133 g (without battery) e ~215g (with battery)
Output Level & Runtime
Turbo Level: 3500 lm (misured 3546 lm) – 3min + 2h15min
High Level: 1800 lm (misured 1670 lm) – 2h15min
Med Level: 540 lm (misured 536 lm) – 5h45min
Low Level: 150 lm (misured 145 lm) – 21h
Eco Level: 8 lm (misured 10 lm) – 250h
Turbo Level– Powered with Keeppower 26650 5200mAh – Home Enviroment 22°C - Uncooling
High Level– Powered with Keeppower 26650 5200mAh – Home Enviroment 22°C - Uncooling
Body and materials
The Lumintop ODF30 is a compact and lightweight flashlight. Inside it hides a 26650 battery and the big and voracious XHP70.2. The thermal regulation system prevents the torch from reaching too high temperatures. If the heat exceeds 55 ° C, the output will be reduced automatically. The torch is well finished and treated in detail, the materials are of quality and the thicknesses are adequate. In the hand gives a good feeling of robustness and excellent workmanship.
The head has two series of dissipation fins that allow to dissipate the heat produced by XHP70.2 very well.
The Bezel in stainless steel and protects the lens. The lens has anti-reflective treatment, it seems to have a thick thickness and looks good. Lumintop declares a transparency of 99%.
The orange peel reflector provides the torch with diffusion characteristics.
The side switch allows you to control the entire interface thanks to the intelligent UI of the flashlight. It is made of rubber, surrounded by a steel bezel ring, quite protruding, very precise, offers excellent tactile feedback and at the pressure it emits a loud click. Under the power button there is also a led indicator that activates if the cell voltage falls below the 3V threshold.
The central body has a polygonal working with protruding parts that allow to have an excellent grip in any situation. The anodization is well done, perfect on the whole torch, it also helps in the grip.
The threads are anodized so I allow the physical lock out with the classic ¼ turn of the tailcap. They come well lubricated, they are very precise and flowing.
The Tailcap is flat and allows the use of the flashlight in the tailstand. Also this presents a polygonal processing that helps in the grip. Also there is a small ring for inserting the laynard.
At the negative pole we have a special gold-plated tongue that simulates a spring, while at the positive pole we have a golden, sturdy and resistant spring (this allows the use of flat and button cells).
The lettering is really minimal but still well done. We find it only in the head with the company logo (a bunny), the word "Lumintop" and the model of the torch "ODF30".
The company declares the impermeability to 2m depth and a resistance to impact from falls of 1.5m.
In your hand the torch is very comfortable, you hold it well, the button is easily tracked even in full darkness and using gloves.
Other shots….
User Interface
General mode: Low-Med-High (with memory);
Hidden mode: Turbo, Eco and Strobe.
  • ON/OFF: Single press for on, press and hold for 2 seconds to turn off.
  • Output selections: With the light on, click to cycle through Low-Med-High.
  • Turbo: With the light on, quick double clicks to enter Turbo, another click will return to previous general mode.
  • Eco: When the light is off, press and hold the switch for 2 seconds to enter, another press will cycle through Low-Med-High.
  • Strobe: Under Eco mode, double quick click the switch to enter, another click to exit.
  • Lock-out function: When the light is off, press and hold the switch for 4 seconds till flash to enter, loosen the tail cap to unlock if needed. Under lock-out statues, the light can only lighten up on Low until released when press or click the switch.
Beam, Tint e Beamshots
The ODF30 beam is well studied and gives the torch diffusion characteristics. Nevertheless it tends not to disperse in the darkness and to remain focused enough.
The shot is good, with its 3500lumen the ODF30 manages to illuminate even over 100 meters away). Lumintop declares 19600cd and 280mt of maximum shooting. The beam is uniform, does not have particular color changes or artifacts. The tint despite being a Cool White (at eye about 6500K) does not mind. Obviously, for personal tastes, it was neutral I would have preferred.
Below you will see some beamshot on the average / long distance. The Eco level has not been taken into consideration given the very low brightness. The distances, for greater accuracy, were calculated using a telemeter.
Beamshot #1
Measurement of the distance
Low Level
Med Level
High Level
Turbo Level
Beamshot #2
Low Level
Med Level
High Level
Turbo Level
Beamshot #3
Low Level
Med Level
High Level
Turbo Level
Beamshot #4
Low Level
Med Level
High Level
Turbo Level
Dimensional comparison with other flashlights in my possession and with other objects
Conclusion
This Lumintop is one of the smallest, most compact and powerful EDCs with 26650 power I've ever handled. There are many aspects that struck me, first of all the power output (the 3500 lm, although inevitably will tend to decline rapidly over time). Secondly, I was struck by the excellent regulation, as can be seen from the previously reported runtime curves.
The presence of an Eco level of 8 lumens, although not a real firefly level, is always convenient and in this case thanks to the 26650 battery power allows to reach over 250h of runtime.
