ALIVE: Haikelite MT07S only US$46.72
186 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 hours 42 min ago
Thank you very much hIKARInoob! It worked! Thumbs Up
hIKARInoob
hIKARInoob's picture
Last seen: 28 min 13 sec ago
Cheers man. I’m afraid there doesn’t seem to be a permanent fix to this problem, and it’s a software bug or something.
Lux-Perpetua
Now, I need to figure out what this rattling is about. Without the battery tube the head still rattles as if there is something loose inside, maybe the MCPCB or maybe the glas lens.
Update: It’s not the glas lens. I pushed my fingers against it when I shook the flashlight’s head.
aginthelaw
aginthelaw's picture
Last seen: 58 min 47 sec ago
I have 2 versions of the mt07s. one that has the blinking switch light bug and one that doesn’t. is there a way to turn off the indicator light when on? it doesn’t make sense that the switch light comes on when the light is on. I already know the light is on, I don’t need the switch to tell me it’s on.
never fear shadows…it means a light shines nearby
ImA4Wheelr
Last seen: 1 week 1 day ago
Tell me about it.  It seems most lighted side switches do that.  I want a light I can find in the dark.
I've been wanting to probe the MT07S driver for a spot that feeds the power to MCU (should be under 5V).  Then just connect one of the switches blue LED to it.  May need a resistor if to bright.  The LED would always be on and the red LED for low voltage should still function.
Or, you can just use a very high value resistor directly off the 16.8v from the battery pack.  Probably would start with 100,000 ohm at least.  Recommend you use a test LED that you wouldn't mind frying first.
