(BLF) Sofirn Q8 V1.5: The XPL HI monster, DIY parts + Extended 8x18650 tubes GB Interest List
380 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 2 min 26 sec ago
Yes. That’s why this took some time for Sofirn to manufacture them.
They’ve had to make special battery carries that work like in the BLF GT, and make an additionnal tube that threads on the original one.
That would mean you can just remove the tailcap, screw on the new tube, put in the carriers with the cells, and screw down the tailcap onto the new tube, and voila! 8×18650 Q8.
Edit: Not so sure on that aspect anymore. I’m waiting for Sofirn to respond on that.
Fate0n3
Last seen: 3 hours 9 min ago
Thank you big time kind sir for the response!!!! That is awesome and great news. One last question for us looking to purchase is to ask if we will be required to run Button top cells? not that is a deal breaker just so that all of us interested know and make sure we have button top cells ready to go for this.
Acebeam X70 – BLF GT70 – BLF Q8 – Acebeam X80GT – Acebeam X45 – Astrolux MF01 – Noctigon Meteor M43 – Thrunite TN36 Limited – Emisar D4S – Emisar D4 – Lumintop GT Mini – Olight S10 Baton – Olight SMINI Baton Ti – Mateminco X6S – Mateminco S03
DavidEF
DavidEF's picture
Last seen: 2 hours 8 min ago
Uh… The “original” BLF Q8 tubes were quad bored pretty tightly in order to be able to load a single cell (or two or three cells) and have it (them) stay in position. I’m fairly certain there’s no spare room for a carrier, unless it is simply two PCBs and a center bolt! Shocked Can we get a picture of the carrier? Innocent
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
BlueSwordM
I’ll ask them for some details. What I said doesn’t make a ton of sense indeed.
I hope it’s not going to be a completely separate tube and carrier.
Unless they are making a completely customized carrier though. I do doubt that however, just looking at the CAD renders.
I was perhaps completely wrong Facepalm
Let’s ask Barry.
DavidEF
DavidEF's picture
Well, a couple of PCBs and a bolt or better yet, two or more bolts to keep from spinning, might actually work, but I can’t imagine it being very durable.
-Ayn Rand
Fate0n3
Looking at the video they for sure used a carrier on both the one that screwed into the head and the secondary tube. Which if that is the case i am STILL IN, but maybe inquire about a complete light setup. A new Sofrin head and 2ea battery tubes/Carriers for the few of us that would rather have separate lights to do this with.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 1 hour 58 min ago
I have shared the information about the extension tube+carrier on TLF and that it is yet to be clarified if the extension will fit and work with the original tube w/o carrier. Sofirn has meanwhile checked if availability on Amazon could be an additional option to their store on AliExpress. They replied back on TLF:
"the extension tube has to connnect with the BLF Q8's head, not original Q8 tube.
I just got a notice, the group buy of extension tube will only be available in aliexpress store."
@BlueSwordM: Please add 3 extension tubes + carriers for me. Thank you! I wonder if a 12p configuration is still sort of "lightweight"...haha. Big Smile
SebaZ74
SebaZ74's picture
Last seen: 2 weeks 2 hours ago
Hi, if i have one Blf Q8 (4×18650) and i want have 8×18650 tube version, what i must buy?
Sorry for my bad english.
djozz
djozz's picture
Last seen: 1 hour 15 min ago
This is what I got as a sample two weeks ago, I do not know if it is the final version. I have not have time to really dive into it, sorry about that. You need both the two new tube parts because they need to be completely hollow to fit the battery carriers. They are made for button tops because no reverse polarity protection goes wrong very easily with battery carriers. But as you can see it is easy enough to solder shallow brass buttons on the carriers if you want to use flat tops (and are not scared of battery shorts every now and then Evil )
The system works very well and despite what Sofirn said this works with both my Sofirn Q8 and BLF Q8’s. But I have not checked resistances yet compared to the stock Q8 battery situation. I have the hope that the springs used are copper-alloy springs
SebaZ74
SebaZ74's picture
Thanks djozz, how much lumen will it be and how long will it shine in higher and turbo mode?
