(prototype) the GT Mini
1637 posts / 0 new
Lonelydad
Lonelydad's picture
Last seen: 4 days 11 hours ago
alex64 wrote:
Received the replacement from Banggood (complete flashlight) and this works excellent. I tried more than 60 clicks and did not miss any. Good customer service of Banggood.
Must be nice. I gave up on getting them to send me a NW instead of the CW they sent. Their attitude was basically “the flashlight works, what is the problem?”
You don't really need a parachute to skydive. But you DO need one if you want to skydive twice!
hodor
hodor's picture
Last seen: 9 hours 6 min ago
I’m getting fed up with them as well, please tell us know how you worked your magic.
editor
editor's picture
Last seen: 1 year 6 months ago
Quote:
Anyone else having any type GT Mini switch problems besides the people I mentioned above??
Hi, I got a GT Mini as BD present from a commercial source. Love the light, it’s smart, bright and tiny, but it seems button issues went to production. It requires quite a pressure and this force needs to be applied through a thick rubber. Something like bicycling in deep sand. Even if it clicked it’s not sure it got the command. With randomized sensitivity to button clicks modes part settings and use is more than challange. I’m not complaining, I’m amazed by the efforts and results in community flashlight world, this is just a respectful feedback.
JasonWW
JasonWW's picture
Last seen: 15 hours 43 min ago
Is your rubber switch cover aligned properly or crooked?
editor
editor's picture
The smiley head is slightly tilted right and the bunny on the tube is not fully aligned with the button. Approx five degrees. Does it make a difference?
teacher
teacher's picture
The bunny on the tube makes no difference.
The switch might… although it it not that far off.
Try pinching the rubber boot & pulling up on it a bit.. then let go & see if that helps.
JasonWW
JasonWW's picture
I can’t see your pic, but it should look like this.
(By Lock)
Some people report a mushy feel if it’s slightly rotated.
editor
editor's picture
Thank you for your help teacher, I appreciate it much. Tried what you said, I could grab the cap with my nails quite well and tried to adjust some. There were both misses and doubles since. The sings that suspect the controller is that sometimes clicking the count of required mode and it sticks in the first. A second or two later the light steps up but not the exact mode I clicked. I also experienced an event more times when lowest mode turns on and turns off a second or two later when I don’t even hold the light any more.
My experiences are after successfully resetting the light, swapping to modes and selecting mode 9.
editor
editor's picture
Sorry for the pic, I’m new here don’t know where’s my mistake. The pic is in this shared Google album:
https://photos.app.goo.gl/Ny4gAU8oNvY9uFzB8
JasonWW
JasonWW's picture
Here is what the back of the rubber switch looks like.
The switch on the driver is rectangular. If this gets rotated it might just be pushing on the edge of the switch which could lead to unpredictable results.
If nothing you try fixes it, contact who you bought it from to see about getting a replacement head.
JasonWW
JasonWW's picture
Google hosted images are hit and miss. Sometimes they show up and sometimes they don’t.
Your switch doesn’t seem to be rotated too much. I’d still try to straighten it and see if that has any effect.
teacher
teacher's picture
Sure thing editor, sorry it didn’t help. And FYI, I can see your picture. Thumbs Up
editor
editor's picture
Thank you for the picture! Can that rubber be pulled all the way out from the outside when the light is assembled without damaging it?
I did not buy the light, I received it as birthday present. The last thing I would do is bothering the person being kind to bring me present on my birthday to have it fixed or replaced. No idea where he ordered from, best guess is Banggod, but who knows. He wanted to make me happy, I won’t go back to say I’m not. At least ramping mode doesn’t care much about missed clicks and doesn’t produce random behavior.
JasonWW
JasonWW's picture
Maybe. The retaining ring is a press fit squishing the rubber edge to make it water tight. Sometimes it’s not super tight and it can rotate. If you do pull it out, you can probably pry out the retaining ring to reinstall everything. I have not tried this personally.
(My picture is from the ODF30. It’s the same basic switch boot as the GT Mini)
Here is a picture where someone removed the switch boot on their GT Mini. I was showing them how to pry the retaining ring up.
