(prototype) the GT Mini
1637 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 4 hours 8 min ago
wolfstyle wrote:
After three weeks I finally got my Mini GT NW today. Light looks great however there is an issue with it. When in turbo or top of ramp and double click to turbo the beam changes from NW to CW with a purple corona and then smoke starts swirling inside the reflector. Obviously this isnt’t right. I bought from the Group buy here on BLF. Not sure who to contact.
It sounds like the led is overloading/overheating due to bad soldering to mcpcb. One other person reported the same. I would contact Neal or M4D M4X.
Click this to go to signature links.
Newlumen
Newlumen's picture
Last seen: 1 week 5 days ago
I got my mini gt today. Yay.. both mini gt cw and d1s cw measured the same lumen… so both are equally good or the same.
Newlumen
Newlumen's picture
This might be useful to buyers from united states.. i recorded banggood shipping time.. all free standard shipping. I counted the days when they start shipped.
Flashlights 10 days
Flashlights 11 days
Flashlights 9 days
Flashlights. 14 days ( wild fires delay ? )
Flashlights. 11 days
teacher
teacher's picture
Wonders never cease!!
Mini GT was……..
  • Ordered & Paid for 9 July 2018.
  • Shipped 2 August 2018
  • Delivered today, 27 August 2018
An impressive little light to say the least….. Thumbs Up
MRsDNF
MRsDNF's picture
Last seen: 2 days 3 hours ago
Possibly the led has not been flowed onto the MCPCB correctly.
Newlumen
Newlumen's picture
Mini GT was……..
  • Delivered 27 August 2018
25 days ? Thats hella long.. atleast mini gt get there safely…
teacher
teacher's picture
Yep… there are several of us that bought these through the Pre Buy/Group Buy/whatever it was………. that the shipping time sucked. Big Smile
No complaint… just fact. It appears that group of packages either was truly on a slo boat or just sat around somewhere for a couple of weeks with no movement.
But… such is life (and shipping from China). Big Smile Big Smile
At least it arrived in one piece & working. Wink
JasonWW
JasonWW's picture
That is what I’m saying. When it goes to turbo, the heat can not get to the mcpcb fast enough.
nkresho
nkresho's picture
Last seen: 18 hours 20 min ago
Got mine today as well. Played around with a charged 30q when I got it. No smoke or unfocused reflector (that sounds horrible, sorry man). It looked great on the wall.
After the included 30q was all charged up I stuck it in my sphere. Only got 1,101 lumens at startup and 1,049 at 30 seconds. Mine is the NW variant.
I did notice the light seems to be made to accept protected cells as the 30q is not as tight end-to-end as other 18650 lights. Springs are not compressed without load, just not as long as I expected.
I may bypass the driver spring to see if it helps.
I’m not really let down too much, as i’m getting 88% of rated output. I’d be happier within 10% though. I’ll try a few other 30q and maybe a vtc5a to see what it might be.
It’s pulling 5.32amps, at start, in turbo.
I did get 134,524 candela at 20’ measured with the same battery fresh off the charger, which is right on par with the claimed 135k (within 1%).
JasonWW
JasonWW's picture
What sphere are you using? Obviously they can vary the output readings.
If your measuring 135kcd from a NW, you have the most powerful NW yet. It kind of suggests your sphere readings are low.
Is the 5.3A at startup? It’s better to measure at 30 seconds or sooner if it stabilizes. Maybe you can squeeze a bit more output with a driver spring bypass.
Newlumen
Newlumen's picture
I measured 1390 lumen @ 10 seconds.. TA tube. Cool white. Sony vtc6.. jason, is that too high??
JasonWW
JasonWW's picture
Are you asking me to compare my TA Lumen Tube to yours? Do you suspect your tube is reading a bit high?
I adjusted my TA Tube to make it read consistently to my Maukka calibration light. I had to reduce my output by more than 32%. I had to reduce it by 39%.
Your lumen reading is about 12% higher than mine (well within tolerance of the stock TA Tube). It would be best to also compare the amp draws and the candela. If your also drawing 5.5A and had 148kcd, then your tube might be reading a bit high (compared to mine).
If your drawing 6A and get 155kcd, then your lumen numbers might be about the same as mine, your just getting higher output from the light.
I see you just ordered a calibration light from Maukka. Have you received it yet?
Newlumen
Newlumen's picture
I do not believe my tube is reading high, as I have not tampered with it.. two fenix lights measured 960 and 1027 lumen for the stock 1000 rated..
I am just curious what you guys getting.. I ordered maukka calibrated lights and should be here soon.
