MiBoxer C8 ( 8-bay) charger coming soon
Miboxer C8 coming soon
Input: 12V*5A
Output: 4.2V,4.35V,3.6V,1.48V.
Current: 8*1.0A, 4*1.5A, 2*2A
You will have the samples for review at July.
:open_mouth: :open_mouth: :open_mouth:
That look like a monster.
Nice feature you have there… now the rumored cat is really out of the bag! :+1: :beer:
Looking forward to this one
So, if two of the channels deliver 2A, then what do the remaining six channels deliver? 1A?
Or does it mean the remaining six channels cannot be used at all while those two channels run at 2A?
hello Pete
Thank you for your question.
what I mean 2*2A is, if there only 2pcs batteres in the charger, both channels can deliver 2A, and when you put 3 or 4 pcs batteries, the channels just can delivery 1.5A,
in the same way, if you put more than 4pcs in the charger, the charging current is 5*1A,6*1A,7*1A, and 8*1A.
Thanks
Is this what it means? :
1 x 2A max (remaining bays empty)
2 x 2A max (remaining bays empty)
….and when more than 2 bays are used, the 1or 2 X 2A goes down to:
3 x 1.5A max (remaining bays empty)
4 x 1.5A max (remaining bays empty)
5 x 1.0A max (remaining bays empty)
6 x 1.0A max (remaining bays empty)
7 x 1.0A max (remaining bay empty)
8 x 1.0A max
Am I correct?
yes, completely correct.
price? would love to see a C8-12 that would be monster.
I’ve got 2 C4-12’s so I’ve got 8 bays all of which can do 3A’s, I’ll just stick with those. Actually I think Miboxer should resolve the issues with current chargers rather than putting more in the market that may or may not work as advertised.
Actually mine both work fine I just don’t have a lot of confidence in them long term at this point
It looks nice but the slots are too close together. It lacks the spacing that the Gyrfalcon ALL-88 offers. Charging a bunch of 26650s or larger will be a problem. Make the slots wider on that Miboxer.
Huge +1 on this. I haven’t even looked at the photo until you pointed it out.
Ugly… well maybe just old school; I’d like to see someone do a new 8 cell charger like the Nitecore that has the batteries vertical in a cube shape for a small footprint… but with decent electronics of course.
I think the C8 is mainly aimed at 18650 cells.
Maybe a future model will be the C8-16 (8x2A) or C8-24 (8x3A). This will be aimed at multiple 26650 using a bigger frame.
It will take a lot of power and be pricey. I wonder if there will be a market for it compared to folks just buying two C4-12?
Miboxer C8 can charge 8 pcs 21700 Simultaneously
1.5A*4
0.8A*8
Li-ion(4.2V/4.35V)
Ni-CD/Ni-MH
LiFePO4
12V*3.0A input
by the way, all of Miboxer charger can charge 21700 with protected from now on.
the charging slot is 80mm can fit 21700 with protected batteries.
That’s a nice feature. :+1:
BTW, neither of your posts above have pictures showing, for me at least.
Looks great. Does it detect the internal resistance to automatically set the charge current? Can it display the internal resistance like the Miboxer C2-3000?
I wouldn’t worry about 26650, I predict they will die out as 21700 becomes more popular.
Why would you think that? Are you under the impression that a 21700 can match a 26650? Far from it. The 21700 is simply a container size in between the 18650 and 26650. That’s all.
The 21700 can’t match the 26650 capacity, but can deliver far and away more power. I’ve found this true in the Samsung 30T and iJoy 21700’s as compared to any 26650 I’ve tested, and there’s been quite a few.
But I for one will be using the 26650 for a long time, as well as the even larger 32650, as I have lights that do very well with these package sizes.
The MiBoxer C4-12 is a favorite charger of mine, I can’t see much use for less than 1A charge to 8 cells though so this new offering has no appeal to me.