Here is the whole conversation.
http://budgetlightforum.com/comment/1366531#comment-1366531
editor
editor's picture
Thank you so much for your kindness, this is more than informative. I’m afraid I daren’t risk to tear the rubber cap apart or void the tightness. My other experiences with this light suggest that controller may also struggle with challanges, the occasional delayed operation and surprising behavior suggest that. Most probably I let the light as it is. It functions in ramping mode and missed clicks / malfunctions can’t cause me tactical disadvantage :-). It’s my first Lumintop light and first experience with a button not promptly responding and not reliably. My bow to BLF developers and fans is honest, still I’m not sure I became a Lumintop fan.
BlueSwordM
BlueSwordM's picture
Last seen: 2 weeks 1 day ago
It’s really sad actually.
All the problems come down to the switch actually.
Everything was fixed on my GT Mini just by rotating the switch cover… but this shouldn’t be a problem on a stock sold light.
editor
editor's picture
I’m not sure it’s all about the switch. There are few strange experiences:
  • In Modes from standby I click once. Moonlight comes up, switch flashes three times and the light goes off. Sometimes it does this way, sometimes it turns on.
  • In Modes from standby I triple click – seems like nothing happened. Looking on the led, it’s in moonlight and before I could turn away it burns my eyes.
So delayed, sudden and surprising answers coming from the light in Modes.
DB Custom
DB Custom's picture
Last seen: 1 min 49 sec ago
The D shaped boot activation pad is catching on the side of the driver, delivering an unusual pressure that may stay applied for a short time after you click resulting in the driver “thinking” a different action was required from what you intended. The boot needs to be rotated slightly so that the flat top side of the D shape can clear the driver, you should have no problems after that.
You can probably use a sharp wood chisel to slightly raise the retaining ring, bump the chisel in slightly from each side to give some wiggle room for the boot, then align it. Try it in action and see if it is fixed, if so, tap the retaining ring back in. Wink
editor
editor's picture
Thank you Dale, perhaps I’ll do it once. Not in the next two weeks for sure.
hodor
hodor's picture
Are there any aftermarket boots which fit?
fluke
Last seen: 3 days 18 hours ago
Having switch issues with my GT Mini.
Any solutions?
I not sure I could replace it.
Don't want to mess up a light being ham fisted.
Spent a life working on cars but this switch is teeny.
teacher
teacher's picture
1. What is it doing (or not doing)?
2. Where did you buy it??
3. How long have you had it???
fluke
teacher wrote:
1. What is it doing _(or not doing)_? 2. Where did you buy it?? 3. How long have you had it???
  1. Does not register every click. (Sometimes you can click it 4 times it does nothing, no matter wahat mode it is in, even momentary)
  2. Bangggood
  3. Since Sept 2018
mortuus
mortuus's picture
Last seen: 6 hours 20 min ago
Ok, then your issue is same that me and some others had, button does not register clicks etc.. but weird did u use the light and no issues since sept 2018 and suddenly problems? My issue started probably just a few weeks after i got mine from Neal during group buy hardly used, i got a new head replacement which i requested. Maybe try request it to banggood also but i dont know how they will deal with this problem now?
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
BlueSwordM
Well, rotate the switch cover slightly.
It’ll fix the problem instantly.
fluke
Thanks Guys.
I will try Banggood but as you say doubt they will help.
How do you twist switch cover? Just tried seems like it will rip doubt its glued.
BlueSwordM
You just take some pliers, and remove it gently.
It should pop right out.
This is what I did on my GT Mini anyway.
fluke
 Yep that worked.
I ripped it a bit but all ok.
Thanks All.
fluke
Only started a few days ago. I dont edc it but get used regularly.
teacher
teacher's picture
fluke wrote:
teacher wrote:
1. What is it doing (or not doing)? 2. Where did you buy it?? 3. How long have you had it???
  • Does not register every click. (Sometimes you can click it 4 times it does nothing, no matter wahat mode it is in, even momentary)
  • Bangggood
  • Since Sept 2018
  • Ok, that ‘ sounds familiar. Bought it in September from Banggood… they might or might not help.
    Rotating the switch might fix it. HERE is a post that gives some details & pics about that.
    This is normal switch orientation…
    This is the underside of the switch.
