LG 18650 HA4 1300mAh (Purple)
Official specifications:
Nominal capacity: 1300mAh
Nominal voltage: 3.70V
Discharge cut-off voltage: 2.75V
Standard charge current: 0.75A
Maximum charge current: 4.0A
Maximum discharge current: 30A
Peak discharge current (4sec): 52.5A
A high current low capacity tool battery.
The discharge curves are very good, then match nearly perfectly and capacity do not vary much with load, even at 30A
Conclusion
With the low capacity is is probably a fairly old generation of tool cells, but high current performance is very good
Notes and links
Vapcell told me that I was missing some cells in my comparator and they would be happy to supply them.
Compare to 18650 and other batteries
