[M4Ddeal active] : Lumintop GT Mini - 2 authorized deals
402 posts / 0 new
shirnask
shirnask's picture
Last seen: 1 hour 32 min ago
Just ordered one NW and a short tube
Thanks Martin!
M4D M4X
M4D M4X's picture
Last seen: 25 min 39 sec ago
Neal will speak with Lumintop
find all available items in this list
i launched my new blog - all deals for members without MAP B$ Wink
find a short description about my idea here
if you want to buy a flashlight or battery for a better price: just send a mail - i will try to save you money!
dekozn
Last seen: 1 day 23 hours ago
Is there any difference in output depending on which cell is used? Does it need buttontop cells to work?
JasonWW
JasonWW's picture
Last seen: 1 hour 22 min ago
It has a spring on the driver so flat tops will work fine.
18650 cells can vary a lot depending on the model. So if it can maintain a certain voltage under load it will give the full output.
If you want the most run time at 4.5A (regulated output) you need an unprotected high drain battery. There are many to choose like 30Q, VTC6.
If you use a high quality protected battery it will have an extra voltage drop which means it will fall out of regulation sooner. So less time at 4.5A. You would need protection circuits capable of 7A, I think.
Both types will work to give full output, though. If your not sure about a certain battery just ask.
dekozn
Thanks Jason,
I was just wandering if there would a big difference between a sanyo GA and Samsung 30Q. both unprotected.
JasonWW
JasonWW's picture
dekozn wrote:
Thanks Jason,
There is a bit of difference since the 30Q is a high drain and the GA is a high capacity.
I like to use HKJ’s battery comparator. Load up both batteries, set it to show 5A and you can see that the 30Q will have less voltage sag giving you more regulated run time. The GA will give you more unregulated runtime.
In the real world you might not notice these differences. Both are good batteries.
I would stay away from the Panasonic NCR18650B, though. I had this picture already so I figured I’d post it.
Even at 3A, the Panny B has big voltage sag. At 5A the sag is even greater. The GA, 35E and MJ1 are all good high capacity cells if you need max runtimes down to the low voltage protection.
I prefer sticking to high drain and swapping batteries once it gets down to 3.7v or 3.6v.
vit55
Last seen: 21 hours 32 min ago
Just ordered now, one CW with holster and sony VTC6 thanks Martin thanks Neal.
leroycp
Last seen: 7 hours 1 min ago
Ordered
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 hours 51 min ago
I filled out the form this morning. Anything I need to do except for waiting for the code?
JasonWW
JasonWW's picture
You just need to wait for Martin to send you the purchase info. He’s in Austria so he might be asleep right now. Are you in the same time zone?
Still, if you signed up this morning it seems like he should have sent you the info earlier today. There are plenty of lights, so no need to rush. I’m sure he will contact you soon.
teacher
teacher's picture
Last seen: 2 min 45 sec ago
Ordered:
  • 1 x GT Mini CW
  • 2 x C8 Sheath
  • 1 x VTC6
Thank you Martin & Neal!!! Beer
Lux-Perpetua
Well, yes…actually Austria and Germany are in the same time zone and very close together. We even speak the same language. Wink
No need to rush…I can certainly wait. I was just a bit suprised how many people wrote today something like “yeah, just ordered”, so I was wondering if there’s anything else to do from my side.
Thank you JasonWW!
Cheers,
Thomas
timbuchanan
Last seen: 6 months 1 week ago
I’m still looking for a runtime on high estimate – would this calculation give a good approximation? 3000mah = 3ah, 3ah/4.5a = 0.66hr, so 40min on high.
anycolourfloyd
Last seen: 1 week 19 hours ago
JasonWW wrote:
dekozn wrote:
Thanks Jason,
Do you have an estimate at what voltage the 30Q will fall out of regulation?
Delta_V
Last seen: 55 min 24 sec ago
It’ll be more complicated than that because at some point the voltage will drop below the threshold required to maintain the 4.5A current draw. At that point, brightness will start decreasing, but so will current draw.
End result is the total runtime will be longer than 40 minutes, but the runtime at max brightness will be less.
Neal
Last seen: 23 hours 56 min ago
JasonWW wrote:
klrman wrote:
What protected battery is recommended for the short tube micro?
18350 cells are already way down on power. A protected version doesn’t make sense to use in my opinion. I think the Aspire is the best, but I don’t know if it’s made with protection circuitry.
Maybe someone else knows.
Keeppower 18350 1200mah
they said aspire is from the same factory
MikeH
Paid earlier today for 1x NW + shorty tube.
Thanks Neal, Martin, and Lumintop!
M4D M4X
M4D M4X's picture
JasonWW
JasonWW's picture
No, that’s something Lumintop would have to tell us. They could design the driver to fall out of regulation at different voltages. They might not tell us, but we could still measure it once we get the lights.
JasonWW
JasonWW's picture
Like Delta_V said, it’s more complicated than that. Keep in mind that in the real world thermal protection may activate. So you would measure on high, then turn off and cool down the light, then run on high again, then add up all the run times to find out the total run time on high (within regulation). Is that what you meant? Or did you mean how long it will it run before stepping down due to heat?
I can only say that you will definitely get longer, steadier run times at 3.5A. Also, a high drain battery will stay in regulation longer in comparison to a high capacity battery.
We won’t get any real runtime data until the light gets tested.
Xikex
Last seen: 59 min 17 sec ago
Just ordered a NW and a 30Q. Thank you guys.
Kalihi
Just ordered one NW with a holster.
wolfstyle
Last seen: 17 min 10 sec ago
Just ordered one in NW, short tube, and two 18350.
Enlightened1
Last seen: 1 month 1 week ago
Ordered 1 NW, 1 CW, 1 short tube, 1 holster, and 2 VTC6 batteries the other day.
Thanks for the opportunity!
M4D M4X
M4D M4X's picture
thank you guys!
teacher
teacher's picture
M4D M4X wrote:
thank you guys!
Your welcome… Thank you Martin!!! . Beer
DrDevil
DrDevil's picture
Last seen: 1 hour 21 min ago
Ordered a GT mini -cw with short tube, holster and sony battery
Thank you Thumbs Up
808Hi
Last seen: 6 min 3 sec ago
Ordered 1 MiniGT/ NW
Delta_V
Just ordered one in NW & holster. Thanks.
Satisfaction
Satisfaction's picture
Last seen: 2 weeks 4 days ago
Just ordered mine, then signed up for your site!
Thanks
