(BLF) Sofirn Q8 V1.5: The XPL HI monster, DIY parts + Extended 8x18650 tubes GB Interest List
380 posts / 0 new
djozz
djozz's picture
Last seen: 1 hour 16 min ago
SebaZ74 wrote:
So please, tell me what are the real benefits of the 8×18650 configuration compared to 4×18650?
1) extended runtime
2) it looks extreme, especially with even more extensions added Big Smile
3) if you are a modder, the battery carrier situation makes it somewhat easier to convert the Q8 for 6V leds (together with a different driver)
The output will not change dramatically with 8×18650.
Fate0n3
Last seen: 3 hours 9 min ago
You could have started and ended with this one, you sold me on it with the one line lol
Acebeam X70 – BLF GT70 – BLF Q8 – Acebeam X80GT – Acebeam X45 – Astrolux MF01 – Noctigon Meteor M43 – Thrunite TN36 Limited – Emisar D4S – Emisar D4 – Lumintop GT Mini – Olight S10 Baton – Olight SMINI Baton Ti – Mateminco X6S – Mateminco S03
leaftye
Last seen: 5 days 13 hours ago
People that want a baseball bat assault light finally have a good option.
The low mode should be lower.
Reviews: Efan IMR18350 700mAh 10.5A, <a href="http://
DB Custom
DB Custom's picture
Last seen: 3 min 1 sec ago
I am interested in getting two tubes with their corresponding carriers, also wondering if the thread pitch might happen to match the Fenix TK75 extension tubes? (shot in the dark, that one)
FWIW, Richard makes a 4S carrier that fits the Fenix TK75/TK61 lights. Just saying.
Kasperrr
Last seen: 1 month 1 week ago
Hi!
I am interested in getting two extensions tubes + two carriers for my Sofirn Q8!
Thanks!
DB Custom
DB Custom's picture
I know, I know, but I’m so dang forgetful!
What was I planning to do with these XHP-50.2’s I got in the mail the other day? They were for the Q8, I am pretty sure, but I forget just what the plan was? Did I say anything about this here? (truly sucks, having a fish net memory)
[something in the back of my mind pushed me to order a 4S carrier from Richard, this applies here, yes?]
Nguyen
Nguyen's picture
Last seen: 1 day 2 hours ago
interested in BLF Q8 tube. One set.
Thanks
DavidEF
DavidEF's picture
Last seen: 2 hours 9 min ago
So… 4S conversion, using (at least) two tubes for more power, XHP50.2 emitters, in a Sofirn Q8? Are you going to use a Lexel driver? Or a L4P driver? Other?
Reason is not automatic. Those who deny it cannot be conquered by it. Do not count on them. Leave them alone.
-Ayn Rand
BlueSwordM
BlueSwordM's picture
Last seen: 3 min 4 sec ago
DB Custom +2
Kasperrr +1?
Nguyen +1
@Kasperr, do you mean 1x extension sets(2 tubes+2 carriers) or 2x extension sets(4 tubes+4 carriers)?
@Dale, what kind of danger of society are you thinking to build with an 16 cell Q8?
It’s obviously not a 3V setup. You’d blow the LEDs and traces everywhere if you tried something that way, even with Luxeon MZs.
A 6V setup would be good, but still way too much current for the XHP50.2s, since XHP50.2s are more fiddly than the XHP70.2
A 12V setup with 4xXHP 70.2s would work well, although you’d be at the limit for the LEDs if each is paired with 4×18650s BeCu spring bypassed carriers. And at the limit to create a fission reactor lol.
BlueSwordM
However, the Q8s design is extremely good compared to something like a Haikelite MT09R.
It has much better finning, meaning active cooling works quite well actually, and can be easily modded for more heat sinking potential.
JasonWW
JasonWW's picture
Last seen: 6 hours 24 min ago
I could see a 12v buck driver working well with 4 x xhp50.2.
