Massive fraud on 18650s in the Littokala Aliexpress stores!
881 posts / 0 new
tatasal
Last seen: 5 min 27 sec ago
Are these Littokalas re-wrap Sanyo NCR18650GA’s?
https://www.aliexpress.com/item/100-Original-LiitoKala-Lii-35A-3-7V-3500...
Agro
Agro's picture
Last seen: 4 hours 1 min ago
In general there are various cells under Lii-35A wrappings.
If they say this one is GA – it should be GA.
Anthon
Last seen: 2 days 53 min ago
I bough from that store 4 Liitokala 3000mAh that were supposed to be LG HG2.
My lii500 shows that all the cells are around 3300mAh so they can’t be HG2.
tatasal
Ok, here’s another one:
A GA with different wrapper. Anybody has this ?
https://www.aliexpress.com/item/100pcs-lot-freight-free-SANYO-18650-3500mAh-NCR18650GA-high-power-battery-cell-10A-18650GA/32374140512.html?src=google&albch=search&acnt=479-062-3723&isdl=y&aff_short_key=UneMJZVf&albcp=266121556&albag=7593673036&slnk=&trgt=aud-165594907443:dsa-42862830006&plac=&crea=64152518716&netw=s&device=c&mtctp=b&memo1=1t2&aff_platform=google&gclid=EAIaIQobChMIyfObj8Oq2wIVRCUrCh0dwwluEAAYAiAAEgJUHvD_B
Edit: Same wrapper as Liion wholesale: https://liionwholesale.com/collections/batteries/products/panasonic-sany...
Persechini
Persechini's picture
I’ve made 2 orders from different stores. Both say on the listing that they are Sanyo GAs, but ones from one order looks like samsung 35E (recessed top, 3 prongs) and from other order looks like LG MJ1 (4 prongs). Both measured the correct capacity and seem to sustain the correct max current, but they for sure are NOT sanyos
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
matg
Last seen: 3 weeks 1 day ago
Im thinking about trying some out HG2’s or the 25r’s but using them for vaping. Now if these prove to be fake would I have issues with vaping if the max discharge is not sufficient?
WalkIntoTheLight
Last seen: 4 months 3 days ago
If you’re using a mod that isn’t current-regulated, then certainly. And even with a safer current-regulated mod, if the discharge is high, it could get you into trouble. I don’t mind pushing a battery near its limits in a flashlight, but I wouldn’t want to do it next to my face.
If you absolutely need a high-discharge cell where safety is a concern, buy it from a reputable dealer that you know isn’t going to give you fakes. If all you need is 5 amps or less, then even a fake is probably good enough.
I’ve had good luck with cells from China, but you never know. Sometimes it can be hard to spot fakes.
joechina
Last seen: 1 month 1 week ago
I have ordered six 30Q batteries from the Liitokala Factory Store at the 29th of May
Hope they are real. Has anybody received his ones?
manithree
Last seen: 12 hours 16 min ago
I ordered 6 30Qs from the Liitokala factory store on 17 May. Just got a message today that I think means the package was returned to the shipper as undeliverable, so they just shipped it again.
Meanwhile, the 30Qs I ordered from LiionWholesale at a much later date arrived yesterday. There might be a lesson there. Or not.
Nachtfeuerzeug
Nachtfeuerzeug's picture
Last seen: 1 month 2 days ago
I got the same message:
lin zhang: Hello, because your package was returned as undeliverable, give you change the other logistics today sent to you, in the 17th website can query. This is the new tracking number:
Is this going to happen?
EDC
FW3A, SST20 4000K || S21A, Crescendo MTNdd 20mm, LH351D 4000K || SP32A, SST40 5000K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | S21A, Crescendo 20mm, LH351D 4000K | L2 w/6A 20mm SST40 driver, XP-L HI | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | SK Zoomie Nichia 5000k, C2 driver | EagleTac clip | Ultrafire C2 w/5A 17mm & XM-L2 | Nichia 219C 2700K with gray S6 |
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3)
avani733
I got the same message from “Liitokala factory store”
Barkuti
Barkuti's picture
Last seen: 2 hours 37 min ago
I've had a couple AliExpress orders whose shipments were cancelled; this usually gets noticed in the order details page or the tracking information page a few days after the initial waiting for pickup notice.
Paying a minimum of attention to shipments' tracking information is a nice idea because, in my experience, sellers do not seem to report their cancelled shipments to users.
Cheers Party
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
WalkIntoTheLight
Sounds like the shipper they used will no longer accept lithium-ion cells. Does your new tracking number indicate a different shipper this time?
ZoomieFan
ZoomieFan's picture
What’s the max possible capacity for an 18650, 21700 and 26650.
Click here
The 9900 mAh 18650’s at $1/piece, are obviously a hoax.
