14500 sizes
25 posts / 0 new
mmalive
Last seen: 11 months 6 days ago
14500 sizes
Hey guys, are these cells suppose to be same size as AA? One if mine is about 1/4 longer. Please advise.
HKJ
HKJ's picture
Last seen: 2 hours 29 min ago
Unprotected flat top 14500 is the same size as AA. A button top may add a mm and protection add a couple of mm
ifratos
ifratos's picture
Maybe is it protected.Can you show as a photo?
And God said, Let there be light: and there was light.( Gen.1:3)
mmalive
I do not know how to post pictures on here. But for sure it has a PCB and much longer than regular AA. The reason is one of my lights uses AA x 2. I can not fit them in at all. Both 14500 are longer.
mmalive
The 14500 is 1/4” longer than AA for sure. I measured it.
The name brand is Digital Energy World. Sold a few years ago at Radioshack.
GreenLights
Last seen: 3 hours 27 min ago
I hope you weren’t going to put 2×14500 in a 2xAA light, even if they would fit.
Just discovered this wonderful addiction.
ifratos
ifratos's picture
mmalive
Why not please? Then that means I might end up making spacer if only 1 is used?
ifratos
ifratos's picture
If AA are in parallel and your flashligt works also with 14500 you can, but if is it in seriese not because you will have 8.4V instead or 3V.
SamGranger
14500 is about the same size as an AA, but its a 3.7V battery. AA batteries are 1.5V. You can find 14500 batteries that are compatible though with AA batteries.
mmalive
ifratos wrote:
If AA are in parallel and your flashligt works with 14500 you can, but if is it in seriese not because you will have 8.4V instead or 3V.
Both batteries will be installed with + end towards head and next battery right behind it. That is the reason I can not fit both in there. Both 14500 will be 1/2” longer.
ifratos
ifratos's picture
14500 li ion have 3,6V nominal 4.2V maximum not 1.7
http://batteryuniversity.com/learn/article/serial_and_parallel_battery_c...
mmalive
Ooh, the battery is 3.7V according to package on battery.
ifratos
ifratos's picture
Your lucky was longer , otherwise you burned your FL
mmalive
Cool thanks. So I can use 1 and make spacer?
ifratos
ifratos's picture
I’m not sure depend of your FL specification , if works with 4.2V Yes.
GreenLights
If you got the 14500s in order to have rechargeable batteries, look into getting some Eneloop AA instead. They will be the correct voltage for your light and are high quality.
And now that you have some 14500s, now you can add to your collection and buy a light that takes them. Smile Just make sure the light you get specifically says it will take protected 14500s.
ifratos
ifratos's picture
I agree too ,best advice for you.
mmalive
These are the 2.
https://policesecurity.com/product/sleuth-silver-2aa/
https://policesecurity.com/product/hypercage-2aa/
mmalive
Thanks for info. I have the Costco Eneloops recently.
ifratos
ifratos's picture
Unfortunately no one informations there about max voltage . Stay with AA rechargeable better.
GreenLights
“The HyperCAGE features an industrial design that is nearly unbreakable. Drop it from 100 feet and dunk it 3 meters under water, it can handle it.”
It survives a 100 foot drop. That’s impressive!
mmalive
That is reason I own 2 of them. Just wanted to use 14500. But I will settle on Eneloops if not viable for 14500.
ifratos
ifratos's picture
For 14500 buy this and you will be more than happy:
https://www.aliexpress.com/store/product/Powerful-LED-flashlight-EDC-pocket-torcia-lamp-with-Cree-R5-400lm-3-Modes-waterproof-LED-torch/2933049_32796820396.html?spm=2114.12010612.0.0.6f4b5da8A0FcGr
d_t_a
Last seen: 3 days 3 hours ago
I got several 14500s now.
The Sofirn 14500 is noticeably shorter, even with its button top, it’s just as tall as the shoulder of the Fujitsu (LSD NiMh).
The Hixon is a protected 14500 and is notably much taller than a regular AA (it’s also slightly fatter in diameter).
The PKCell is a flat-top (on the second PKCell in the picture, I placed a disc magnet on top of it so it can function as a button-top temporarily on flashlights that require button tops)
