Designed for urban cycling commuting, C01 is a versatile rechargeable bicycle headlight. By adopting the anti-glare multi-faceted reflector, it produces an equal ray, takes care of near and distance illuminations. At the same time, it prevents dazzle to the oncoming people and vehicles. Utilizes Cree XP-G3 LED with neutral white color, it has better penetrability, even in rainy and foggy weathers. Three general output levels plus Strobe, SOS, and Beacon with a max output of 400 lumens, it meets the commuting and daily lighting demands. The built-in 1,400mAh high-capacity lithium polymer battery provides a maximum runtime of up to 10.5 hours which meets long-distance cycling requirements. Micro USB direct charging function allows you to charge the light at any time to ensure a sufficient power of your ride. Charging indicator, low-power warning, quick-release structure, IPX-8 waterproof design etc., C01 is your reliable partner in daily commuting, road riding, or in daily use.
The UI is simple, one click for ON, then another click for mode change (have memory), long press 1s for OFF (at any mode).
When ON, press and hold 4s for Strobe, then another click to change to SOS, Beacon.
Hi, the battery capacity is decided and limited by the light size, the max 10.5 hours on low is enought for a single city ride, what’s more, it’s rechargeable.
I was looking for a couple lights for the kids bikes. We live in a very dark area in the middle of nowhere and this would do them just fine. They could bring it in every night and charge it for the next time. I will be picking up a couple when they are available. Depending on price of course.