I do not know how to measured amp draws nor have a device to do it.
JasonWW
JasonWW's picture
This is very easy to do. Most folks on the forum prefer using the Uni-T UT210E meter. There was a group buy as well as coupons a while back. It’s usually around 30 bucks. You can take off a lights tail cap and connect the battery with a loop of wire to the battery tube. Then clamp the meter to the wire. The light works normally and you can measure the amperage. This is how you would estimate output if you didn’t have an integrating sphere.
M4D M4X
M4D M4X's picture
Last seen: 28 min 46 sec ago
wolfstyle wrote:
After three weeks I finally got my Mini GT NW today. Light looks great however there is an issue with it. When in turbo or top of ramp and double click to turbo the beam changes from NW to CW with a purple corona and then smoke starts swirling inside the reflector. Obviously this isnt't right. I bought from the Group buy here on BLF. Not sure who to contact.
Neal is the seller Wink
I made a new email: CS@m4dm4x.com
that is redirected to Neal and a copy reaches me
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
d_t_a
Last seen: 1 day 12 hours ago
I have just experienced that kind of behavior from a Sofirn C8T: in low and medium mode, the tint is NW, when set to Highest brightness mode, the tint changes to cool-bluish tint, and there’s smoke swirling inside the reflector… I reported the issue to Sofirn and sent a lot of pictures (even asked me to put more thermal paste beneath the LED board, which I did, but it didn’t solve the problem.) Fortunately, Sofirn send me a replacement LED+board, which I’ve installed on the Sofirn C8T, and now it works properly (no tint shift when changing from medium-to-high modes and no “smoke swirl” in High mode.
I think the issue is the LED is not ‘baked’ properly into the LED board (which I don’t know nor have the equipment and skills to correct that), so the LED gets hot and becomes bluish (purplish in your case) — at least that’s how I understand the issue to be..
djozz
djozz's picture
Last seen: 8 min 50 sec ago
@Wolfstyle:
When opening the bezel of my GT (in the process of checking a faulty driver switch) the led was sheared off the board by transfer of the twisting action to the reflector and centerpiece. This may or may not be related to what happened to you. Shearing off a led has not happened to me before so it could be that Lumintops reflows are on the edge of not hot enough or too little flux, resulting in insufficient solder joints that apart from being weak may also not transfer the heat well enough.
nkresho
nkresho's picture
Mine is a 17“round sphere, calibrated using maukka lights, using a drmeter. It’s got two baffles preventing direct exposure on the meter’s sensor. Using an HS1010a at 20’ for the candlela.
Same exact measuring setup reads 2008 start lumens (1886 at 30s) on the catapult v6, with 174kcd.
Also took a hotspot pic at 4 feet. Both on low settings. GT mini is NW, v6 is CW.
Blf gt mini vs catapult v6 hotspot
The gt is a good deal smaller. Measuring on the wall, I got about 3” on the mini and about 4.5” on the v6.
Just tested the mini again with vtc5a, and got 1057 at start and 1013 at 30s.
Here’s a few pics of my sphere, for reference:
New sphere
edit: just bypassed the driver spring with 20ga and got 1195 at start and 1081 at 30s. Also stretched the spring out a little and about 2 coils had been soldered together at the board side. Spring popped right out and gave about 7mm of height, compared to about 4mm out of the box.
KawiBoy1428
KawiBoy1428's picture
Last seen: 1 hour 38 min ago
djozz wrote:
@Wolfstyle:
The Decapitator centering ring will find your weak reflow’s….right click on pic, view image, + to enlarge…nice rotational scissor action going on…. Big Smile Never like that style of centering ring. Angry
KB1428 “Live Life WOT
Brainsick67
Brainsick67's picture
Last seen: 2 months 1 day ago
Sorry to hear about the smoke problem..thats the second person to have that happen..hope you get it fixed.
I'm ThatCrazyFlashaholic 67
Brainsick67
I did get mine delivered yesterday..FINALLY..Heres my unboxing video
https://m.youtube.com/watch?v=I8LegEqA08g
wolfstyle
Last seen: 50 min 51 sec ago
Email sent to address. Thanks
Delta_V
Last seen: 1 day 2 hours ago
Still nothing for me Facepalm
Now USPS has removed the estimated delivery date completely, and the last update is still from the 22nd when it was processed in New York.
