Golisi IMR20700 3200mAh S32 (Black) 2018
Official specifications:
Size: 20 x 70mm
Model: 20700
Capacity: 3200mAh
Constant Current: 30A
Nominal Voltage: 3.7V
Charging cut-off voltage: 4.20±0.05V
Cycle times: >800
Charging Time: 2.5H(with Golisi Charger)
Operate temperature: Charging(0-45?), Discharging(–20-60?)
Storage Temperature: Room temperature, dry place
This battery is a high current one and is of the never sizes.
The two batteries do not match completely, the capacity is nearly constant at any load.
At 30A I had to stop early due to temperature.
Conclusion
This battery looks like a fairly good high current cell.
Notes and links
The batteries was supplied by Golisi for review.
Compare to 26650 and other batteries
