Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
1514 posts / 0 new
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 31 min ago
KB1428 “Live Life WOT
Newlumen
Newlumen's picture
Last seen: 3 days 2 hours ago
I did the kawi’s way.. i put one layer of plastic on the sensor and the number were reading lower…
Turn on.. general reading..
Noctigon m43.. 7200 lumen
Fenix L16. 1950 lumen
Fenix tk35ue.. 3640 lumen
Blf q8. 5230 lumen
Malkoff wildcat v6. 1200 lumen
Lumintop odf30. 3510 lumen
Thrunite tc20. 3280 lumen
I measure tn42vn90.. 5000 lumen… it was about 5200 lumen turn on and stepping down gradually…
From my general testing, ths lumen tube is pretty accurate without spending thousands of dollar…
Thrunite catapult v6. Using shockli IMR
Turn on. 2320 lumen
@30 second. 2200 lumen
SKV89
Last seen: 4 min 59 sec ago
Blf q8. 5230 lumen
Turn on. 2320 lumen
Glad to see a measurement of the TN42vn90. Did you add an extra layer of diffuser sheet at the meter?
Newlumen
Newlumen's picture
Blf q8. 5230 lumen
Turn on. 2320 lumen
Yea. I will test more lights especially Tn42vn90.
KawiBoy1428
My Malkoff Wildcat with 3 new batteries..
Texas_Ace
Texas_Ace's picture
Last seen: 2 days 7 hours ago
I have no idea what the ratings on most of those lights are supposed to be, would you might posting the rated lumens with the measured lumens?
Also some readings without the plastic would be nice to get a better idea of a general purpose calibration factor for everyone.
Sooner or later a number will have to be averaged out and selected for all of them to get comparable readings.
Newlumen
Newlumen's picture
So far I get better reading with the plastic.. it is pretty consistent..
Newlumen
Newlumen's picture
How do I make this tube stand level?? I can’t twist it anymore.: do you use heat gun ?
053_A54_C7-3_C13-41_C2-_A6_E6-1_B23_E697_FF66
Newlumen
Newlumen's picture
I want to make my lumen tube stand like the one in the first photo..
Micael
Try losening the the closest locking ring
Micael
Newlumen
Newlumen's picture
I will figure out.. in the meantime, I tested the tn40vn90. Skylumen got 5000 lumen @30 seconds..
I got 5600 turn on.. 5000 @ 30 seconds..
Olight sr96vn.. vinh got 12000 lumen… TA lumen tube 12540 lumen.
Stock acebeam L16… 2100 turn on.. 2050 @30 seconds..
So this tube is pretty accurate.
teacher
teacher's picture
Last seen: 7 months 4 weeks ago
No heat gun. Eat your Cheerio’s Newlumen & twist that thing to where it belongs…… Wink
Newlumen
Newlumen's picture
Yea.. i am very agree. My wrist size is 206 milimeter or 20.6 centimeter.. i am a small guy..
Newlumen
Newlumen's picture
I am getting very comfortable with the TA lumen tube.. I am getting better results..
Just set it like that and place your light..
F2_F13_CA5-6_B9_F-4_F1_D-_B432-_C092_EF0798_A5
Newlumen
Newlumen's picture
More test.. first one is turn on, and second number is 30seconds.. batteries use were sony vtc5/5a/30q.. give or take.
Malkoff wildcat v6. 1475/1408. Lg mj1
Thrunite tc20. 3820/3740. Shockli imr
Lumintop odf30. 3560/3410.. oem cell
Thrunite catapult v6. 2670/2540
Fenix tk35ue. 4560/4470
Emisar d4 quad xpl. 4360/3660
Emisar d1s. 1796/1734
D4vn skylumen quad xpg2 dedome. 3580/1650
D1vn skylumen sst40 sd. 2400/2250
Fenix tk72r skylumen. 14000/13820
Pelican 7060.. some box say 368 or 402… fresh off charger. 450 lumen
Noctigon m43vn xpl dedome.. skylumen 11000, TA 11320
Haikelite mt09r xhp70.2 cw. 25500/22800
SKV89
Just use your BLF GT for half an hour a day and watch your muscle grow Big Smile
Btw, the numbers you got looks pretty accurate. Is this with the plastic sheet added at the meter or just stock from TA?
Texas_Ace
Texas_Ace's picture
Nope, no glue or heat gun on that joint. Simple wiggle it back and forth while putting it out and it should loosen up. Then you can twist it to where ever you want.
Yeah, I agree the plastic is better for the readings, I am wanting to figure out how much adjustment the spheres need. The more data the better.
