Brinyte: What did you do to your B158?
25 posts / 0 new
Brinyte2018
We’ve learned that many friends like to mod flashlight for better use experience. As a classic member of Brinyte, B158 becomes one of the favourite lights for modders. How did you mod it and what’s it like eventually? Post here to show your work Wink
Edited by: Brinyte2018 on 06/05/2018 - 03:18
Lightbringer
Lightbringer's picture
Last seen: 9 hours 41 min ago
I don’t have a B158 yet, but if I did, I would like to pimp it up but good!
My birfday’s coming up, so… Big Smile
yasenf
Last seen: 2 min 51 sec ago
Not a modder, but I have Brinyte B158B with some mods:
1. Change of forward clicky with omten switch – it is a pain to program a driver with forward clicky. Would be very helpful if you offer such a switch and rubber cap.
2. Bypassed springs
3. Pill with SSt40 and 9A Led4Power driver
4. Pill with dedomed XP-G2 and BLF DD driver. If I measured correctly, this is my smallest light with 260k candela
If you care you might offer bigger head, will be interesting. Also the washer, that covers the MCPCB better be black I think.
gchart
gchart's picture
Last seen: 16 min 24 sec ago
I do love my B158’s. My usual mods include:
  • Replace the cool-white LED with a neutral tint (around 4500K) Cree XP-L HI
  • Replace the floating 2.8 amp driver board with a MtnE FET+1 driver that is soldered directly to the pressure-fit ring.
  • Bypass the spring in the tail cap. This spring is really long, which adds too much electrical resistance.
  • When I have the time, I like to add a PD68-style illuminated tailcap.
Brinyte2018
2. Bypassed springs
Thumbs UpThumbs Up How does the final work look like? We are expecting LOL
Brinyte2018
!{width:100%}https://drive.google.com/uc?id=0BxFO0UNp0BswMVhJUHFneGRDUTh1eFZuUFoyWUtG...!
Good job, gchart! The sapphire tail switch is beautiful. Like it Love
ZozzV6
ZozzV6's picture
Last seen: 11 min 22 sec ago
Ireplaced the driver with a FET triple channel TA driver and replaced the led with a dedomed XP-G2 S4 2B on DTP copper MCPCB. Painted the led surrounding area with blackboard paint to reduce artifacts and rings in beam when zoomed in.
My measurements:
Current: 4,65A
Output: 693 lumens
Intensity: 325000 cd
Throw: 1140m
This is the beam reflected from the river surface:
-X3-
-X3-'s picture
Last seen: 1 hour 20 min ago
Mine has no driver anymore, direct drive for short bursts (and I monitor my battery from time to time).
Xp-L HD dedomed, blackened centering ring.
It pierces the night quite well now !
Left : B158, Right : C8 FET driver with XP-L HI
"-X3-, is there any place in your house without a flashlight ?"
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
gchart
gchart's picture
I have some Luminus SST-20 en route. I might try dedoming/slicing one of those and then seeing what it’ll do. Should be intense (ok, pun intended)
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 3 hours 39 min ago
Mine is a similiar set up to you all. Dedomed XPG2 S3 1A with a BLF A6 driver and spring bypass and i used a sharpie to darken the centering ring. I might spray paint the centering ring.
I like it but i think i prefer the dedomed XML2 it throws almost as good. Plus my Cometa modded the same appears to throw further?.
BobbyMK
BobbyMK's picture
Last seen: 31 min 59 sec ago
Not much variety with this one.
Mine is almost the same as every other one here.
First gen B158
Cree XP-G2 S4 2B dedomed
BLF A6 Fet +1 driver
Reverse clicky switch
Slightly over 300 000 cd.
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
djozz
djozz's picture
Last seen: 10 min 46 sec ago
Slight variation on the same theme: dedomed XP-G2 S4 3D with FET-converted Nanjg AK47-1C driver. 320kcd.
!{width:80%}https://farm2.staticflickr.com/1743/41721485345_abfbe50cac_b.jpg!
Hey mate what did you use to paint the LED?
djozz
djozz's picture
I sanded the plastic a bit and then simply used a sharpie. For metal versions (which are in the Uniquefire aspherics) I have used flat black engine paint.
I used the same method on mine and doesn’t looks like that but i didn’t sand it lol. Ill try sanding it see if it helps.
Thanks!
dhvl1357
Last seen: 6 days 22 hours ago
Have been considering a B158 for a while now. How many Cd is the stock XPL-HI version? Asking because I can’t mod and would love a single 18650 light sabre to pierce through bushes and buildings and light up something/someone far away.
Slow is smooth; smooth is fast.
ZozzV6
ZozzV6's picture
Stock is 717 lumens and 113 kcd
dhvl1357
Ahh, literally 1/3 of what y’all have modded to. Oh well…
Thanks, ZozzV6!
luminarium iaculator
luminarium iaculator's picture
Last seen: 13 hours 51 min ago
Everything in following post is based on my experience so I speak in my name and IMHO…
So you are Brinyte representative?
