Haiklite MT09R GB replacement drivers
107 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 15 hours 46 min ago
I do remember that row of resistors.
I have spoken with TA before and I had asked if the driver was FET+Nxlinear regulator for regulation.
He said no, and he said that he is instead using a resistor array for current regulation at low modes.
KawiBoy1428
KawiBoy1428's picture
Last seen: 15 min 7 sec ago
Now that is whack…….If that spring bypass wire breaks off will it touch ground….could get interesting…
On the driver spring my by- pass wire is always inside the spring, kind of like being contained with in the spring…
KB1428 “Live Life WOT
Texas_Ace
Texas_Ace's picture
Last seen: 18 hours 58 min ago
JasonWW wrote:
Texas_Ace wrote:
JasonWW wrote:
hIKARInoob wrote:
Yeah but there’s nothing I can see on the driver that says the driver is for the 70 version.
At the expense of possibly looking like a fool, is it possible the drivers are interchangeable with the emitters determining the amp draw/load?
One is 12v, one is 6 volt and the MCU is 3v so I assume you have to use a different voltage divider between the 2 drivers.
The drivers are the same design, the only changes are some of the components to work correctly with the voltage change.
Hot damn, I’m not such a fool after all! Lol
What’s funny is I don’t think I’ve ever seen this MT09R driver until now. I don’t remember the row of resistors. TA, did you specifically not show any pictures of it in your driver replacement thread? Maybe I just forgot seeing a picture of it.
You are not a fool at all. You made a good educated guess.
You are also correct, I never posted any pictures of the drivers so it would not be stolen. It took me months and several prototypes and a ton of testing to get this design stable. In one case moving a component a few MM was enough to make it significantly more stable. Along with a few other equally minor but very important changes.
This driver really changed how I look at building drivers in general, even the smallest details start to matter when messing with these kinds of currents. I was very surprised at the effects some of the changes had but the results are worth it, I have not heard of any issues with the almost 100 final versions of this driver that are floating around.
Once I have time to put together a final version of the driver for release on oshpark I will upload it for personal use of course. Just got several other projects in the fire that are more important right now.
Texas_Ace
Texas_Ace's picture
Yeah, I was worried about this. I even sent them some sample drivers should good bypasses but it seems that was ignored. This is the first I have seen of it. They have not sent me any samples even though I have asked.
Texas_Ace
Texas_Ace's picture
Indeed, I never hid what I was doing, just exactly how I did it. The smallest details proved key to making it work stable under extreme conditions.
smokuxx1987
smokuxx1987's picture
Last seen: 1 day 12 hours ago
This one is not bad, one is worst.
BlueSwordM
I do wonder why they are still using steel springs instead of phosphor bronze or beryllium copper for the main spring, and make it even thicker since it screws down on a battery tube and not bare cells.
Would avoid such bad solder jobs.
leaftye
Last seen: 1 week 6 days ago
Unfortunately many of my spring bypasses look like that. It takes me a few tries before I get one without solder sucked all the way up the wire and making it look like those. That’s not an excuse though. They should have practiced. At least folks with patience or good soldering skills can fix that.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
Texas_Ace
Texas_Ace's picture
Yeah, that type of bypass works, for awhile anyways. I find that wrapping the wire “around” the spring so that it does not flex as much when the spring is compressed lasts orders of magnitude longer. I have yet to have one break on me doing it that way but had most of my old ones like this break over time.
luckily they never hurt anything when they broke, they just stopped being bypasses and the output dropped.
sherman2k
I am still waiting for my replacement driver for almost a month now. To the member that received the replacement driver, how long did you wait for your replacement driver?
BlueSwordM
Your driver should come very soon.
I was waiting for my Haikelite MT01 driver and reflector, and they came today!
I had emailed him, and he said the reason for the drivers taking time to be shipped, is that he was waiting to ship every spare part from almost every Haikelite light, the MT01, MT07S, MT03, etc, for lower cost shipping.
This is why it’s taking time.
sherman2k
Thank you
smokuxx1987
I was waiting since Group Buy was over.
I buy 3 pcs new MT09R and Dale send drivers with it by DHL.
Probably they will send drivers by normal shipping method registred/unregistred so to europe it takes 3-4 weeks
pooptoast
pooptoast's picture
Last seen: 1 week 16 hours ago
I’ve emailed multiple times about a replacement driver for mine but I’m not getting any response. I’ve given up on my light though at this point so if it comes, it comes, if not whatever, this thing will just sit in the bottom of a drawer somewhere.
BlueSwordM
Don’t give up.
He is extremely busy.
He only responded to me when the drivers were in my city in tracking.
He has a lot of work on his hands, and probably 100+ emails to respond to.
sherman2k
On one post on this thread since 7/8/2018. I understand Dale is extremely busy but how about some customer service for the members that purchase the light in first GB with the trust of the company.
sherman2k
Bump
Nicolicous
Nicolicous's picture
Last seen: 40 min 58 sec ago
Its been two months when he emailed the driver got shipped but still no show up Sad
Nico -.-
sherman2k
I am going to continue bumping this thread until someone responds.
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 13 hours 8 min ago
Yes, for the GroupBuy, he told me a shipping number and said he has shipped it before CNY, but it was shipped very late after CNY. So dont trust his words at all. I think he will ship at least yours.
I have no answer depending the driver.
sherman2k
bump
Itsme
Last seen: 1 month 1 week ago
I haven’t heard from Dale in a long time in regards to my replacements. Hope they show up at some point as he did originally tell me that they would be shipped
Nicolicous
we want our drivers Beer
Nico -.-
sherman2k
bump
sherman2k
bump
mortuus
mortuus's picture
Last seen: 11 hours 29 min ago
sherman2k wrote:
bump
what will bump help `?
...where Frugal meets with Flashlight!
sherman2k
So this thread will not disappear. Hopefully, more people in the first GB will express their concern. I am sure I am not the only one.
vinte77
Last seen: 2 days 12 hours ago
Well it’s been about 2 months for me since I was told my driver was sent out. So as long as you were told that you would be receiving a driver, the only thing you can do is wait. But if you never go in touch with HL to request a new driver, you need to reach out to HL and request one… Then wait.
mortuus
mortuus's picture
Ah ok, i guess the only way is to mail HL and bug them to send out the drivers, or that Dale guy but he seems to not write much here about it ?
Or they just dont care for those few that needs drivers – same i read with the BLF GT a few members are left with a broken light and the company refuses to fix the issues for a few members.. maybe its same here? who knows either way its wrong and not a way to treat customers for sure.. 2 months or more is a forever wait sorry but seems they just moved on the drivers should have long reached u all…
sherman2k
I did 2 months ago and during the 2 months, I only emailed them about 3 times. I was patiently waiting but when I email them again I don’t get any response anymore. I don’t think that is acceptable customer service. What is the acceptable wait time for you?
