Test/review of LiitoKala 21700 4000mAh Lii-40A (Yellow)
14 posts / 0 new
HKJ
HKJ's picture
Last seen: 1 hour 25 min ago
DSC_7165
Official specifications:
  • Model: Lii-40A
  • Size: 21700
  • Chemistry: IMR
  • Nominal Capacity: 4000mAh
  • Nominal Voltage: 3.6V
  • Discharge: 40A Max Continuous
  • Positive: Flat
  • Rechargeable: Yes
  • Dimensions: 21.2mm x 70.4mm
  • Weight: 61.2g
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-info
High current 21700 cells from LiitoKala and also with good capacity.
DSC_7164
DSC_7166 DSC_7167
DSC_7168
DSC_7169
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Capacity
The two cell matches discharge curves fairly well and capacity is nearly constant at any load.
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Temp-15.0
The cells get warm at high current.
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Temp-20.0
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Temp-30.0
I do not know exactly what happend with the B cell, but my battery holder was melted, i.e. the strange curve is probably due to a damaged battery holder and not the cell.
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-CapacityTimeHours
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Energy
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-PowerLoadTime
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-TripCurrent
LiitoKala%2021700%204000mAh%20Lii-40A%20(Yellow)-Charge
Conclusion
The cells has the rated capacity and capacity is fairly constant with load, but they do get rather hot at high current. This means they may handle high pulse current, but 20A or more in constant current is not a good idea.
Notes and links
Compare to 18650 and other batteries
Edited by: HKJ on 05/08/2018 - 11:31
Agro
Agro's picture
Last seen: 2 days 49 min ago
Oh yeah, I waited for this test. Good battery in general and very good for the price.
Thanks HKJ!
Henk4U2
Henk4U2's picture
Last seen: 10 hours 11 min ago
Thank you for yet another review. It seems that my Samsung INR21700-48G is still best choice as long as I don’t exceed 10-12A.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
Barkuti
Barkuti's picture
Last seen: 1 hour 55 min ago
Well, a Lishen cell with almost 4Ah and a 3C rating.
It's appeal lies in its demolition class price LoL.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Agro
Agro's picture
$7.05 / 2 pieces for the next 2 weeks:
https://www.aliexpress.com/item/LiitoKala-Lii-40A-3-7V-21700-4000mAh-14-...PCB/32846442786.html
Is that a good price?
Satan@103TFS
Last seen: 2 days 2 hours ago
Agro wrote:
$7.05 / 2 pieces for the next 2 weeks: https://www.aliexpress.com/item/LiitoKala-Lii-40A-3-7V-21700-4000mAh-14-...PCB/32846442786.html Is that a good price?
Not for TH with 26.32$ shipping.
BlueSwordM
BlueSwordM's picture
Last seen: 3 hours 59 min ago
If you are in the US, then it is the best deal on lithium ion cells I have found outside of bulk purchases.
Otherwise, I will continue ordering from there:
https://sunway.aliexpress.com/store/3173029?spm=2114.12010108.0.0.5de455...
Satan@103TFS
There are 2 colors of Liitokala Lii-40A yellow and pink ,are they the same?
Nicolaas
HKJ: considering the high capacity of 20700&21700 cells, shouldn’t you put them in your 26650/32650 list rather then with the 18650 cells?
Thanks for all your testing: it really helps us out to decide what to buy!
Cheers,
Nico
JasonWW
JasonWW's picture
Last seen: 1 hour 47 min ago
The Lii-40A are already in both lists.
Or do you mean all 20700 and 21700?
JasonWW
JasonWW's picture
Satan@103TFS wrote:
There are 2 colors of Liitokala Lii-40A yellow and pink, are they the same?
Are you sure? Do you have the pink ones or know some place selling them?
It seems they are all yellow at the moment. If you have info about the pink, I would like to find out about it.
Satan@103TFS
Many of the pink one.
https://www.aliexpress.com/wholesale?catId=0&initiative_id=SB_2018061201...
HKJ
HKJ's picture
They are in both lists, but I usual forget to change the link at the bottom (It is auto generated to the 18650 list).
I have just added a link in the 18650 comparator to the 26650 comparator, hopefully this will help with this.
JasonWW
JasonWW's picture
Okay, I see.
My suggestion is to buy the yellow since it was the one HKJ tested. The pink might be identical, but why take that chance?
I personally would just buy the yellow.
