Laser Digital measurer
15 posts / 0 new
Robowski
Robowski's picture
Last seen: 3 days 19 hours ago
Hi everybody,
I’m looking at upgrading my old tape measures to the laser type.
This is only for home use and I don’t want to spend a fortune on some professional model that I would only use occasionally.
Has anybody bought a good budget measure that works well, from sites like eBay, Banggood etc?
I’m in Australia, so buying from USA or Europe can almost double the price with postage costs.
I have bought all my flashlights, batteries etc from Banggood because of free postage.
eBay can also have low postage costs especially from China.
thijsco19
Last seen: 3 hours 17 min ago
I dont have any experience with them but if I was looking to buy one and couldn’t find one locally I would probably get this one: https://www.banggood.com/UNI-T-UT392B-100M-Laser-Range-Finder-Distance-M....
RobertB
RobertB's picture
Last seen: 31 min 4 sec ago
Bosch power tools should be available in Australia at most home improvement stores. The 60 to 120ft models range from $40 to $80 here in the US. Wouldn’t expect them to be much different in Aus.
There are some Bosch models in the 2 to $300 range, but they calculate all kinds of angles and other measurements. But if all you need is a basic unit, they aren’t that expensive
XXX-Man
XXX-Man's picture
Last seen: 14 min 32 sec ago
You can buy this one
https://www.banggood.com/KXL-E40-40M-High-Precision-Digital-Handheld-Las...?
I ordered 5pcs for me and friends and they all work perfect.
"With the first link, the chain is forged. The first speech censured...the first thought forbidden...the first freedom denied – chains us all, irrevocably."
My reviews:
Sofirn SF36 /// Thorfire VG10S /// Sofirn C8F
Robowski
Robowski's picture
Thanks all you guys for your advice.
RobertB – yes, the Bosch tools are widely available in Australia, and if I was to buy from a walk-in store, that is what I would get.
thijsco19 and XXX-Man, both your suggestions look like good ones to buy as well.
I will have a look at all of these and make a decision soon.
klrman
klrman's picture
Last seen: 13 hours 53 min ago
atbglenn
atbglenn's picture
Last seen: 49 min 33 sec ago
klrman wrote:
I have this one.  It’s on sale right now and works perfect.
https://www.gearbest.com/laser-rangefinder-electronic-distance-meter/pp_366164.html?wid=1433363
I have the same one. Great display, and seems accurate enough. It has features I’ll never use.
XXX-Man
XXX-Man's picture
That’s the same one from my link.
Gearbest is cheaper now, so buy there Smile
When I was buying banggood was under $20.
My reviews:
Zulumoose
Zulumoose's picture
Last seen: 13 hours 6 min ago
Just got the same one yesterday for a friend, tested it against a tape measure, 4.92m exactly on both across a room. Cost was $16 through Bilakos.
Beam me up!
klrman
klrman's picture
Got it from Bilakos too.  Couldn't resist that price.
Theodore41
Last seen: 2 days 11 hours ago
I have bought from UK the following meter,which I think it is very good. 65m 213ft Digital Laser Distance Meter Test Range Finder Measure CEM LDM-65,but I see that it is available from Singapore as well.
https://www.ebay.com/p/65m-213ft-Digital-Laser-Distance-Meter-Test-Range...
Enderman
Enderman's picture
Last seen: 37 min 35 sec ago
I use this one because I needed very long range.
https://www.banggood.com/UNI-T-UT393B-150M-Laser-Range-Finder-Distance-M...
There are cheaper models with less range and features.
Robowski
Robowski's picture
Thanks a lot guys. As some of you already own and recommend this one:
https://www.gearbest.com/laser-rangefinder-electronic-distance-meter/pp_...
I have just ordered it from Gearbest – it was US$20.24
That coupon code for $10 off only appears to work if you spend $50 or more.
Some of you mentioned Bilakos…
Is that another online store?
Pete7874
Pete7874's picture
Last seen: 5 min 18 sec ago
I have that one as well. The only time I found its readings somewhat innacurate is when measuring fairly short distances, like under 12 inches. But for such short distances you can just use a ruler. Smile
bilakos is a BLF member who often provides discount codes for various merchandise. Here is his thread: http://budgetlightforum.com/node/57247
Robowski
Robowski's picture
Pete7874 – thanks for that info – as you said, for short measurements a ruler or tape would be fine.
I will also keep a look out for Bilakos’ codes and deals in future.
