(prototype) the GT Mini
1637 posts / 0 new
Agro
Agro's picture
Last seen: 6 hours 12 min ago
Nope, the 18650 tubes are different and there’s no 18350 for D1S.
shirnask
shirnask's picture
Last seen: 3 min 51 sec ago
JasonWW wrote:
Agro wrote:
For me the reason to pick GT Mini is the shorty variant.
The D1S also has a 18350 tube I’m pretty sure. The same as the D4 shorty tube.
I don’t think a shorty tube has been offered with the D1S
DB Custom
DB Custom's picture
Last seen: 46 min 37 sec ago
The D1S has a deeper thread at the tube to head connection. It can use the short tube of the D4 IF the user makes some adjustments. There are copper crush washers that come in handy in times like these, Kawiboy found them to work very nicely and I too have found them to be useful. Occasionally one fits without adjustment, other times some filing or sanding may be necessary. But at any rate the copper washer works as a spacer between the driver ground ring and the battery tube to allow the short tube to make contact. Wink
gabo
Last seen: 11 months 3 weeks ago
Hello, this is my first post on BudgetLightForums and a week ago I got my GT Mini in the mail from Neal. I noticed that the backlight button is weirdly backlit, not like other GT Mini’s, and at some times its very unresponsive, one time I couldn’t turn the light off for 2 minutes because the button won’t do anything. I hope the button will break in with use and work normally. Here are some links to pictures of the backlight button:
Image 1
Image 2
Image 3
EDIT:
Here’s the video, you can see sometimes the problem occuring. https://photos.app.goo.gl/sAGa9NQv8kmXNQGi7
Convoy S2+ XML, Convoy C8 XML, Thrunite TC20, Lumintop GT mini, Skilhunt H03, Anker LC40, Anker LC90
mortuus
mortuus's picture
Last seen: 8 hours 35 min ago
all gt minis are backlit like that, mine looks more or less the same like yours. Its clearly that there is an issue with the buttons sadly on some lights. But if u have on a brand new light already a button thats unresponsive i dont think it will get better overtime, mine worked perfect for almost a month then suddenly one day unresponsive…
I hope they will cover us that has issues with this, its clearly something that should go under warranty and i mean 40$ i expected better quality overall..
...where Frugal meets with Flashlight!
gabo
Sometimes when I try to turn on the light it recognizes one click as two and goes straight to turbo or recognizes 3 clicks and goes to battery check mode, that is frustrating, but overall I like this light.
EDIT:
mortuus
mortuus's picture
Yes same problem i have, the light is useless as its defective that way since its a gamble when it will turn on or off or even go turbo no matter if u click ten times not normal behaviour, send Neal a mail and ask for replacement head or something. Even if its just a few under 10 people so far out of 3-400 users its still not fun for the few of use that got the a defective light either at once or after a months use…
Neal@m4dm4x.com
gabo
Neal@m4dm4x.com
Thanks! I’ve sent him an email stating the switch issue.
JasonWW
JasonWW's picture
Last seen: 1 hour 56 min ago
No, his black button cover is rotated to the wrong position.
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
JasonWW wrote:
Even if they offered a replacement driver, which is relatively easy to swap by soldering two wires, most people still couldn’t do it because the bezel is glued shut. So it definitely needs to be a warranty issue. This is the flip side to gluing your lights.
Yep Jason…. well said. Thumbs Up
Especially when some of the bezels are glued ‘extremely well’to say the very least. Facepalm
Still a lot to be said for driver retaining rings, threaded switch retaining rings, and no glue. Wink
ymmv
mortuus
mortuus's picture
well so is mine, its not perfect centered the so called smiley Smile its a bit off but not as off as his no but still….
