Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
1513 posts / 0 new
beam0
beam0's picture
Last seen: 1 year 6 months ago
Newlumen wrote:
Not bad beam. i got 4662 lumen @30 seconds for the the stock blf q8. Samsung 30q fully charged..
Thanks, I also used fully charged 30q’s (stock button tops)
I was wondering about that one because it was coming up a lot higher with the plastic bags vs the deli paper.
"Over 2000000 hours (about 200 years) standby time"  (DQG Tiny 4th)
"27,157 results for zoomable flashlight" (ebay)
teacher
teacher's picture
Interesting info Jason. It really shows the variation & inconsistencies of different mediums…. even between the same medium.
Newlumen
Newlumen's picture
Last seen: 2 weeks 2 days ago
beam0 wrote:
JasonWW wrote:
I would be willing to give TA a deposit for the light and pay for shipping so I can find my particular lumen tubes exact correction number. Then the +-5% might shift down to +-1% or 2%. I could even ship it to the next person wanting to use it. I don’t know if TA or Micael would want to do this, though.
It may not even be needed. Of the 35-40 tubes made, I think statistically most are already in that +-1% or 2% range. The rest falling into the wider ranges. So passing a light around might be a waste of time. ???
For me right now I’d have no real need for the calibration light because TA is going to figure out what to for do re-calibration (something better than paper sheets / plastic bags) then he will send us the part to install or tell us what to do.
After that I could see maybe passing the light around to confirm accuracy of the fix, if TA recommends doing that, at that point I would be ok with paying for shipping the light to the next member.
I would be interested in sample lights., so I can compare.
Texas_Ace
Texas_Ace's picture
Last seen: 1 hour 27 min ago
beam0 wrote:
I assume TA is going to figure out something better than paper sheets / plastic bags etc. and send us the part that can then be permanently installed. (or tell us what/where to buy it)
Yes, I plan to figure out a more universal option. I cut out some acrylic discs yesterday that fit into the meter hole. So I can stick some form of diffuser to them to get the readings correct.
Texas_Ace
Texas_Ace's picture
maukka wrote:
TA’s calibration lights (S2+ 8×7135 XM-L2 3B and BLF348 219B) are measured and ready to ship as well.
Great! I will pm the details shortly.
JasonWW
JasonWW's picture
Last seen: 16 min 39 sec ago
What types of diffuser material have you tried?
I’ve also just noticed that the readings change a noticeable amount depending on how far you push the Lux meter in the hole.
Click this to go to signature links.
Texas_Ace
Texas_Ace's picture
Yep, even 1mm will have a noticeable effect. The same goes for the 1st piece of PVC as well, how hard it is pressed in can have a surprisingly noticeable effect on the readings.
Now factor that by the 4 joints in the sphere (which you had to take apart to make any changes and then reassemble to measure and hope you got it together with the same force every time, which you never did) and you start to see the tip of the iceberg these were to calibrate lol.
beam0
beam0's picture
Sounds great!
Texas_Ace
Texas_Ace's picture
Missed this before, I have not tried much yet, until I have a more exact correction factor to aim for it is hard to know what will work.
I am thinking some form of DC-Fix type sheet is what I would like to use, unless I happen to find something that works perfectly. I am going to check home depot sometime to see what kind of options they have. Some very light window tint could work but I have a feeling it would drop the readings too much.
I also cut some discs out of the left over/broken diffusing sheets I used in the spheres to see if they happen to drop the readings by the right amount.
Newlumen
Newlumen's picture
So i tested my fenix tk35ue.. there is a guy name Kospap who tested the fenix tk35ue and we got similar result.. I got 3486 lumen @30 seconds.. below is his graph.. look like my TA tube is working great with .70 factor.
2_DF315_F5-861_D-4_BEE-_A3_E7-_A96_F142_DAA57
JasonWW
JasonWW's picture
How does Kospap measure it, does he have an integrating sphere like Maukka?
Edit: I see his review. He says he confirmed the lumen output, but he gives no details on how he did it.
peabody
Last seen: 6 hours 55 min ago
Here is just a few.
all readings on original tube at 10 seconds
Olight S1 rated 500 aluminum side down 744 grey side down 710 AW16340 finishing charge 4.08
Zebralight SC62W 930 1245 1175 zebralight battery 4.10
Nitecore TM16GTVn 6300 6650 6540 unprotected 30Q 4.05
Thorefire VG10 847 1178 1050 30Q 4.02
Thorefire BLFQ8 5500 5880 5680 30Q 4.04
Niwalker mm18mbvn 8500 8480 8380 30q 4.05
Emisar D4 3826 4550 4360 30q 4.02 Emisar D1 1434 1828 1747 30q 4.04
4-7s Malestrom mmu-x3 1600 2520 2480 four sevens 4.01
Newlumen
Newlumen's picture
I have no clue.. i was reading it on cpf and it say light box.. . we would have to send PM and asked him how he calibrated and stuff.
