Review: Manker U22 (1x21700, NW, XHP35 Hi, Rechargeable, Thermal test)
7 posts / 0 new
Budda
Budda's picture
Last seen: 2 days 1 hour ago
I received the Manker U22 from Manker.com for the review.
The U22 is Manker latest release, it’s a compact version of the well known Manker U21. It features XHP35 Hi, in a slimmer and shorter design, and noticeably it is powered by a 21700 li-ion battery.
The U22 is available in NW and CW version. I got the NW one.
The Manker U22 comes in this box.
Inside the box: the U22 with the battery, lanyard, spare o-ring and charging cable.
The U22
The overall design of the U22 recalls the one of the U21: thin body with a bigger head, but it is noticeably slimmer when you compare the two lights.
There is still a single, back lit, electronic switch at the head. On the other side of the electronic switch there is the USB-C port for charging the battery.
The head hosts a XHP-35 HI emitter, in a smooth parable. The glass has AR coating.
The tailcap allows tailstanding and has a hole for the lanyard.
On my sample the body is glued to the head of the light, and the only part I can remove is the tailcap. The male threads on the body are triangular cut and anodized, allowing physical lockout.
At the tailcap there’s a pair of golden nested springs, and at the tailcap a golden spring (flat top cells can be used).
Beamshots
The tint of my light is a pleasant NW, with a yellowish color.
Setup 1, 100 meters at the tree.
Setup 2
Output and runtime
Everything tested with the provided Manker 21700 Li-ion Protected battery, with a claimed capacity of 4800mAh.
At turbo, the light gets brighter after a few seconds, reaching the peak at 44”.
I also tested the provided 21700 battery from Manker, discharging it at 2.0A until 2.8 Volts with my SKYRC MC3000.
Here’s a thermal video of the light running at turbo mode
My thoughts
The light is well built and finished.
The regulation at the tested levels is ok.
I like that the UI allows you to access directly to lowest, highest and last used mode.
I like that the lowest mode has a settable brightness in the order of a few lumens, but the jump to the next output is a bit too big. I would like to have a 30-50 lumen mode more. .
I think the U22 is a good compromise of flood/throw and pocketability. Compared to the U21, it has lesser throw, but it is much much more light and compact.
My thoughts on the 21700 cell:
The introduction of the new battery format, 21700, it is a novelty. In a few mms more than a 18650, you have more capacity (the cell is rated 4800mAh), and the extra size and weight of the battery and the overall body construction, makes the light more balanced and easier to hold and use. The 21700 that comes with the U22 is button top but protected, so it’s even longer than a regular unprotected 21700 (the Manker one measures around 74mm).
In my personal experience, I wasn’t able to charge the 21700 in any of my chargers (Nitecore D2, Nitecore I2, several GYRFALCONS) because it is too long, and it doesn’t fit in any of the slots. I had to resort to charge it with the USB-C port on the light (for the Discharge test I pushed a lot a slot of the SKYRC).
Regarding the future of the 21700 format in the flashlight world, It is still a wild guess. Not long ago the 26650 was a promising format, but was never fully adopted on any flashlight format. In my opinion the 21700 has a more promising future because it will be more supported from a research-industrial standpoint, thus, like the 18650, we could see the performance of that particular format increase significantly in time (like the 18650s did, passing from a expensive 2000mAh cell, to a cheap, 3500mAh cell with good discharging capability).
And maybe, above all, it’s a size that is still compatible with the EDC segment, unlike the bigger 26650.
But only time will tell.
The light is still compatible with a 18650 cell, although Manker doesn’t provide a spacer.
I would like to see the light come with a sheath.
Thanks to: AntoLed for the camera, the tripod, the camera help, the luxmeter.
All my reviews, in italian and english, here: Lumenreviews.com
Edited by: Budda on 04/22/2018 - 09:52
maukka
maukka's picture
Last seen: 4 days 10 hours ago
That runtime is weird. Why does it step down if it only gets to 38°C? There should be real thermal control in a light at this price point.
komeko
komeko's picture
Last seen: 2 hours 9 min ago
Nice review but … I did not compare to U21 (beamshots). I wonder how a direct comparison would be made to Thrunite V6.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
SKV89
Last seen: 1 hour 27 min ago
Great review. Too bad this doesn’t out throw the D1S otherwise I would have bought it.
StandardBattery
Last seen: 6 months 4 days ago
Nice Overview. As soon as it’s dark I’m going out with min to check a few things. I got mine without their battery.
I think you meant U21, and ‘less’ vs. ‘lesser’ in the sentence below.
“Compared to the U22, it has lesser throw,….”
Budda
Budda's picture
Thanks. fixed.
PhatPhil
Anyone recommend a diffuser for the U22??
