(prototype) the GT Mini
1637 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 7 hours 15 min ago
chadvone wrote:
If I run mine up to a mid level and double click it goes to Turbo, and if I double click from Turbo (blinkys disabled) it returns to the mid level.
Sometimes it just turns off with the double click from Turbo.
Edit- this only happens when I am at the top of the ramp.
I see what you mean. The fact of the matter is that a dbl clk is not designed to return to the previous level. I think it’s just a glitch that it does (assuming you have blinkies disabled and are below the ramp top).
The solution is to just slow down your button presses. Don’t try to dbl click. Just let the light turn off and back on. This is how all my other Narsil based lights works.
Or, if you like that ability, don’t run it at the top of the ramp. Run it just below the top.
Click this to go to signature links.
chadvone
chadvone's picture
Last seen: 1 month 1 day ago
Yep, all my other Narsil based lights have this glitch also
Edit- Now I know its not a switch problem.
Thanks
Nev
The original GT also has a glitch ,if you click 3 times for the battery volt check then click to exit, If you turn the light on within a few seconds the gt will switch off but it acts normal if you wait a few more seconds befor turning on.
Pulstar
Pulstar's picture
I am happy to report i recieved replacement head from Neal’s gadgets. Switch feels alot different and has great tactile response. So far no problems. Consider my issue resolved Wink
teacher
teacher's picture
Unless I missed someone, I count 17 people to date who have posted about switch problems. They are….
  • djozz // Reported RESOLVED
  • mortuus // RESOLVED (replacement head from Neal arrived)
  • teacher // RESOLVED (replacement head from Neal arrived)
  • RobertB // Reported RESOLVED
  • gabo // RESOLVED (replacement head from Neal arrived)
  • Cereal_killer / (from Banggood)
  • Jhicks2018 // RESOLVED (replacement head from Neal arrived)
  • P33 / (from Banggood) // RESOLVED (“partial refund” reported)
  • Coyotehawk
  • X3 / (from Banggood) // RESOLVED (PayPal dispute refund)
  • illuminos
  • Silent_Star / (from Banggood)
  • Juheebus / (from Banggood) // RESOLVED (Replacement head)
  • mb200k
  • Pulstar // RESOLVED (Replacement head from Neal arrived)
  • A92AA0B03E / (from NealsGadgets) // RESOLVED (Replacement head)
  • komeko // RESOLVED (PayPal dispute & refund.. explained in post below)
Anyone else having any type GT Mini switch problems besides the people I mentioned above??
List updated. Pulstar & komeko RESOLVED, 30 December 2018
komeko
komeko's picture
Last seen: 22 hours 33 min ago
Neal ignored me. He promised to send new head and the promise was over. Paypal gave me money so I consider the topic closed to me.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
teacher
teacher's picture
Sorry to hear you were ignored komeko. Sad … But glad you were at least able to resolve it thru PayPal. Thumbs Up
I updated your name in the list above.
Icarus
Icarus's picture
Last seen: 1 month 1 week ago
Not a problem with the switch but inside the head of one of my GT mini’s (I bought 4 from Neal) something is rattling. I reported this to Neal. He asked for a video which I sent him a few days ago. So far he didn’t reply yet.
JasonWW
JasonWW's picture
Maybe the centering ring for the reflector is missing? If so, don’t run it at high brightness levels. You might burn up the led.
Icarus
Icarus's picture
No, the centering ring for the reflector isn’t missing. Unfortunately I can’t get the bezel off because it seems glued and I don’t want to damage the finish.
JasonWW
JasonWW's picture
About the only other thing I can think of would be a completely loose anti rotation screw. If that’s the case, there is a chance it could create a short between the positive lead and the reflector.
teacher
teacher's picture
It ‘could’ also be a loose piece of solder….. possibly.
Icarus
Icarus's picture
Based on the sound it could be the reflector and/or the window.
JasonWW
JasonWW's picture
If the centering ring is there, maybe the o-ring is missing. Assuming the o-ring applies pressure to the lens and reflector. You might add a little heat to the bezel (hair dryer, heat gun, etc…) and see if you can loosen it.
teacher
teacher's picture
Is the lens (window) loose??
Press on it & shake the light and see if the sound stops.
Icarus
Icarus's picture
teacher wrote:
Is the lens (window) loose?? Press on it & shake the light and see if the sound stops.
When I press hard on the lens it helps but there is still some rattling. Neal still didn’t reply. Sad
P33
Last seen: 1 day 2 hours ago
I just want to let you know that I fixed my GT Mini. The issue was a cold solder on the microswitch.
teacher
teacher's picture
Good for you P33….. Thumbs Up . Glad you figured it out.
teacher
teacher's picture
Hmmmm…… ??? . Hopefully Neal will reply & have some idea…..
To bad the bezel is glued tight….. Facepalm
Th558
Th558's picture
Last seen: 1 hour 19 min ago
I’m having some problems. The switch behaves strangely sometimes. It started working fine a few days ago when I loosened bezel a tiny bit. I opened it again today removed the reflector to check something and put it back and it started doing random things again. Like not not detecting clicks and sometimes detecting two. It seems to fix itself sometimes but then starts malfunctioning again.
mortuus
mortuus's picture
Last seen: 7 hours 35 min ago
sounds like the problem me and and a few got in here, i would ask for replacement head.
...where Frugal meets with Flashlight!
teacher
teacher's picture
Yep… Where did you buy yours Th558?
Th558
Th558's picture
Banggood
Th558
Th558's picture
For some reason the highest current I can get from a 30q is 3 amps. This is with a mustool MT66 with some AC mains cables instead of stock leads. With an LG MJ1 I got about 3.8 amps. The led looks brighter aswell compared to my L16. The button is slightly off center on the 30qs so could this be what’s causing the problem? I don’t even know if I’m meant to be using button tops in the first place but that is what it states on banggoods page.
JasonWW
JasonWW's picture
Multimeters are no good for amp draws. They almost always read low, especially as the current increases they become more inaccurate. You need a clamp meter.
teacher
teacher's picture
Unless I missed someone, I count 18 people to date who have posted about switch problems. They are….
  • Coyotehawk
  • illuminos
  • mb200k
  • komeko // RESOLVED (PayPal dispute & refund.. +explained HERE +)
  • Th558 / (from Banggood)
List updated. Th558 Added, 5 January 2019
Igor
Igor's picture
Last seen: 5 days 18 hours ago
I’d like to ask a question I couldn’t get an answer elsewhere. I just could find one runtime graphic on google, showing that the GT mini steps down to around 10% of the output in the first 3 minutes? Can anyone confirm that? Thank you.
The darkness is afraid of us.
Flashlights are cheaper than therapy.
mortuus
mortuus's picture
hm yes it does stepdown, but not to like 10%, a few hundreds lumens less but how much i cant say exactly.
Igor
Igor's picture
Has anybody measured and plotted a runtime graphic?
Igor
Igor's picture
My GT mini has just arrived, I’m in China right now and bought directly from Lumintop. I got the neutral white version. I like it so far, waiting to get dark to test it.
I don’t know if I got lucky, but the flat on the body is perfectly aligned with the button.