Perhaps a bit inconvenient access to the Strobo that provides the transition from the Eco level, as well as access to the Turbo only by flashlight on. I would have preferred direct access to these functions, perhaps with the classic double click for the Turbo and triple click for the Strobo, but these are just details and personal tastes.
I like the beam geometry and I think it particularly usable for different types of scenarios.
The tint is a Cool, to eye on 6500K and it do not mind. Personally I feel very satisfied with this new Lumintop.
For me Torch promoted!
What do you think about it?
Ps: sorry for my english, i hope i did not make mistakes
Edited by: lock on 04/16/2018 - 19:09
toddcshoe
toddcshoe's picture
Last seen: 19 min 49 sec ago
I was on the fence with this light. After this review I think I am just going to pull the trigger. Nicely done review. Thank you very much.
Aviationtech
Aviationtech's picture
Last seen: 40 min 11 sec ago
I’m close to pulling the trigger, I would just like to know the battery sizes it will accept. I’d like to use the Shockli 5500mah which is a bit wider than most. Is it possible to get an exact inside diameter measurement?
Satan@103TFS
Last seen: 52 min 25 sec ago
Nice review & pictures .
CM2010
Last seen: 3 hours 33 min ago
Great review and photos, mine is in the mail as we speak. Looking to run keeppower 6000 26650’s in it.
blueb8llz
Last seen: 2 min 46 sec ago
Outstanding review. Fantastic pictures! Thank you.
lock
lock's picture
Thank you all friends!
Aviationtech wrote:
I'm close to pulling the trigger, I would just like to know the battery sizes it will accept. I'd like to use the Shockli 5500mah which is a bit wider than most. Is it possible to get an exact inside diameter measurement?
Inside diameter is 26.6-26,7 mm
SKV89
Last seen: 15 min 21 sec ago
I really like your review! Great photos and helpful charts. I wonder how this compare with the TC20.
djozz
djozz's picture
Last seen: 9 min 44 sec ago
Very nice review with losts of great pics in nice surroundings, makes me want to go on holidays, with the ODF30! Thanks for taking all the trouble making the review. And welcome to BLF Smile
LTVictor
Last seen: 6 months 2 days ago
Awesome, thanks for the great review with beautiful pictures, it reminds me to go outdoor right for the time, good job! Thumbs Up
charles lin
charles lin's picture
Last seen: 3 days 6 hours ago
Nice review & great pics. I would appreciate if you could do compare beamshots between Rofis MR70 & ODF30. It is very hard to see actually Tint, brightness & a beam pattern without the comparison beamshot.
lock
lock's picture
hi...you can see my review on CPF Italia of the Rofis MR70 Here . You can compare "Beamshots del Main LED (Low-Mid-High-Turbo)" of MR70 with "Beamshot #1" of the Lumintop ODF30.
firedome
Last seen: 2 weeks 5 days ago
Great review & pictures. Thanks Big Smile
“We can easily forgive a child who is afraid of the dark; the real tragedy of life is when men are afraid of the light.
-Plato
my9221
Last seen: 2 min 19 sec ago
Thanks for the lengthy reviews and pics!
ChibiM
ChibiM's picture
Last seen: 50 min 13 sec ago
In my review I found that the parasitic drain was 0.05Amps. Could you check that? I just unscrewed the tailcap to meaure when turned off and measured between 0.02A and 0.05A.
 Edit: I guess it's my reading... I just can't understand how to read my DMM.. It just says 0.05
lock
lock's picture
ok i checked...the parasitic drain in my ODF30 is 51uA (0,051mA or 0,000051A) .
With a 26650 5200mAh battery the teorical runtime is 101960h  (4248 days or 11 years) XD
ChibiM
ChibiM's picture
lock wrote:
ok i checked...the parasitic drain in my ODF30 is 52uA (0,052mA or 0,000052A) .
With a battery 26650 5200mAh the teorical runtime is 100000h  (4166 days or 11 years) XD
Hmm. Maybe i jist didnt read it good enough. Are you sure it's not 0.05A? Smile
lock
lock's picture
XD...yes i'm sure...In the photo you can see the used scale in the multimeter (uA) and the measured value 51,2uA  Smile
ChibiM
ChibiM's picture
Yep, seen it.. Need to double check it on mine...
KevinZA1988
KevinZA1988's picture
Last seen: 2 days 6 hours ago
Hi there, great review! I am keen on getting either the Rofis MR70 or the Lumintop ODF30. Wich one do you prefer, and why?
I am leaning towards the Rofis MR70 due to the USB port and the included battery. But it is more expensive.