Newlumen
Newlumen's picture
It is very difficult to get the turn on lumen number because number change quickly.. but after all, we look for 30 seconds lumen…
So far so good. TA numbers are pretty close to skylumen..
Newlumen
Newlumen's picture
I add one layer of grocery plastic bag. Make sure the light is stable.
Newlumen
Newlumen's picture
I don’t know how malkoff measure their lumen.. wildcat v6 is rated 1050. Maybe they are using 4 cr123 or protected 18650.. we got 1400 lumen range using unprotected.
SKV89
I just realize you got 11k lumens for the M43vn. That seems much too high. I thought even Skylumen couldn’t boost it any above stock because it’s already overdriven from the factory, which is rated at 8,000 lumens for the XPL-HI. My M43 w/ XP-L HI v2 measured 7,000 lumens at turn on using ceiling bounce, whereas my MT09R with TA driver and TA swapped 4000k 80CRI emitters measured 22.8k lumens at turn on using ceiling bounce.
Newlumen
Newlumen's picture
I just realize you got 11k lumens for the M43vn. That seems much too high. I thought even Skylumen couldn’t boost it any above stock because it’s already overdriven from the factory, which is rated at 8,000 lumens for the XPL-HI. My M43 w/ XP-L HI v2 measured 7,000 lumens at turn on using ceiling bounce, whereas my MT09R with TA driver and TA swapped 4000k 80CRI emitters measured 22.8k lumens at turn on.
I bought my m43vn in September, 2016. Skylumen rated 11000 lumen, and I have it on my note…
8_E3005_C6-1_D37-4271-_A2_EF-94_A70_A9569_CD
free photo hosting
Found the spec card..
9_A63_ECC7-13_B1-465_C-_B46_F-9_BE652_B00_B60
images hosting
SKV89
Oh wow that’s very amazing considering the size of it.
Texas_Ace
Texas_Ace's picture
11k lumens from an M43 should be possible. I have a 12× 319A 80CRI light that does around 13k lumens, I use it as a photo light.
Newlumen
Newlumen's picture
Found the m43vn spec card.. check post #3510. I got 11320 lumen with the Sony vtc6.
SKV89
Which light is that? LOL
I currently use my 5000k 219c MF01 modded by Lexel (I think I measured about 10k lumens) for indoor photography by bouncing light off ceiling. Works very well and allows for fantastic looking pictures.
Texas_Ace
Texas_Ace's picture
It is a modded Supfire M6. Yep, I use it the same way. Works great.
JasonWW
JasonWW's picture
Last seen: 2 min 51 sec ago
Everyone should know that the measurements you get with a plastic bag or whatever over the sensor is not going to be relevant to anybody else. Not all plastic bags have the same density and reduce the output by the same amount. It’s best if we all just use the bare sensor and record the higher number so that we can all compare our lights with each other. Later on we will figure out an exact number to use as a correction factor. Then we will know the correct lumens.
KawiBoy1428
I’m looking at sending 3 of my stock constant current lights to a lab in Lincoln Park Michigan to get tested. But for now I’m pretty satisfied with what I got, actually I could not be happier!
So hurry up Jason or who ever, come up with something better, the other BLF members are waiting….
JasonWW
JasonWW's picture
The procedure right now is to simply use the lumen tube as designed even though it’s reading a little high. Texas Ace is having some of his lights sent over to Europe to get tested by Maukka. When he gets those back he will figure out a proper correction factor. (For the time being we can use .65 to .70)
THEN he will experiment with materials to use over the sensor to find something that eliminates the need for math to get the lumens. Something cheap and consistent that he can buy a lot of like a box of 20 to 50 sheets of a certain paper which can easily be mailed out so we all have the same exact material. Not from different sources or even different batches. All from the same box.
I’m not completely sold on plastic bags because it may have different densities from one to the other (a Walmart bag in Indiana might be slightly different than a Walmart bag in Florida) plus it’s prone to ripping. Also, it might reduce too much light or not enough.
I think we need to find a thin material that doesn’t reduce too much light so we can use multiple layers to find the right amount of light reduction.
I’m leaning toward white waxed tissue paper. It is cheap for one thing. The sample I tried needed 3 layers to reduce the light down to the level of my JoshK sphere.
So if you want a correction factor to bring it in line with the JoshK sphere (based on mine and emarkd tests) I would multiply the stock readings by .65
.64 to .73 seems to be the general correction range. Who knows, maybe the JoshK sphere is reading a bit low and .69 is more accurate? We will have to wait and see.
