Review New Convoy C8+ Desert Tan: weird beam?
24 posts / 0 new
AnhTran
Last seen: 2 weeks 2 days ago
I received this new Convoy c8+ today after 3 weeks, bought it from Aliexpress Convoy store. This is basically an old C8 inside with different outside design and and new colour. The new design look much better than the old one in my opinion.
Specs from Convoy:
Reflector : Smooth
LED : CREE XPL HI
Battery : 18650 lithium battery (protected or unprotected), battery is not included
Diameter of head : 44.5mm
Length : 142mm
Diameter of body : 25.2mm
Weight : 145g
Led choices:
XPL HI V2-1A 6500-7000K
XPL HI U6-3A 5000-5200K
XPL HI U6-4C 4200-4500K
XPL HI U4-7A 3000-3300k
This light use 8*7135 driver with 12 mode groups.
AR coated lens
New knurling is more aggressive than the old convoy C8
Improved tailcap design, maybe less stable tail standing but easier to press.
Same smooth reflectors
Compared with other Convoys
Beam shots
This flashlight produces a beam with a visible dark spot in the middle at close range. I dont have any other big smooth refelector with XPL-HI flashlight so i’m not sure if this beam pattern in close range is normal, but i couldn’t find any defective in this light. Please let me know your opinions about this problem.
Thanks
Edited by: AnhTran on 05/31/2018 - 07:29
Calaveras
Last seen: 6 hours 59 min ago
I was using a c8 XPL-hi today, it does not have that donut.
freeme
freeme's picture
Last seen: 9 min 55 sec ago
Donut more or less diminished at the stated distances.
desmondkun
desmondkun's picture
Last seen: 34 min 55 sec ago
Facepalm
Take care of your flashlight and your flashlight will take care of you.
-X3-
-X3-'s picture
Last seen: 9 hours 3 min ago
Throwers make a donut at short range when properly focused.
So what you think is a failure MIGHT be a good sign.
Does the donut disappear at, let’s say, 2 meters ?
"Hey -X3-, do you have a flashlight ?"   "-X3-, can I borrow one of your flashlights ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
raccoon city
raccoon city's picture
Last seen: 1 hour 36 min ago
freeme wrote:
So the emitter is 4cm away from the bezel?
Right...
freeme
freeme's picture
About 3.6-3.7cm after second glance. Didn't remove the reflector, just laid my ruler and gauge with my eyes.
Right...
raccoon city
Oops!
That does make sense.  :THUMBS-UP:
Please excuse my earlier sarcastic remark.
uranus
Last seen: 1 week 2 days ago
My C8+ arrived yesterday.
The light has a very nice curling and head Design.
And…..yes! IT hast a donuthole on a distance at 80cm.
BUT: This is a thrower with an HI LED, i think nobody is using this light on a 80cm distance!
The SS bezel looks great on this light. Later i make a picture with this.
Best wishes
Steve- from Germany- with a bad english xD
wolfey
Last seen: 6 months 5 days ago
That’s a nice looking flashlight right there. Now I want one. Not sure if I should get this new c8 or the emisar d1 ive been wanting also
AnhTran
This is my first flashlight with Xpl-hi and big smooth reflector, so i’m just not sure this donut beam is normal, I have a convoy s2 with xpl-hi and smooth reflector, it doesn’t have this donut beam, and hotspot is even. This C8+ donut beam does disappear at longer than 1m range but the hotspot is not even as of the s2. Anyway this light is supposed to be used at long range and it is very good at this
d_t_a
Last seen: 15 hours 26 min ago
I don’t have the Convoy C8+, but regarding XP-L Hi and donut holes… I’d like to mention on my Astrolux S2, by default with the LED plastic centering ring installed, it will produce a donut hole shape (when at closer ranges); but if I remove the plastic centering ring, the donut hole then disappears (or becomes more faint). Not sure if the same might happen on the C8+.
I’ll try to take some pictures when I have time..
AnhTran
This is exactly what i thought because i noticed the led in c8+ is deeper under the reflector than in my convoy S2, but i didn’t tried to remove the centering gasket. After your comment, I tried to remove the gasket, and guess what, NO MORE DONUT BEAM!! and the hotspot is more even, and a little more thow (i guess). Thanks for your suggestion Thumbs UpBeer
djozz
djozz's picture
Last seen: 2 min 12 sec ago
In my C8 with dedomed XP-G2, should not behave much different from a XP-L Hi, the donut hole is completely gone at 50cm, the hotspot is nice an smooth then.
Small video:
pennzy
pennzy's picture
Last seen: 4 hours 45 min ago
Minus the centering ring , are you risking a short?
AnhTran
I tried and no short happen. And if it did not happen at first, there is no more risk because both the pcb and reflector are tight and secure.
Small video:
very nice demonstration video, you can try to remove the centering gasket to eliminate the donut beam and get a more even hotspot
Pete7874
Pete7874's picture
Last seen: 4 hours 35 min ago
My C8 XPL HI has a donut hole at very short distances. Not donut hole visible once you’re 50cm or more from the wall.
Zulumoose
Zulumoose's picture
Last seen: 5 min 40 sec ago
Just curious, is there a middle ground perhaps where the centering ring can be shaved enough to remove the hole but still function as intended?
Beam me up!
AnhTran
i think we can sand it to the right thickness, i will try and update the result
djozz
djozz's picture
No no no. The hole should be there at short distances, the beam has not formed yet, you actually see the hole in the reflector where the led sits. My C8 from the video has a perfectly focussed led.
d_t_a
Glad to know that trick helps on your Convoy C8+
To be frank, I discovered the above (effect of LED centering ring) accidentally.
I had my original Astrolux S2, showed it to an acquaintance who also wanted one and I ordered for him. When I tested the new Astrolux S2 and my older Astrolux S2, I noticed that my Astrolux S2 didn’t have a donut hole, whereas the new Astrolux S2 has a donut hole (at short distances).
I was wondering what’s the difference between the old and the new Astrolux S2 — and on closer inspection, that’s when I noticed that my original S2 does NOT have a centering ring on it, whereas the new one has the centering ring (causing the donut hole).
If I had known my original S2 was missing a LED centering ring I would have complained to Banggood about the missing part, but that’s already been several months ago). Anyway, I have been using my Astrolux S2 (with the missing centering ring) for some time now, and have not experienced anything out of the ordinary — hoping there wouldn’t be a risk for it to get a short?
BlueSwordM
BlueSwordM's picture
Last seen: 39 sec ago
The donut beam is just normal.
tatasal
Last seen: 1 min 37 sec ago
Does anyone know the lux reading of this new variant?
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 12 hours 55 min ago
If the light has proper focus it should have a donut hole close up. All reflector thrower suffer this issue.