BlueSwordM
Some additional info:
two new battery tubes(with two battery carriers) for the BLF Q8 head. Since the threads are different between BLF Q8 and Sofirn Q8, we need to make the tubes sperately.
So that is it. A different config altogether.
Fate0n3
So we need to get the Sofrin Q8 for this to work? Or they will be making it for the BLF Q8 also?
I wonder why they changed the threads between the 2 seems like an odd thing to do
BlueSwordM
The change of threads mostly happens at the head to fix some O-ring problem with the Sofirn Q8, so yes, they will probably introduce 2 tube variants.
Lux-Perpetua
BlueSwordM wrote:
Some additional info: _two new battery tubes(with two battery carriers) for the BLF Q8 head. Since the threads are different between BLF Q8 and Sofirn Q8, we need to make the tubes sperately._ So that is it. A different config altogether.
I'm not sure if I got this right: Two new tubes for the BLF Q8 head? I assume they just meant to say they are making two new tubes for BLF Q8 AND Sofirn Q8, i.e. one new tube for the Thorfire "BLF" version and one new tube for the Sofirn version. Is that correct?
Unloco
Last seen: 56 min 14 sec ago
I want a BLF Q8 extended 8×18650 tube (x1).
BlueSwordM
Lux-Perpetua +3
SebaZ74 +1
Unloco +1
@Lux-Perpetua, that basically means the 1st tube that threads onto the head on the BLF Q8 is different than the one on the Sofirn Q8.
TheBigLEDowski
Last seen: 2 weeks 4 days ago
interested in BLF Q8 tube
BlueSwordM
TheBigLEDowski +1
SebaZ74
SebaZ74's picture
I’m sorry but I still do not understand, I have to modify my Blf Q8 before I buy the tube? if not, there will be a lot more lm? and how will it be with the length of the turbo mode? Thanks.
BlueSwordM
@SebaZ74, you will only have the buy the BLF Q8 version of the tube to make it work.
If you have not bypassed the springs, you will be getting more lumens since the resistance will be 1/2, and the current to the LEDs will increase, and there will be more brightness.
High turbo brightness runtime will be increased by about 1,5-2x depending on what 18650s you use.
Chatika vas Paus
Last seen: 1 hour 38 min ago
Will it be possible to buy it later in their store on Ali?
BlueSwordM
Uhh, yes obviously.
Where otherwise would they sell it ? Wink
Dirt
Last seen: 4 days 6 hours ago
In fer 1. Price dependent.
BlueSwordM
Dirt +1
Fate0n3
BlueswordM you going to keep the interest list in this thread or make another one?
JasonWW
JasonWW's picture
Last seen: 6 hours 23 min ago
You take off the stock battery tube and put it in the closet. Then buy two new tubes and two carriers. Then you can use 8 batteries in it.
Correct BSM?
A single blast of turbo should last about the same amount of time as it does now, or maybe a bit less, before the thermal protection reduces output. It might be a bit brighter, but not much.
Total run time basically doubles when you double the number of batteries.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
BlueSwordM
@JasonWW
1. Yes. Put it in the closet.
2. Yes, same turbo runtime, but if you can keep the light cool, you will get at least 50% more runtime.
3. Not exactly with a FET light. Since you basically halve the resistance of your battery setup, that means the light will be capable of pulling more power, and therefore, less max power runtime on unregulated mode.
Bonus points: With an extension tube, you can now get the same power output as with 4×20A cells with 8×10A cells, meaning you can use higher capacity cells like the NCR18650GA and Samsung 35E/36G to get 10-15% more capacity on average, which is non-negligible.
JasonWW
JasonWW's picture
If you keep the light cool you can more than double turbo run time, even using 4 batteries. It’s hard to keep it cool, though. Wink
You don’t really halve the resistance of the batteries by using 2 carriers. Texas_Ace saw this when using two carriers in the GT. You add a little resistance back into the circuit from the contacts between the carriers as well as having more battery springs.
So you get less resistance overall, but it’s not exactly cut in half.
We still need to see how good the contacts are between the carriers.
SebaZ74
SebaZ74's picture
So please, tell me what are the real benefits of the 8×18650 configuration compared to 4×18650?
JasonWW
JasonWW's picture
Longer run times and ease of converting voltage to 6v or 12v for custom emitters.
