(prototype) the GT Mini
1637 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 3 hours 15 min ago
Hey Scott, do you recommend the new VTC5D over the older 5A? Looking for the absolute most delivery from an 18650 to stick in my Meteor. Smile
And hey, gotta love that little GT mini, right? Did you get the short tube for it? Really cool in that format, just awesome all around for what it can do and it’s diminutive size. I think it’s a win, regardless of how close it is in performance to the D1S, different format and just overall really likeable.
Newlumen
Newlumen's picture
KawiBoy1428 wrote:
Got my GT mini today… GT miniscule measured 1318lm with a 30Q and 1463lm with a VTC5D.
Very Nice…INDEED! Thumbs Up
Nice.. your lumen number are reading high as well as d4s.. did you wait like 5 seconds after you turn on the light?
Delta_V
Last seen: 5 days 23 hours ago
Finally! And in one piece, lol. The LED isn’t quite perfectly centered, but doesn’t seem to affect the beam. Kinda disappointed in the diffuser, to be honest. It’s too loose to be used for anything except tailstanding. Otherwise, it’s extremely impressive. Shocked how much shorter it is than a C8.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 25 min ago
What is a Meteor 4P? I know they do perform a bit better than my VTC5A’s in some of my lights. They out perform/perform better in my multi cell carrier lights, single cell multi emitter lights, (quads and trips). They hold the output longer too. I don’t see as rapid of a drop in output as with the A’s. The VTC5D’s got my TN42 70.2 P2-1A into the 9’s the A’s did not, as much as I tried and I have a lot of A’s of different vintages. Now I’m wondering about the VTC6A’s….right, these are the next bad boy 18650’s?
Edit: Yeah I really like this little bugger, the wife had to laugh when she seen it next to his three giant brothers! And of course I got the even more miniscule Micro Tube for the baby GT! Big Smile
KB1428 “Live Life WOT
KawiBoy1428
Naw, that read was at turn on with the VTC5D. I don’t do countdown or 30sec test with FETDD drivers, it will drive you crazy. I watch the output drop for anything out of the norm, like it sky rocketing down, other then that, I don’t really care. Now my Linear, Buck or Boost driven lights, that’s when I care a lot.
DB Custom
DB Custom's picture
Scott, yeah, the Meteor is 4P to 12 emitters. Stock the cell choice may not be such a big issue, but, well, mine is a long way removed from stock. May be pulling 50-60A. (I get a quick 17,284 lumen reading and it plunges, getting hot and draining cells at a crazy rate) So of course, I’m looking for that little bit more… Smile
JasonWW
JasonWW's picture
Last seen: 16 min 40 sec ago
The VTC5D (late 2017, early 2018) is supposed to be the latest, greatest chemical mix. It’s a bit better than the older VTC5A (2016).
When it comes to the major battery manufacturers, it seems like their newest version always performs better than their older version. They are always finding small improvements. (Don’t qoute me, I’m talking about in general they always make improvements)
mortuus
mortuus's picture
Last seen: 13 hours 55 min ago
very nice, i asume its cw ? Smile
...where Frugal meets with Flashlight!
KawiBoy1428
Indeed… Big Smile
KawiBoy1428
The 8 VTC5D’s I have register 15-16 IR on my SKY RC..if that helps ya…
DB Custom
DB Custom's picture
Yep, thanks Kawi. Wink The 30Q’s I’ve been using are showing around 25 IR. Compared to the single digits of my 30T’s (07-09) 25 is pretty high.
Thinking about trying out the offset boring with a 4 jaw chuck to see if I can open the battery tube holes in the M43 a bit to accept the 20650 LG HG6, pretty dang close to the 30T really in a slightly smaller form factor. (I could offset bore towards the middle and not bother threads or anything, in theory) Wish I had a mill….
Still thinking about making a new tube for my GT mini to use a 30T… Wink
lawallac
lawallac's picture
Last seen: 7 hours 46 min ago
BLF GT mini with short and reg tubes, BLF GT with short and reg tubes. Not sure that I’ve seen these all together or at least recently, so here they are.
mortuus
mortuus's picture
thats a nice looking blf-family.
Agro
Agro's picture
Last seen: 11 hours 32 min ago
According to HKJ curves:
VTC5D < VTC5A < Samsung 24S < Samsung 20S.
JasonWW
JasonWW's picture
When a battery manufacturer designs a battery they have to adjust the chemical mix to give them what they want. They can go towards the direction of high capacity at the expense of less amperage output. Or they can go the other direction and make it have more amperage output at the expense of less capacity.
