Convoy C8+ New look for an old favorite
151 posts / 0 new
beam0
beam0's picture
Dale, the single cell light I’m modding isn’t a C8, but it is an old favorite, an original UltraFire HD2010, which already has pretty amazing throw for having an outdated emitter (XML T6) with east-092 driver (DD but crappy mode arrangement)
I have one of these copper pills:
Takes up to a 26mm MCPCB, and a 22mm linear/FET driver.
I plan to use a Maxtoch XP 26mm Copper MCPCB to keep the wires away from shorting on the reflector.
And yes throw isn’t everything in my plans for it, I want good throw, but with some useful spill / larger hot spot / extra output.
It’s one of my favorite lights and one of my first purchases when I got into this, and I’d like to make it into something special and useful, so I thought it would be a good candidate for an XHP35 HI, don’t want to derail too much here but I’d love to hear any other suggestions.
I’m also considering an XP-L2 HD (dome on) I have a few (stock) lights equipped with it and the tint looks fine to me.
DB Custom
DB Custom's picture
Last seen: 1 month 1 week ago
I’d use an FET driver from Richard paired with an SST-40, I think. That is a good combination for this C8+ or the HD2010 either one, where the parameters are as you outlined. I think I’d use thermal paste to begin with, try it out, and if the spot was too large I’d pull the pill and remove the emitter then slice/dice/shave the SST-40. Would probably re-flow the emitter/mcpcb into the pill then, might would reinstall it with thermal paste and double check first but I’d probably go straight to the re-flow. (test it first, make sure it isn’t ringy and that it’s to your satisfaction, then go from there.)
beam0
beam0's picture
DB Custom wrote:
I’d use an FET driver from Richard paired with an SST-40…………….
Thanks, then I’ll use a MTN-22DDm.
Versus using only thermal paste, what does reflowing the mcpcb to the pill result in? Better heat dissipation?
I had thought about the SST40 but wasn’t sure I’d be okay with the tint since I’m pretty firm on neutral tints only, and everyone seems to comment on how cold/bluish it is, interestingly just today I received my first SST40 light! (Jetbeam E20R). I wasn’t able to get outside with it tonight but inside it’s not too horrible, I don’t see any bluish tint at all, even on white walls, it looks very yellowish to me, with a hint of green.
I also plan to get the C8+ tan host version and run a MTN-17DDm so maybe the SST40 for it as well. I see Richard offers the Slice LED option, how’s the tint on it after slicing?
DB Custom
DB Custom's picture
The SST-40 doesn’t exhibit the tint shift we’re used to seeing from Cree, it does drop some but not like the XM-L2’s. I’ve found the 40 to have a nice creamy color once the dome is taken off. Richard seals them though, so it’s a bit different than a naked die.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 27 min 33 sec ago
Does anybody know if the old bezel ring will fit to the new C8+?
https://www.banggood.com/de/Convoy-C8-Stainless-Steel-Tactical-Attack-He...
Luminous and wired, we'll be glowing in the dark.
ZozzV6
ZozzV6's picture
Last seen: 6 days 23 hours ago
I saw a picture of a C8+ with stainless bezel so yes.
DavidEF
DavidEF's picture
Last seen: 19 hours 14 min ago
But what about a nude gnu?
- The YKK Philosophy
beam0
beam0's picture
Thanks, curious though now to see that photo Smile (no luck with google etc.)
DB Custom
DB Custom's picture
Gnude Gnu’s haven’t been legalized for power use to date, not in the US anyway. Testing is underway to put them to work under AR confinement but the results are not in… Gnarly Gnude Gnu’s will be next. Mark my words. Wink
DavidEF
DavidEF's picture
I only asked because you mentioned creamy colors and naked dies. Innocent
DB Custom
DB Custom's picture
Naked makes news, always! Smile
Still though, it’s true, the XM-L2 U4 with a clean de-dome on it throws further and burns less current than a pushed XP-L HI, MaxToch found that out in the Shooter 2X.