The question should be What Brinyte did to improve B158 light?
The only thing you improved on that light is removing of chunky and totally unnecessary hunk from B158B, and that did not passed without drama. At first you refused such suggestions from respective members here. But finally the guy from your sister company “Odepro” which understood English language very well and follows BLF posts decided to sell B158 without hunchbacks at much higher prices than usual. Maybe you are that guy?
Brinyte tends to listen only one communist orientated boss which punishes their workers for some no big deal “mistakes” (don’t ask me how I know that). Workers are OK but that boss is pita for company.
B158 is just an average light and needs some major improvements like:
- reverse clicky omten switch (switch redesign could lower size and upgrade light performance)
- double and thicker oring to neck section or any exposed section (it is not that waterproof as you saying no matter for some online reviews)
- pill perfectly adopted to 17mm drivers and mcpcb’s which will allow easier driver/mcpcb swapp
- Smaller or larger heads? Where are they?
But what is incredible and no other OEM flashlight manufacturer except Brinyte figured out is that cheap acrylic lenses can be better and more consistent (almost 100% of consistency at around 95% of light transmittance) than any commercial available ones. So plus for you here Thumbs Up
So I am just curious how Copyfire (Uniquefire) did not figured that out and made their own version of UF158 light. So far they they not only manage to copy certain lights but they also improved them (seriously).
Dear Brinyte if you don’t want to work on improving your light and make it more user friendly it is just matter of time until some of your rival companies reveal all mentioned above and start manufacturing their own better versions.
Similar destiny happened to Dereelight (anyone remember them?), Tiablo, Crelant, Wolf Eyes. Uniquefire grew on their ideas… They just copy-pasted, lowered the prices and made even better products then them. They have boss who is listening, researching and improving things… All that could not be said for your boss dear Brinyte.
Modding is making something how you want it to be, not how it comes stock...
Old-Lumens
gchart
gchart's picture
I too am glad to have seen the B158B version come out with the “lugs” of the B158. Regarding improvements, I agree with part of what LI said. Specifically, I’d like to see:
  • Stop using thermal adhesive to affix the LEDs in place. I hate scraping and cleaning that stuff up.
  • It would be nice if the LED shelf could properly hold a 20mm MCPCB, even better if had tapped holes for screws
  • The floating driver and press-fit ring is a pain in the butt. Just make the opening the right size for the driver. Solder the driver directly to the pill or something
  • Changing out the switch for a reverse clicky probably isn’t a bad idea, though not a deal breaker
  • Modify the spring setup in the tailcap – it’s way too long
emarkd
emarkd's picture
Last seen: 21 min 47 sec ago
So mine may be a bit different than most. Its got a 5.4 amp qlite with guppydrv, driving a Nichia 319a SW503 D400. “Only” 83kcd, 577 meters throw, which is probably quite a bit less than an XP-G2 or XP-L HI build, but I really like the hex-shaped beam better than the usual square.
MascaratumB
MascaratumB's picture
Last seen: 10 hours 25 min ago
With what do you guys paint that thing in black? I have a similar light, and wanted to reduce the artifacts… Thanks and sorry for the off-topic Silly
REVIEWS: AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// SOFIRN: SF14 & SP10A / SP32A / SP10B /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B018 /// ACEBEAM: H20 /// BLITZWOLF: BlitzWolf BW-ET1 /// DQG: AA Slim Ti /// HC-LIGHTS: SS AAA /// XTAR: PB2 Charger /// OLIGHT: M2R Warrior /// WUBEN: TO10R / E05 / T70 /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 & A5R / E300S ///
 Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7   TIR Lenses: 1 / 2   Others: Biscotti 3 & 1*7135     Triple TIR & XP-G2
 MY GIVEAWAY (FW3A)
emarkd
emarkd's picture
Mine up there is painted with flat black high-temp engine enamel. Its in a spray can, but I sprayed it in a plastic cup and brushed it on. It does a great job reducing the artifacts, but its still not perfect.
MascaratumB
Quite cool, though, emarkd! It may not be “perfcet” but I’m sure it will reduce the artifacts if compared with the white “gaskets” these lights bring! Thanks for the tip/answer, gonna see if I see that around here!! Thumbs Up
 MY GIVEAWAY (FW3A)
LumenHound
LumenHound's picture
Last seen: 18 hours 5 min ago
I picked up mine when they first became available.
I replaced the driver with a Mtn fet plus single 7135 loaded with the BLF A6 firmware and the driver spring bypassed.
Replaced the led with a XP-L HI V2 3B on Noctigon also from Mountain.
Switch was replaced with a 1288 reverse clickie/tail spring pypassed and I used flat black hi heat gas barbeque paint on the white retaining ring.
I still need to raise the pill with a thin slice of copper water pipe to give a wider full flood.
