Brinyte MX01: 24.5-27mm adjustable Magnetic Gun Sight Scope Mount
Hi guys, today I want to introduce one of Brinyte’s most popular flashlight accessories to you, the MX01. It can be mounted or detached easily thanks to the magnet, also it can bear the recoil and won’t come off, which make it perfect for self defense shotgun or nighthunting.
Let’s check it out :wink:
Basic Specs
Hole Dia: 26.5mm (Suitable for—-Minimum size: 24.5mm/Maximum size: 27mm)
Trail Width: 50mm
Height: 11mm
Weight: 85/90g
Material: Aluminum
When will this be available and how much will it cost.
It looks nearly the same as the Olight mount.
What is the smallest diameter barrel/mag tube that this mount will fit?
+1
This can’t be mounted on optics ?
Hi MRsDNF, MX01 is already available. The price is $12.6.
Link?
The smallest diameter it fit for is 24.5mm.
Yes, it can. Just take care of the suitable diameter (24.5-27mm).
I’d suggest barrel mount only.
Minimum order amount is 20.
How when optics are mostly made from aluminum, and magnet won’t stick on aluminum ?
Why you don’t post your stuff on Ali Express ?
Thanks for your suggestion, MRsDNF. :innocent:
Yeah, also the material should be considered.
We have alibaba store, you can check some of our products on it. Here is the link: Shenzhen Yeguang Technology Co., Ltd. - Hunting Flashlight, Diving Flashlight