I asked Neal if maybe a replacement head is an option to send, since that is easy just unscrew and it would probably work but if they dont want do that i have wasted 40$ on a light i will not use since its defective and warranty for a light thats 1 month old should cover normal use…
teacher
teacher's picture
mortuus wrote:
(snip)
I asked Neal if maybe a replacement head is an option … (snip) … but if they dont want do that i have wasted 40$ on a light i will not use since its defective and warranty for a light thats 1 month old should cover normal use…
Don’t worry… they will make it right. Wink
mortuus
mortuus's picture
Got reply from Neal, Thumbs Up
Quote:
Yes that is ok I will resend u a head Regards Neal
JasonWW
JasonWW's picture
Quote:
Yes
that is ok
Regards
Neal
Thumbs Up
teacher
teacher's picture
JasonWW wrote:
Quote:
Yes
that is ok
Regards
Neal
Thumbs Up
Yep… told you it would work out. Smile . Thumbs Up Thumbs Up
DB Custom
DB Custom's picture
I think I need a new head too, think Neal can help me with that? Mine’s damaged…
Oh, we’re talking about flashlights aren’t we? Silly
Brainsick67
Brainsick67's picture
Last seen: 3 months 4 days ago
Go to Ebay, you can find a new head there.
I'm ThatCrazyFlashaholic 67
teacher
teacher's picture
Take your pick my friend… Wink
DB Custom
DB Custom's picture
I might should choose the aluminum one, rough as I am on a head…
PS: Also because I’m a little soured on the whole beheading thing. Wink
Flashaholics
Flashaholics's picture
Last seen: 3 hours 57 min ago
Just reviewing the GT mini for youtube, first thing I’ve noticed is my GT has strobes from default. Nice light tbh, the aluminium is very very soft though.
My 4K Lumen Whore Reviews (MS18, X70, MS12, DX80, X80-GT, X45vn etc) - https://www.youtube.com/c/FLASHAHOLICS_GB
teacher
teacher's picture
Excellent choice IMO….. Thumbs Up .. Beer .. Wink
JasonWW
JasonWW's picture
They all do. I think Lumintop used a slightly different version of NarsilM than they were supposed to. Still v1.3.
Maverick1947
Maverick1947's picture
Last seen: 1 month 1 week ago
!{width:33%}https://tse2.mm.bing.net/th?id=OIP.muluruCb-VXnpLbil6ZDvgHaFj&pid=15.1&H...!
3 valves per cylinder? The hell? Where is that head from?
There’s no replacement for displacement.
Yourrid
Yourrid's picture
Last seen: 6 days 1 hour ago
Finally caving in and ordering a GT mini… question is, who has the best deal and fastest shipping?
teacher
teacher's picture
Maverick1947 wrote:
I really don’t know… it was just a ‘stock picture’ with no info.
chinooker
chinooker's picture
Last seen: 19 hours 19 min ago
4 valves/cylinder-engine_hyundai_trajet_2.0_16v_136_hp
JasonWW
JasonWW's picture
3 valve is pretty common. A lot of Ford 4.6 and 5.4 have them. No big whoop.
DB Custom
DB Custom's picture
3V Cylinder Head Bare 2.190/1.650” Valve 225 Cc Intake – 60 Cc Chamber – Ford Cleveland/Modified
Brand Name: CYLINDER HEAD INNOVATIONS
Part Number: SBF3V225B-60
Description:
The all new 3V 225cc cylinder heads replace the older 218cc heads and are suited for use on competition and serious street engines of 400+ cubic inches in size and making up to and in excess of 650+hp. The new 225cc feature the same minimum cross section (2.4�) as the 218cc intake ports are designed to deliver maximum power and torque, for those people not concerned by RPM limitations, but rather wanting to make the most possible torque and horsepower for their competition to wild street power plants.
Oh yeah, $852 each and of course it takes two. Silly
Cereal_killer
Cereal_killer's picture
Last seen: 1 month 4 weeks ago
That’s not a Ford head 100% for sure. Atleast not from a modern 3-valve 4.6L/5.4L. For one the valve arrangement is wrong (Ford heads have the single exhaust valve centered), plus if we were to say just for s&g’s thay maybe those were aftermarket Ford heads with non-factory valve geometry we’d still be able to prove that wrong as the intake ports are no where near correct. Not only would the ports not line up but the two decks (head to intake manifold) wouldn’t meet up at all on those things.
I’ll bet money those arnt Ford 3v heads. Hell it could even be an i4 head off who knows what.
DB Custom
DB Custom's picture
I google searched by the stamped in coding, and it came back as a Ford head. A custom racing Ford head.
Neither your money loss nor Teacher’s best intent helps me much though, and it was his offering of 3 choices to help me that got all this started. Best intentions and all that…