DB Custom
DB Custom's picture
Last seen: 2 hours 4 min ago
nkresho, wondering about how you figure your lux reading… if you do it at 20’ what is the math on that? I ask because I was told to use EXACTLY 5M (or 10M or 15M or more, I’ve done up to 50M), then multiply the meter reading by 5 squared (25) to get the lux reading. So if it’s a multiplier of the distance squared, what do you use as a multiplier x meter reading? (just checking to see how you derived that lux number) 5M of course is 16.4’. It would help if we all used a standard distance, but of course throwers actually need some space to get the beam focused properly if they’re any good at being throwers, so a 5M reading may be cutting the lux short.
nkresho
nkresho's picture
Using this in excel: =(0.09290304*T22*20*20)
with T22 being the cell with the lux reading.
Meter is in a dark room, in my basement, on a black metal cabinet. Meter reads 0 at test start, with ambient light.
Measurement is 20’, via tape measure to a fixed point on the ceiling, with a thumbtack and a long rubber band hanging to where I hold the light.
I test for 30 seconds and have the meter set to display the max number (this might be where i’m off). Reading peak rather than the 30s number.
I measured my GT (bone stock) at 30’, and used =(0.09290304*S21*30*30) for that one. I got 1.151M candela in that instance.
DB Custom
DB Custom's picture
What is the 0.09290304 number? Not sure why the two lights, at different distances and power levels, would have a same multiplier…
Ok, say you’re at 16’ 4.8” distance (5M) and you shine a light at the meter which reads 10,000. You’d multiply 10,000 × 25 for 250,000 as a lux reading (250Kcd) and then take the square root of 250,000×4 for throw. (1000M throw)
Another light, weaker, shows 767 on the meter set at 10x, so 7670 × 25 = 191.75Kcd. Taking the square root of 191,750 × 4 you’d get 875.79M throw for this one. See? nowhere is there a same multiplier except for the distance squared (5M squared is 25)
I don’t know all this part well enough to understand why we’d have a different formula, which is why I’m asking. Wink Trying to discover how we all get on the same page.
LightUpTheDark
Last seen: 2 weeks 5 days ago
Woohoo!! Got mine in the mail last night just in time for some night work on a movable bridge. This GT-Mini is tiny… smaller in hand than expected. Slightly shorter than my Nitecore P30 (by 0.5 inches/12mm) but the head/bezel diameter is nearly the same…I put them face to face… but the head size of the GT Mini is smaller than the P30. Just got to get used to the side switch on this little bad boy (I’m used to the dual-switch on the P30- Tail for on/off with tactical momentary-on and side switch for mode/levels).
Most likely mentioned before but UI is similar or same as BLF Q8.
The only bad thing I have to say about it is that this is a minor dimple in the reflector 10:30 o’clock position (looking at LED with switch at 12 o’clock position) about halfway in between lens/bezel and LED. It doesn’t affect the output or quality of the beam but it is a minor defect. It is very noticeable because the rest of the reflector is near perfectly smooth (the lateral machine lines on the Nitecore P30 are way more noticeable). It sticks out like a sore thumb.
Is there a way to request a replacement reflector?
I’ll figure out a way to post a pic.
I’ve got a thrower, a flooder, and an EDC too. Still looking for a bigger thrower, flooder, and a new EDC, give or take a few. I’m a flashaholic.
JasonWW
JasonWW's picture
New sphere
I wish I could see your pictures, but they are not showing up. Your sphere sounds a lot like the ones from Josh K. Is that what you have or is it just similar to it? Not the same at all.
Keep in mind that the Catapult V6 uses an xhp35 Hi which is a bigger LED than xpl Hi.
JasonWW
JasonWW's picture
I’m guessing the 0.09290304 number is about converting feet to meters. Candela is always meters.
By far the easiest way to measure it is try to find 10 meters in your house. It doesn’t need to be completely dark or anything. Just subtract whatever the ambient light is from your total reading. I typically set my light down so that the emitter (not lens) is at the 10 meter mark from the sensor (meaning 1” from the wall). Then I turn on the light and walk over to the opposite wall and try to find the area of the hotspot that is brightest (I measure along a straight line between the center and the edge of hot spot). It can sometimes take 25 or 30 seconds, so I just kind of count that out in my head. Once you have the number at 10 meters the math becomes very easy. You take whatever that number is and multiply by 100 which is just adding two zeros to the end.
So my GT Mini was 1,480 lux. This is 148,000 candela at 1 meter. Easy math. My big GT was 10,560 @10m which is 1,056,000 cd. 10 meters is the way to go if you have the space.
Then to convert to distance is the regular X4 then square root.
Newlumen
Newlumen's picture
Mine thrunite v6 measurement are similiar to nkresho. If that is true, mini gt cw have more lumen than nw .. i was told mini gt cw led are high bin. anyone can verify ?