ZozzV6
ZozzV6's picture
Found it. It was in a facebook flashlight group.
beam0
beam0's picture
Thanks Zozz, a small gap but it looks pretty good!
DB Custom
DB Custom's picture
Put a thicker lens in it, increase the gap, and you’ve just effectively added a cooling fin. Wink
bmengineer
bmengineer's picture
Last seen: 1 week 4 days ago
With these updates to the Convoy line, I wonder if there’s going to be any changes or new colors to the M series of Convoy lights…
Find all my reviews of flashlights and more gear at www.bmengineer.com
hIKARInoob
hIKARInoob's picture
Last seen: 2 months 4 days ago
No idea if this video was posted already, but here it is. And my goodness it’s good looking… Big Smile
mortuus
mortuus's picture
Last seen: 13 hours 33 min ago
banggood claims 1100 lumens for this, i guess its their usual marketing and its not really true?
https://www.banggood.com/Convoy-C8-Sand-color-XPL-HI-1100LM-Memory-Function-Professional-12-Group-55Mode-Tactical-Flashlight-p-1294747.html?rmmds=search&cur_warehouse=CN
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
desmondkun
desmondkun's picture
Last seen: 23 hours 31 min ago
I look again and again. I think I like the old version better.
They should make more different than only it’s looks.
Take care of your flashlight and your flashlight will take care of you.
maukka
maukka's picture
Last seen: 11 hours 5 min ago
The clear coated Convoy C8 with 3A XP-L HI does 839 lumens @ 30 sec on high.
WalkIntoTheLight
Last seen: 3 weeks 3 days ago
The Convoy store also claims “about 1100 lumens”, so it might be true. The output current is listed at 3000mA, which is higher than the previous Convoys that use 8×7135. So, it looks like they’re using a better driver.
If I had to guess, I’d say probably closer to 1000 lumens, but I wouldn’t rule out 1100.
DB Custom
DB Custom's picture
Pretty sure the driver is made up consisting of 8×380mA 7135 chips, making it effectively a QLite (3.04A) So actual output depends greatly on the emitter choice you make when you order the light. A 1A tint will be higher than a 4C, for example. Just how it is. Relatively simple to stack a few chips for more power.
J-Dub74
J-Dub74's picture
Last seen: 4 months 2 days ago
Where are you referring to that it says this? I haven’t seen that info anywhere. As far as I know this is still the 2.8A driver and would not be putting out 1100 lumens. Am I missing something? I can see BG listing 1100 lumens but I don’t see anything like this in the Convoy store.
Satan@103TFS
Last seen: 2 hours 58 min ago
That’s L2 , are we talking about C8 ?
J-Dub74
J-Dub74's picture
Thought I was losing it for a minute there. Yeah that is the L2 and this thread is about the C8+ Wink
WalkIntoTheLight
Doh! Sorry. Okay, I take it back. I have no idea why BG is claiming 1100 lumens.
nkresho
nkresho's picture
Last seen: 2 months 4 weeks ago
I got a tad over 700 lumens out of the box… maybe closer to 800 (log is at home). With a freshly charged 30Q. I replaced the driver with a blf a6 one and swapped emitter with a sliced SST40. Now it’s making just over 1600. Perfect light now.
WalkIntoTheLight
Nice! What’s the throw like? The Astrolux C8 uses a BLF A6 driver and an XP-L HI emitter, getting around 100k candella with a fully-charged 30Q cell, at about 1300 lumens. Does the SST40 with 1600 lumens throw further?
nkresho
nkresho's picture
I’ll check it tonight and post here.
DB Custom
DB Custom's picture
The SST-40 would have to be de-domed to throw similarly or better than an XP-L HI, not an apples to apples throw comparison if the SST-40 is domed.
DB Custom
DB Custom's picture
In my own experience though, the de-domed SST-40 throws somewhat less than a clean de-domed XM-L2, albeit making much more lumens in the process. (The SST-40 makes more)