Acebeam L16, BLF Q8 (modded), BLF A6 (modded), Convoy L2 (modded), Convoy S3 (custom), Emisar D4, Skilhunt S3 Pro, Jaxman E2L (custom), Rofis MR70, Olight S1R Baton II Etarnal + Spring + Autumn + Summer + Winter, Olight S2R Baton II, Nitecore HC65.
the4ds9
Last seen: 3 days 1 hour ago
I had an extremely negative experience with the Imalent DX80 so I avoid all Imalent and anything resembling Imalent. Rofis MR70 reminds me of Imalent. I would choose Lumintop ODF30!
komeko
komeko's picture
Last seen: 55 min 23 sec ago
I will ask, out of curiosity, what is wrong with the imalent? I’ve never had any lamps from this producer, that’s why I’m even more interested.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Q8, D4, D4S, PL47, GTmini, SDmini, Mini AAA, TIP CRI, M43, H1, H03, TC20, TN40S, TN42, V6, UT01, UV
the4ds9
The minor thing was that the supplied charger will fail. Every one of them whether black tip or yellow tip. You will need to purchase a laptop charger from eBay or Amazon to replace it. The major thing was that my DX80, after a couple of uses, and me treating it well as a shelf queen (no abuse; not even drop or bump against any object; even the lens was smudge-free) it ceased to turn on. The battery pack was fully charged because I swapped it out with another DX80 (I used to be a big Imalent fan; even to the point of going on YouTube and liking every Imalent review video) and it was not the battery pack nor connection. It was obviously the electronics in the head. This is not anything I could do to fix it. I venture that even a seasoned modder would have a time figuring out after getting the head open due to the electronics.
Long story short: I got an RMA from Shellen at Imalent and carefully boxed it up and shipped it with a local Chinese courier (located on Valley Blvd. and Del Mar Ave. in San Gabriel Valley, California), that my wife and I have used multiple times without fail (I am Chinese myself). Imalent claims to NEVER have received my RMA package.
$300 lost. Imalent? No more Imalent for me. Anything resembling an Imalent (electronic click instead of a depressed button) is out for me too. I lost well over $300 for nothing. “Thanks” to Imalent.
komeko
komeko's picture
After such experiences, I am not surprised. I would be very disappointed myself. On the basis of various opinions, I have removed a few companies from the shopping list. Such a forum is a treasure.
mortuus
mortuus's picture
Last seen: 37 min 9 sec ago
wow excellent review! must be the best one i seen in a long time here and very nice photos also wow!
...where Frugal meets with Flashlight!
Azza
Last seen: 2 months 4 weeks ago
Wow! A really useful & detailed review with lots of useful information & visuals. Hope you get the opportunity to review other upcoming flashlights too.
I have the Rofis MR70 since a month. Very happy with it. I use it while biking at night. The UI is great. I use the triple-click strobe occasionally for a couple of seconds too. So much brighter than a car headlight even!
The Lumintop ODF30 is similar. The cheaper cousin. It is priced well if compared to its more premium & feature rich cousin.
I note that the thermal/timed output runtimes of both are quite similar at Turbo & High.
flashiman
I love this picture heavy review. Actually, flashlight review should be picture base. The picture with test images gives the clear idea about that flashlight. Lumintop has produced some quality tactical flashlights http://totalguide.org/best-tactical-flashlight. The 3500 lumens means higher brightness. I am thinking to get this one.
JasonWW
JasonWW's picture
Last seen: 1 hour 2 min ago
Very nice review Lock. Thumbs Up
Can you explain how you measured the lumens?
I have a JoshK sphere and all my lumen measurements were about 13% less than rated.
Also, have you tried to look at the driver or switch? They seem to be glued.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
Azza
Yes, I have some doubts here as well.
I recently got hold of the Rofis MR70 and the brightness factor doesn’t seem to be much different considering the near total flood the beam throws out.
The Lumintop ODF30 seems to be more brighter in the centre due to formation of a hot spot making the beam a bit throwier but sacrificing some useful floodiness… most perceptible at its high & mod nodes, rather than turbo.
patmurris
patmurris's picture
Last seen: 1 week 6 days ago
Waow! Great review and great photography in the wild.
Right now i’m in the Mercantour parc on the other side of the Alps.
It must have been cold!?
I like this light a lot, although it seems to be very very floody – almost pure flood?
Could you show a white wall beamshot?
Thanks again! Thumbs Up
PS; i found a coupon here: http://budgetlightforum.com/node/52547 (expired right now…)
JasonWW
JasonWW's picture
Since my last post I recieved my TA Lumen tube and TA recieved some measured lights from Maukka (he has a professional integrating sphere with calibrated reference lights). So we should use a 0.68 correction factor on these tubes.
I measured my ODF30 a bit earlier using a 0.7 correction factor, but that’s still very close.
Brightness levels are roughly:
Turbo 3150
High 1500
Med 500
Low 140
Eco 5
What I’m most interested in is the turbo run time before it starts to ramp down. I got about a 1m 37s before it starts to ramp down. It’s pretty hot to hold at this point. So I’m not really sure how lock is getting two and a half minutes. Maybe yours just getting a lot hotter than mine before stepping down?
Maybe it’s battery related? I see that the black KeepPower 5200mah has quite a bit more voltage sag than the Liitokala 5000mah cyan that I’m measuring with. Maybe this increased voltage sag means it’s delivering less amperage to the emitter so it heats up a little slower?
