(prototype) the GT Mini
1637 posts / 0 new
fonfan
Last seen: 7 hours 25 min ago
Add one.
WANTED Zebralights. My flashlights
M4D M4X
M4D M4X's picture
Last seen: 2 min 18 sec ago
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
fonfan wrote:
Add one.
If you want one you must add it yourself. Wink Go to the link quoted below to do so.
M4D M4X wrote:
http://budgetlightforum.com/node/60983
Erwin Selt
Erwin Selt's picture
Last seen: 1 year 6 months ago
One for me please. Cool
teacher
teacher's picture
Facepalm .. Big Smile . Big Smile . Big Smile
M4D M4X
M4D M4X's picture
guys - due to the new (quite stupid) privacy laws I do not send anyone anything without them actively asking to be contacted.
by using that forms you willingly give me your data and demand to be contacted thru it.
Wink
05131996
Last seen: 1 year 8 months ago
I will take one
Kulumatic
Last seen: 3 weeks 4 days ago
Damn i have to take one.
IN FOR ONE.
jmoots
Last seen: 1 day 17 hours ago
How does this compare with the Kronos X6?
-joel
Agro
Agro's picture
Last seen: 5 hours 51 min ago
I really like the shorty variant…but at the same time I don’t have enough use for it to justify the expense.
zak.wilson
Last seen: 18 min 54 sec ago
This has considerably more throw than a Kronos X6. It’s very closely comparable to an Emisar D1S.
Ceilingbounce – flashlight testing and runtime graphs for Android
toobadorz
toobadorz's picture
Last seen: 2 months 6 days ago
This size is almost the same as Manker U22. Any possibility to have an optional 21700 tube? A descent high capacity 21700 can provide at least 40% more runtime than a 18650, while the diameter is only 3mm larger! This tube diameter difference is almost negligible given that head size.
toxiccoccyx
I’m in for 1.
teacher
teacher's picture
Remember ….
The link below is where you sign up to be on the group buy list. . Smile
Nicolaas
Last seen: 1 month 2 days ago
M4D M4X wrote:
guys – due to the new (quite stupid) privacy laws I do not send anyone anything without them actively asking to be contacted.
Wink
Really?
Well, here’s the solution: I hereby give you permission to send messages to my PM box in BLF anytime you like.
With public greetings,
Nico
weklund
weklund's picture
Last seen: 43 min 54 sec ago
I need two.
... Happy Landings ...
JasonWW
JasonWW's picture
Last seen: 16 min 48 sec ago
weklund wrote:
I need two.
You have to sign up at the link a couple posts above.
Click this to go to signature links.
Firelight2
Firelight2's picture
Last seen: 5 hours 6 min ago
Satan@103TFS wrote:
Signed but what different from D1S ?
Knurling on the body tube. That’s a big improvement right there!! Big Smile
Bozlight29
Bozlight29's picture
As I watch the photo it’s comparable with the UT02. Is it better? I already have the Utorch, so I am only interested if it’s a better thrower.
Perdu
Last seen: 1 year 2 days ago
Down for two please.
Persechini
Persechini's picture
me wanty
In my Tree
My collectionEmisar: D4 / D1 / D4 (broken) ― Convoy: C8 Clear / S2+ Clear / S2+ / S2+ UV / S6 ― Nitecore: Tube / Thumb / Concept 1 / HC30 / HC33 / TIP / TIP CRI / TINI ― Lumintop: Tool AAA / Tool AA / HLAAA / EDC05 ― Sofirn: SF10 / SF12 / SF12 / SF14 / SF14 / SF14 / SP10A / SP10A (gifted) ― Jaxman: E3 ― UTorch: UT01 ― Trustfire: Z2 ― Skyfire: SF-065 (trashed)
Delta_V
Last seen: 4 days 4 min ago
Based on the specs, the Mini-GT will likely out-throw the UT02, and will have a nicer UI. Also hopefully a better button, as I found the button on my UT02 awfully mushy. Beyond that, it will come down to which type of driver is being used. If the Mini-GT uses a FET+1 driver like the Emisar D1S, then the UT02 will have the advantage of more stable output over time due to its boost driver as well as greater efficiency at mid-levels. But if the Mini-GT uses a boost driver, or even just a buck driver, then the UT02 might lose that advantage.
There’s also the difference of whether you prefer 18650s for compatibility with other lights, or the longer runtimes of 26650s combined with micro-USB charging.
JasonWW
JasonWW's picture
They seem pretty comparable as far as output and distance. I seem to remember some people getting really low output from the UT02 after Utorch adjusted the drivers down to increase reliability. I can’t remember if they were measuring 1000 or 1200, though. It was pretty low for a xhp35-HI.
The mini GT seems to have a 9mm smaller diameter head combined with a slightly smaller die size emitter so my guess was the mini GT would have a little bit tighter hot spot giving it more throw, but the pictures show them with a similar sized hotspot. Oh well, I guess the differences equal out.
I think the big selling point on the mini GT is the styling and UI. It’s also much smaller and lighter than the UT02.
If the driver is a FET, the XPL-HI can handle higher amps. At 7A it might be doing 1700 lumen which would definitely beat the UT02. In stock form they appear to have similar throw.
giorgoskok
giorgoskok's picture
Last seen: 3 weeks 9 hours ago
It should be named MT , from Micro or Mini Thrower , compared to GT
Firelight2
“MT” pronounced “empty”? … I think “mini GT” sounds better.
giorgoskok
Maybe another word haha ! Little Thrower (LT) maybe Big Smile Big Smile Big Smile
Mini Giga Thrower is kind of ironic
azj
Random Dan wrote:
When does the AAA keychain model come out? Wink
We need this!!! Big Smile
goshdogit
goshdogit's picture
Last seen: 2 hours 15 min ago
If 18650 is ‘mini’ and 18350 is ‘micro,’ then how about ‘pico’ for the AAA model? Party
M4D M4X
M4D M4X's picture
Big Smile
ToyKeeper
ToyKeeper's picture
Last seen: 1 min 14 sec ago
djozz wrote:
I never liked the looks of the D1S, so I may be in for this one Smile
As far as I can tell, that’s the point. Same size and performance as a D1S, but with a different look and feel. Also, an optional 18350 version.
