[M4Ddeal active]: XTAR PB2
78 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 7 min 43 sec ago
Just received mine. It’s extremely light in one‘s hand and the surface feels really smooth. I’ll put some VTC6s in it later on. A bit of chemical odor is left on one‘s skin after holding it but I hope it will diminish soon. Thanks a lot for this opportunity Martin! Smile
BlueSwordM
BlueSwordM's picture
Last seen: 4 min 20 sec ago
Wash your hands if you smell that.
Better safe than sorry.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
A_M_K
A_M_K's picture
Last seen: 1 day 23 min ago
Today I finally received mine. Everything is fine and after reading the reviews, there are no major surprises. The display is very hard to read with that light bleed and I wish it also had a USB-C port in addition to the micro-USB, also a better more powerfull pass-through charging, including a UPS mode would have been nice.
I have just one question. Has anyone here managed to open the damn thing without breaking it? The case seems impenetrable, I don’t wan’t to destroy mine, but I really want to see what’s inside! Big Smile
atbglenn
atbglenn's picture
Last seen: 1 week 6 days ago
While the display isn’t perfect, I have no problem reading it.
Kindle
Kindle's picture
Last seen: 4 days 5 hours ago
Ditto. I didn’t even notice the glare until it was mentioned here.
atbglenn
atbglenn's picture
I noticed it, but it was so minor it wasn’t worth mentioning it.
A_M_K
A_M_K's picture
Here it is showing 90%
91%
91%
maukka
maukka's picture
Last seen: 3 min 30 sec ago
Attach a blue filter on top of it and it’ll be as clear as day.
james butcher
Last seen: 5 days 5 hours ago
thanks for the code M4D M4X got mine today(was oos for a while)
just trying to resurrect couple over discharged 30Qs that discharged to 1.5v .
probably wont bring them back but worth a go, its displaying 00% im guessing it’ll take a few hours to go above 3v and display a percentage?
anyone know long it will take?
Zulumoose
Zulumoose's picture
Last seen: 2 days 22 hours ago
I would test the voltage while charging to make sure it is actually trying to charge them. If it doesn’t seem to be doing anything you could try and jump-start the process by putting another charged cell in parallel for a couple of seconds by touching with thin wire, that will get the voltage into normal range and the charger into normal charging operation. Do this for only a few seconds, and the cell will likely maintain voltage in the recognised range and allow normal charging.
It’s probably not a good idea with very old cells, and you should monitor their temperature regularly while charging and put them through a few discharge/charge cycles until they stop improving, and then see if they can hold their charge for a week before trusting them.
Disclaimer – I can’t vouch for the safety in jump-starting lithium cells, and welcome any comment on this by more experienced users. I have done it with great success so far though.
Beam me up!
james butcher
yeh the jump start method is a bit iffy for as i only have cheap multimeter.
but anyway i just measured voltage after 30mins (checking for heat every 5mins)or so and its was 2.95v so i put them back in pb2 and just checked again and its reading 10% already so looks like the chargers already paid for itself.
dont know if it will affect the discharge time but its looking good so far.
clemence
clemence's picture
Last seen: 53 min 39 sec ago
Received mine last week. It’s working as advertised, small, stylish, feels good in hands, doesn’t take any protected cells, hard to read, but… I like it. Any filter will helps to make it easier to read. Simply use car windshield film (not the metalized one) and off you go.
I carry it in my side bag plus 4 pcs extra whatever 18650s laying around.
- Clemence
Lux-Perpetua
My PB2 only charges a few devices. I did not manage to charge an iPad (Version 2017) nor an Kindle Paperwhite with it. It immediately stops charging when I attach the cables. When I plug my iPhone onto it, it works just fine. Any ideas what’s wrong here? The iPad should definitely draw more than 250mA.
james butcher
Same here, mine won’t power my miracast or charge ecig
Lux-Perpetua
I found out my PB2 terminates cells at 4.22V resting voltage (after one hour outside of the PB2).
Funtastic
Last seen: 3 days 20 hours ago
Did you suss out why it wasn’t changing those devices?
Just doing a bit of research before importing to sell. Maybe I should wait until Xtar’s latest version releasing later this year.
Lux-Perpetua
Lately, I tried it again with a very short Lightning cable (20cm) from Anker. This time everything worked fine, i.e. both the iPad and the iPhone were charged. But it's shocking that an iPad's battery gets charged by approx. 25-30% only with 2x 18650 batteries.