But what about 4000 mAh 18650? Is that possible?
I’m looking for a few extra 18650’s, I currently use the black 3500 mAh Liikota cells, which were tested as very good by HJK on this forum. And yes I like them, but I’m always on the look for something better.
Chargers: 1xBasen BD01 5/5, 1x Gyrfalcon All-88 4/5, LiitoKala: 3x100 3/5, 2x202 3/5, 1x402 3/5., MiBoxer C4-12 3/5.
Flashlights: DQG Tiny III 26650 5/5, FiTorch MR35 3/5, Haikelite SC26 HD 3/5, Lumintop Tool AA/AAA 4/5, Nitecore LA10, Sofirn C01 BLF 3200k/5600k 2/5, Zebralight H600Fc 3/5.
Powerbanks: EasyAcc 26800 mAh 3/5, Xtar PB2 4/5, Xtar PB2S 5/5
Waiting for: (DQG Tiny) 21700 EDCs.
Nachtfeuerzeug
Approximately:
3500 mAh for 18650
5500 mAh for 26650
21700... (?) mAh somewhere in between above capacities.
EDC
Reviews:
BlueSwordM
BlueSwordM's picture
Last seen: 19 hours 28 min ago
As of June 2018, the highest capacity 18650 is 3600mAh.
Barkuti
Barkuti's picture
LG 18650 M36 3600mAh (Cyan) @ lygte-info.dk Not even 3200mAh minimum down to 2.8V between 0.5A and 1A.
By carefully following the discharge graph lines down to 2.5V, this cell meets 3200mAh minimum down to 2.5V.
BROODMASTER wrote:
3500 mAh for 18650
No.
Best high capacity cell (I believe and not by a lot) is Samsung INR18650-35E:
Quite well matched cells delivering above 3350mAh minimum down to 2.8V at 0.5A - 1A, and surely 3400mAh minimum if down to 2.5V.
Still no 3500.
Cheers Party
BlueSwordM
There is the Panasonic NCR18650G though:
https://lygte-info.dk/review/batteries2012/Keeppower%2018650%203600mAh%2...
Down to 2.5V, it could do 3500-3600mAh without a protection circuit.
If I had one, I could test it myself, but it does cost a LOT of money for a single 18650 cell.
The problem with the NCR18650G and all others 3600mAh legit cells is that they tend to have more internal resistance than their 3500mAh counterparts.
GreenLights
Last seen: 1 hour 28 min ago
Looks like I’m not the only one.
“Hello, because your package was returned as undeliverable, give you change the other logistics today sent to you, in the 17th website can query. This is the new tracking number:”
So I guess another 3 weeks minimum. Sad
Just discovered this wonderful addiction.
BlueSwordM
Damn it. They changed lithium ion shippers.
Barkuti
Barkuti's picture
If I had one, I could test it myself, but it does cost a LOT of money …
This cell would hit 3.4+Ah minimum down to 2.5V at 0.5A - 1A, even without the protection circuit burden (≈40mV at 1A), maybe 3.5Ah at 0.5A, but 0.5A is below the 0.2C official discharge current rating. Totally l00ks like a rewrapped Sanyo NCR18650GA (go check it out with the battery comparator).
Cheers Party
sesgum
sesgum's picture
Last seen: 2 weeks 2 days ago
Got the same returned and new tracking number message. The new one seems usps traceable
Nachtfeuerzeug
Finally! I had to look at a useless EKC (South Korea) website until now.
EDC
Reviews:
Barkuti
Barkuti's picture
Try tracking here: https://track24.net
Hope it is of any help. In eBay fake tracking numbers are usual.
Cheers Smile
GreenLights
In Track24 it tells me the estimated delivery dates are between July 6 and July 26. Hopefully it won’t be that long.
Newlumen
Newlumen's picture
Last seen: 2 months 10 hours ago
I bought 26650 battery from aliexpress before,,, normally take 15 days..
WalkIntoTheLight
I think mine from Ali took about 2.5 months. Very slow shipping, but at least it was free.
JackJax
JackJax's picture
Last seen: 7 months 2 weeks ago
Just got my six 30Q delivery. Ordered through the link in the OP. The batteries have the 4 legs to the positive post, not 3 as my other 30Q cells.
Going to test voltage, then drain and then charge in a VC4 to see about capacity. Will report back with more info.
Update: All six were at 3.62V
Barkuti
Barkuti's picture
I would no doubt open a dispute. I'd recommend choosing “product is not as described” or “counterfeit goods”. If you choose counterfeit goods and the seller doesn't cooperate you'll have to convince the AliExpress Case Management Team with proper evidence, at least like photo-comparing the cells with known good 30Q samples.
YMMV, though.
Cheers Smile
JackJax
JackJax's picture
