(prototype) the GT Mini
1637 posts / 0 new
wellerus
Last seen: 3 days 20 hours ago
Is it normal that when a gt mini is turned off, led still glows like a moon mode, don’t know maybe 1 or 2 or 3 lux, so i can light a watch and see what’s the time, also can clearly see a spot on a white wall.
Even if i lock a torch with a 4 press of a button, so the green led on a button goes off, but xpl-hi led still glows a little, so it’s impossible that an xpl-hi led is iluminated a little from a button led.
Do you think i need to RMA it , because i have befor this one another gt mini NW, but i didn’t see that a main led shines even if a torch is off.
In manuals it writes that a parasitic drain is around 27micro A but on my torch parasitic drain is when a torch is off 4.3mili A.
Is this a problem with a driver or with a led?
M4D M4X
M4D M4X's picture
Last seen: 2 hours 18 min ago
if you lockout the tailcap for a minute and then reconnect - does the led glow before you hit the switch first time too?
already member of M4DM4X.com ?
the best deals are waiting for YOU!
BIG THANKS for helping me by using my REFLinks
before you buy elsewhere mail me: MARTIN@M4DM4X.COM - i will try to save you money!
wellerus
Yes, as fast as i turn down a tailcap, led blinks two times and then dim glows, i don’t need to push a power button.
teacher
teacher's picture
No, that is not normal. When the light is OFF, the LED should be OFF.
JasonWW
JasonWW's picture
Last seen: 7 hours 52 min ago
It’s a problem with the driver. The led is just a dumb device with constant positive power going to it. It’s the driver that is responsible for the ground side. Apparently there is some current leaking through the driver allowing power to flow (like a bad 7135 chip or capacitor for instance). 4mA can run a battery down pretty fast. I would see about getting it replaced.
Click this to go to signature links.
PhatPhil
Last seen: 1 year 3 weeks ago
Any plans for an XHP70 version of the GT mini?
djozz
djozz's picture
Last seen: 28 min 4 sec ago
The problem can be under the led also, if there is a minute short between led- and the central pad (which is connected to ground), a small piece of dirt is enough to cause that, the led lights up. Is it really more than a lumen? (you can get a visisble illumination of a watch down to 0.01 lumen, in which case the drain is 0.03 mA which is totally negligable.
JasonWW
JasonWW's picture
That’s what their ODF30 is. It’s got a bigger battery of course, but very similar.
bluereidon
bluereidon's picture
Last seen: 9 months 2 weeks ago
I just received my GT Mini NW from Lumintop Aliexpress store and I am so happy with it I cant even express it with words!Extremely well build very handy pocket thrower with perfect Kelvin emitter for me!Wicked flashlight!
M4D M4X
M4D M4X's picture
great!
sgt253
Last seen: 13 hours 55 min ago
I just received one also. I am really happy with the light! The size, the distance the beam throws, the tint of the emitter, the UI. Pretty cool that I have a light similar to the BLF GT that I can carry in a pocket. I love BLF! Thanks to all for the effort. Regards.
bluereidon
Same from me man!All the lights BLF community makes are great!
I cant wait to save money for the bigger brother of GT Mini,but I am not sure which to get GT or GT70,maybe the 70 is more of a usable beam
Lonelydad
Lonelydad's picture
Last seen: 3 weeks 2 min ago
Two comments:
1. I sometimes have a problem turning the light off. Usually if I try a few times or ramp up a little ways then try it will work. Not a big problem so not worrying about it.
2. Got mine from Banggood. I ordered a neutral white emitter, received my light with a big CW sticker on the box. I informed Banggood, and their response was basically, ‘mistakes happen once in a while. Will you accept 400 Banggood points [$4 USD] to make it all better.’ Not really – I ordered a neutral white because that is what I wanted.
Anyone have any suggestions on best next step?
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
teacher
teacher's picture
Next step to what?? Not trying to be funny, I just don’t understand. Are you asking about #1, #2, or both??
P33
Last seen: 1 day 2 hours ago
Just don’t agree to anything that doesn’t satisfy you. They just offer silly coupons and wait to see if you’ll escalate it.
Cereal_killer
Cereal_killer's picture
My light had really bad paracitic drain when off, I’m talking an order or magnitude higher than it should of been! It was drawing around 1100-1200 micro amps while off. Not a new development but I just now finally got tired of it and decided to do something about it.
I removed and replaced driver components one at a time (do note I’d already deleted the unnecessary voltage divider since the tiny85 monitors cell voltage internally) till the draw went away. The culprit: C1
I’m now measuring 37uA with the aux LED off, 137uA with it on high (blue led with 5.6kohm R6). I can finally leave the tailcap not locked out again!
Also swapped to the good FET and swapped to a SST20 while it was apart. Reading 156kcd now @ 1300Lm.
JasonWW
JasonWW's picture
You think the C1 had a crack internally which caused a small short? Maybe just defective from the start?
Bob_McBob
Last seen: 6 hours 27 min ago
Is it actually possible to order a GT mini without the bezel glued? I’m getting rather sick of manufacturers that work with BLF surprising us with glued parts on the production run. Enthusiast lights should never be glued.
Bob_McBob
Lumintop, you have a lot to answer for Tired
teacher
teacher's picture
What is that? Glue on the threads, crappy anodizing, crappy threads, or what??
Bob_McBob
That’s blue Loctite, which makes removing the bezel a huge pain in the ass.
teacher
teacher's picture
OK…. That’s what I thought but could not tell for sure from the pic.
I just gave up on getting mine off… it was not worth the trouble to me. Facepalm
I can’t understand why they would use that much….. that is total & complete overkill if they are going to use it.
If it is a BLF light I wish they would stop using any glue or LockTite at all.
Maybe if we start voting with our wallet, they will. Wink
monkeyman77
mine will be here tomorow unless the storm stops ups i am so excited
JasonWW
JasonWW's picture
That’s normal.
Here’s my glued ODF30.
They said it was glued, so they have nothing to answer for.
liteupmynite
Last seen: 20 hours 10 min ago
Hello, I just  purchased a GT Mini and will receive it today.
QUESTION: Are IMR 18650s or 18350s batteries okay to use in it?
thanks!
Lonelydad
Lonelydad's picture
thanks!
I have a Samsung INR18650 30Q in mine, and it works just fine. I would look for documentation saying it would be OK before using two 18350s, due to the higher voltage than two CR123s.
mortuus
mortuus's picture
Last seen: 33 min 21 sec ago
thanks!
yes high drain 18650 recommended, and 18350 will work if using the shorter tube.
...where Frugal meets with Flashlight!
RobertB
RobertB's picture
Last seen: 13 hours 58 min ago
Mine was glued with a bunch of thread locker too. Two strap wrenches and the bezel was off in a minute. Used naptha to clean it up.
liteupmynite
Thanks!!! Look forward to comparing the Mini to it's bigger brother )))
thanks!
mortuus
mortuus's picture
liteupmynite i think the bigger will eat up the smaller Sad