Every new battery seems to perform better overall. An example is the old Sanyo/Panasonic 3400B compared to the newer 3500GA. Max continous amperage went from 5A to 10A and capacity went up just a tiny bit.
To my knowledge HKJ has not tested the VTC5D, 24S or 20S. Maybe you are refering to Mooch?
Do you have a chart of these tests? I’m curious to see it.
JasonWW
JasonWW's picture
Yeah, I think you mean Mooch. He even explains in his report that you have to sacrifice capacity if you want amperage and vice versa. Here is a chart I found. I’d this the chart your refering to? The batteries are a bit different.
JasonWW
JasonWW's picture
A quote from Baditude on the e-cigarette forum. (CDR = continous discharge rate)
Quote:
Let’s follow the evolution of the Sony VTC line:
Sony 18650VTC3 1500mAh 30 amp CDR
Sony 18650VTC4, 2100 mah 23 amp CDR — lost significant amps but gained significantly more capacity
Sony 18650VTC5, 2600 mah 20 amp CDR — added significantly more mah, but lost very little amperage
Sony 18650VTC5A, 2500 mah 25 amp CDR — lost a minimum of capacity, but gained more amperage
Sony 18650VTC5D, 2700-2800 mah 25 amp CDR — gains more capacity without sacrificing amps
Sony 18659VTC6 3000mAh 15/20 amp CDR — gained maximum capacity, but lost moderate amperage. Obviously designed for situations where max capacity was desired, but still had a decent amperage output.
Maximum amperage is not always the end goal when designing a battery; if it was the VTC3 would be the only battery Sony needed to make. Some end users wanted a longer lasting battery, even if that meant sacrificing some amperage.
Subsequent incarnations have had varying capacities and amperage. Now end users have a wider choice of options according to their specific requirements.
Agro
Agro's picture
I forgot, HKJ didn’t test VTC5D. Not sure where I’ve seen the direct comparison with VTC5A…
But he did test 24S and 20S, with Vapcell wraps:
https://lygte-info.dk/review/batteries2012/Vapcell%20INR18650%202400mAh%20(Purple)%20UK.html
http://lygte-info.dk/review/batteries2012/Vapcell%20INR18650%202000mAh%20(Black)%20UK.html
ADDED:
VTC5A vs. VTC5D, from Mooch:
Maverick1947
Maverick1947's picture
Last seen: 1 month 1 week ago
Hey guys. Banggood is offering the Gt Mini for 32$! Just got one for myself.
There’s no replacement for displacement.
JasonWW
JasonWW's picture
It must be part of their big 12th anniversary sale.
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
Have you got a link for that Maverick, I can’t seem to find it.
Maverick1947
It’s a coupon code teacher. It’s on the Banggood discounts thread. The code is ab8a87.
Newlumen
Newlumen's picture
Thanks for the info.. i have 5 sony vtc5d. I dont see much improve over the sony vtc5a.. vtc5d are damn expensive $10 each.., i personally would use sony vtc5a if i can.. its much cheaper..
teacher
teacher's picture
Thank you my friend. Thumbs Up
mortuus
mortuus's picture
hm i think my mini has a problem with the button now Sad It barely works i just put in a fresh charged 30q battery and its like not coming on, it gets power and i have to click like 10 times or more for it to come on suddenly i dont get it? if i double click a few times i get high mode and cant if i hold in button ramp. If i lose tailcap and back again the button turns green so idk it wasnt like this last night,
anyone else have issues with button?
I should send neal a mail maybe but this sucks never had a button go bad on a light before like this..
djozz
djozz's picture
Last seen: 8 hours 18 min ago
I had a switching problem with the mini-GT that sounds like yours. It was not there when I received it but it started after some playing with the light. I contacted Neal about it and he was helpful and prepared to compensate me for it, but also asked if I could look into what the underlying problem was (fair enough, he knows that I’m into modding flashlights). It did not come as far as unsoldering the switch to see if the problem was inside the switch (I ordered some spare switches on aliexpress for a dollar) because the switching started working again after some more use and letting the light run hot a couple of times. Since then the switching works fine, although you never know if it stays that way of course.
mortuus
mortuus's picture
here is a short video of how it behaves
djozz
djozz's picture
Yes, that looks familiar, sometimes the switching is picked up by the light, most times it is not.
RobertB
RobertB's picture
Last seen: 15 hours 16 min ago
Sometimes mine takes a few clicks to shut off too.
teacher
teacher's picture
Yeah….. on a couple of occasions (so far) mine would not shut off. I unscrewed the tailcap to shut it off. After that it worked fine until the next time it would not shut off.
The green light on the switch quit working the 3rd day.