Now a xhp70.2 mcpcb would be sweet as you could use a FET driver, but I don’t think anyone makes one. You might have to use 4 seperate mcpcb.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
contactcr
Last seen: 33 min 17 sec ago
Xhp35 would drop right in. Would be like the Sofirn one on steroids
DB Custom
DB Custom's picture
There are inherent problems to many of the scenario’s, I bought a 21” bar of 3” dia 6061 to be able to re-create the head so more mass and multiple emitters, maybe wired up to facilitate the use of the carriers… I need to get a bunch of parts in hand and go down to the lab and see what Igor can help me create. Big Smile
DB Custom
DB Custom's picture
What would the 50.2’s do as a quad in 2S2P configuration with a 12V FET Zener modified driver? 70.2’s might fare better, but then, 4P 35’s would also do well but the current would need to be limited, maybe not so much on a single driver but… I may be getting to far gone to do these things, hard to think anymore.
Quad 35’s would only be likely to make 8,000 lumens or so, not even worth the effort if I can’t see 12-15,000. Just sayin…
BlueSwordM
For the XHP50.2s, Lexel’s buck driver at 8A would do well for you, and at 4A/LED, with a nice AR lens, you’d probably be getting about 2800 lumens/LED, so an actual 11 000 lumens of regulated runtime would actually be possible with a 4S setup.
You’d actually be the 1st guy to create a stable 11 000 OTF lumens as long as the light is sufficiently cool, which is the problem here of course. Mind you, this would be amazing still.
Wonder why I hadn’t thought of doing that build… Oh yeah. Tint shift and low CRI Sad
Does any know a source for 4500k-5700k Luxeon MZs? I’d love to get some Smile
DB Custom
DB Custom's picture
Ok, I have a plan. Targeting 15,000+ lumens. We’ll see how it goes. And I’ve “drawn it up” so I don’t forget. Big Smile
contactcr
Wont the Luxeon MZ have a donut on the Q8 reflector?
djozz
djozz's picture
Still have to do that mod, and I expect a serious donut hole. I’m planning to heavily frost the lens with sanding paper to get rid of that and create a massive flood beam.
contactcr
Take the reflector out entirely and put 3x carclo triples for 9x MZ for an ultimate flooder
led4power
led4power's picture
Last seen: 2 hours 37 min ago
I've mentioned before in few Q8 threads that Q8 OP reflector made by Sofirn would be nice addition to Q8 modding parts.
yasenf
Last seen: 2 hours 26 min ago
In for 2 sets for BLF Q8 (4 tubes+4 carriers)
BlueSwordM
yasenf +2
DavidEF
DavidEF's picture
Well, there is DC-fix that you could use, which will let more of the light through the lens! And if you want to reduce the amount of light that gets focused into a beam, maybe stippling the reflector with clear coat like Old-Lumens used to do. Or, if you’re going to diffuse the lens one way or the other, take the reflector out completely or paint it white. Anything but taking sandpaper to a lens. I’ve done that, and it looks horrid! Sick
Just my opinion. Big Smile
-Ayn Rand
djozz
djozz's picture
I did a few S2+ lenses with sandpaper (180 grit 3M branded) and it took some time but it looks very nice now. The trick may be quality sandpaper and some perseverence. I will show the Q8 lens when it is finished Smile
DavidEF
DavidEF's picture
djozz wrote:
… may be quality sandpaper and some perseverence.
Ah Hah! The two things I didn’t have! Yeah, I’d like to see your results when you’re done. Wink
-Ayn Rand
DB Custom
DB Custom's picture
Go by the gunsmith shop, have them hit the lens for a couple of seconds with bead blast media, voila! You might call and see when they’re going to be bead blasting, they like to set up work to get in the blaster and do everything and get out. Wink
Or you could just leave like 3 lenses with them, ask for a light, medium and heavy blast whenever they get around to it. They might not even charge you anything, curious to see what you’re doing with it and such. lol
Seawolf
Seawolf's picture
Seawolf + 1 Absolutely!!
Seawolf
BlueSwordM
Seawolf +1
BlueSwordM
New vid on the Q8 extension tube:
https://www.youtube.com/watch?v=kmeRWGCQN6I
As you can see, there are 2 different tubes for the BLF Q8 and Sofirn Q8. No inter compatibility because of a slight thread change on the Sofirn Q8 for slightly better waterproofing.
The Q8 looks huge now though…
I love it Big Smile
DB Custom
DB Custom's picture
Gonna have to take out a loan to buy the cells… Wink