Newlumen
Newlumen's picture
I sent PM to him.. i will let you know.
JasonWW
JasonWW's picture
peabody wrote:
Here is just a few.
We always put the reflective tape side down into the tube. This is the way TA calibrated it.
If you flip the spacer over to have the painted side down, you get unknown numbers.
Texas_Ace
Texas_Ace's picture
Yes, the silver paint was an experiment to try to make things simpler but it didn’t work. Too bad, that reflective tape was way way more work then it seems.
NeutralFan
NeutralFan's picture
Last seen: 1 day 6 hours ago
I spent last night reading through all the posts – interesting stuff!
Curious, does ambient light impact the measurements at all? In other words, does it matter if the measurements are taken in a dark room vs outside in the sun?
I’d rather use my flashlight around the house than turn on the lights.
Texas_Ace
Texas_Ace's picture
The PVC is thick enough that the most I have ever really seen is 1-2 lumens from ambient light through the pipe itself.
Newlumen
Newlumen's picture
So yea. Maukka lumen are legit.. he tested astrolux mf02 cw @ 30 seconds and got 2109 lumen…
I tested my mf02 nw @30 seconds and got 2044 lumen.
I am using .70 correction factor as worst case scenario…
teacher
teacher's picture
(snip)
Yep, I kinda figured they would be…. since he does have a real Integrated Sphere. Wink
JasonWW
JasonWW's picture
I think it’s only fair to mention the MF02 has had at least three different driver versions with three different turbo output levels. When the MF02 first came out, turbo was about 1.8 amp. Then it got bumped up to about 2.2 amp. The very latest versions within the last month seem to have been bumped up to about 2.7 amp.
Newlumen
Newlumen's picture
Mine is the latest version… we can say for sure mf02 are no more than 2100 lumen..
SKV89
Last seen: 18 min 3 sec ago
I just had some time to play with the lumen tube very briefly. It is VERY easy to use compared to my ceiling bounce and calculator method. It is also very consistent regardless of the flashlight head insertion depth, which is a sigh of relief because that was something I was worried about. The measurements are very high though as already confirmed by others. I get about 27.5k startup lumens on my MT09RTA whereas using my previous ceiling bounce standard, I was getting 22.8k startup lumens. Once TA gets the calibration corrected, this will be a fantastic device. I don’t regret my purchase a tiny bit I can tell it required alot of manual labor to construct this along with the discs.
Now I will have to store this away until I find a place to put this in my house. I’m out of room already. My room is already littered with flashslights and batteries.
Newlumen
Newlumen's picture
Thats good bro.. i calibrated my meter to fenix standard, and took the .70 factor lowest number for the worst case scenario.
Haikelite mt09r TA triple xhp 35 cw. 5425 lumen @ 30 seconds
Haikelite mt09r TA tiple xhp70.2 cw. 18,200 lumen @30 seconds.
Haikelite mt07s. TA. Single xhp70.2 cw. 6552 lumen @ 30 seconds.
JordanZHP
Last seen: 1 hour 3 min ago
Sorry if it’s too off topic, but is there an easy way to tell what version my MF02 is? Thanks!
JasonWW
JasonWW's picture
When you bought it would give you a general idea. The only way for sure is to measure the amp draw on the emitter.
Newlumen
Newlumen's picture
Bezel were glued very tight in the latest version. If you purchased after jan, most likey they are new version.
JasonWW
JasonWW's picture
Yeah, I think Lexel said the early versions had no thread locker. Then they started using a light colored thread locker that was pretty weak. The latest ones use a red thread locker and are really hard to break loose.
steel_1024
steel_1024's picture
Last seen: 5 hours 54 min ago
Arrived today
First test:LuminTop ODF30
moon: 11
Low:191
Mid:682
High:2140
Turbo:4270
[correction facto 0.8 ?]
Original factory value:
moon: 8
Low:150
Mid:540
High:1800
Turbo:3500
Sorry for my poor english.
Micael
Last seen: 1 month 5 days ago
Hi all.
I’m excited, i got my lumen tube today so now the fun begins:)/Micael
Is a flooder or a spot giving higer lumens/Lux on the meter?
Micael
