Acebeam EC65 review (21700, 4x XHP35 HI, cool white)
87 posts / 0 new
texas shooter
Last seen: 2 hours 3 min ago
JasonWW wrote:
texas shooter wrote:
I received mine two days ago, the XHP35 version. I do feel a bit let down, turbo for about 12 seconds. I knew from the specs the light was too lightweight. But I bought one any way thinking AceBeam could pull it off. I would rather have an extra ounce or two over the rapid loss of performance. The format of 4 tight packed LED’s over a 21700 is a winner, execution just fell a bit short. On the positive side beam is a good mix of throw/flood. As is it’s a good 2000/650/300/20 lumens pocket light.
It’s not a lack of thermal mass that’s making it drop out of turbo. If that’s what your thinking.
I’m sorry looking at my statement it really lacked clarity.
I want the thermal mass to sustain just running on high. The light heats very quickly on turbo and rather fast on high. I get about 28 seconds on turbo with a fresh battery but too hot to hold. A minute of running on high and it’s rather hot to hold. For me the rapid loss of performance is letting it sit and cool before using again. I’m tempted if the light survives a few weeks of use to pot the electronics for water proofing and thermal relief of those tiny little tortured electronic bits. I’m only guessing, but I believe and extra ounce or two in the host and battery tube will bleed more heat out for longer more comfortable use. The battery tube is very thin.
JasonWW
JasonWW's picture
Last seen: 2 hours 4 min ago
Do you think it might be better to go up in size to the EC50 GEN Ⅲ?
NKON employee
NKON employee's picture
Hi,
Thanks for the very thorough review. We have updated the information on our website based on your review.
It would be really interesting to see what the performance of the EC65 would be on a 21700 battery that can deliver 30+ Amperes.
Cheers,
Elmer
I am an employee of NKON.nl so yes, I like to sell flashlights to you. But I will respect this forum and try to add value to conversations. As a seller I think I have a unique perspective on flashlights. If you don't trust me, because I am a seller, then please ignore my comments. I am not going to spam links etc. I am looking forward to engage with the community and add some value if possible.
Please let me know what you think.
JasonWW
JasonWW's picture
Cheers,
Elmer
You can see similar information here as toobadorz tried a LISHEN LR2170SA which is the same as the yellow Liitokala lii-40A. This is a 15A continous rated battery. It’s voltage does not sag under the load and the light runs at 4,000 lumen for 1 minute when the thermal protection starts to ramp it down.
http://budgetlightforum.com/node/60943
The only 30A continous rated 21700 I have seen is the Samsung 30T. I don’t think anyone has tried this combo yet.
maukka
maukka's picture
Last seen: 28 min 15 sec ago
Welcome to BLF, Elmer!
I have some 30Ts coming my way and will update the review hopefully later this week.
hIKARInoob
hIKARInoob's picture
Last seen: 53 min 46 sec ago
Hi,
Cheers,
Elmer
Hi Elmer, welcome to BLF! Party
NKON employee
Ah that is good to hear. Thank you.
NKON employee
Nice, let’s see what they can do.
NKON employee
Thank you Smile
JasonWW
JasonWW's picture
Elmer, when you want to reply to a specific post or person, look at the bottom of their post and hit the “qoute” button.
I typically write my reply just below the quoted section. Thumbs Up
NKON employee
Noted! Thanks!
severide
Last seen: 2 months 6 days ago
Awesome! Looking forward to the update Smile
Noir
Noir's picture
Last seen: 3 weeks 5 days ago
Thank you for your exemplary review maukka.
I can now safely cross this light of my list. There are several smaller things that are, in my opinion, not well executed or thought out and keep me from buy this light, but the biggest issue is the temperature limit. Why did Acebeam set it at 75°C ? That is just way too high. Sure it protects the electronics, but the temperature limit should be set according to the most temperature sensitive thing, the users hand. A limit of 50°C or 55°C (maybe 60°C) would be better.
Furthermore most Li-Ion batteries have a maximum operating temperature of 60°C, and bad things can happen when Li-Ion batteries get too hot.
maukka
maukka's picture
To be fair, the high temperature limit is usually ok, since most of the time you will be holding the light in your hand and can just step it down manually when it feels too hot to touch (>50°C). I rarely (never) leave a light unattended for hours.
Usually when I do runtime tests I will start the fan when the body reaches about 70°C to protect the battery. This time I just wanted to see how hot the light would actually get.
I’m more disappointed about the single real turbo burst. Looks like toobadorz’s new sample was able to do it four times before stepping down to the lower turbo level though. So there’s some variation between lights and batteries. Still, the visual difference between the maximum turbo and the next level down is non existent.
Noir
Noir's picture
That is of course true, but I would prefer a temperature regulation I don't have to worry about. Perhaps I am spoiled by the excellent PID temperature regulation of Zebralights...
maukka wrote:
I'm more disappointed about the single real turbo burst. Looks like "toobadorz's new sample":http://budgetlightforum.com/node/60943 was able to do it four times before stepping down to the lower turbo level though. So there's some variation between lights and batteries. Still, the visual difference between the maximum turbo and the next level down is non existent.
Acebeam should at least have bundled the light with a higher drain battery, or better yet improved the driver so that turbo mode works down to a lower voltage (lets say 3,3 V or perhaps even 3,0 V).
Bad mode spacing is a constant source of annoyance for me. The brightest modes are too close together, and the low modes are too far apart (unfortunately that is way too often the case).
On the EC65 turbo is only 3526/1784 = 1,98 times as bright as high (a difference that is simply too small and, as you say, barely visible), on the other hand low is more than 20 times as bright as firefly (and of course a 12 lm mode is really not deserving of the name "firefly").
On an unrelated note: maukka do you have a central place with links to all of your reviews? It would make finding them much easier in the jungle of threads on this forum, perhaps a central thread or your signature.
JasonWW
JasonWW's picture
Noir, it sounds like your expectations are higher than current technology allows.
I hope that in the near future Lexel will have his high powered boost drivers working with NarsilM. Then you can set your own levels and your own temperature limits.
I think his Bistro UI works on them, but I’m not very familiar with Bistro.
I think building your own light is the only way you’ll get it to your personal liking.
toobadorz
toobadorz's picture
Last seen: 17 hours 36 sec ago
Hello maukka, your measurement indicates the max temperature of Mid is around 65°C, but with my new EC65, I got only 43°C (the max temperature measured around the side switch, during my whole Mid runtime test). My experiment is done under room temperature (25°C), with no cooling.
That is pretty weird, or maybe I should measure the temperature around the head instead?
maukka
maukka's picture
Here’s the light at 25 minutes on mid. Already too hot to hold.
toobadorz
toobadorz's picture
!https://i.imgur.com/Rt1zVjP.png!
Thank you, maukka. I’m sure that my new EC65 can still be held after 30 mins of Mid. Its body tube was still under 42°C then, and I did hold it to feel if it’s too hot (it was not). So there are indeed some differences.
Noir
Noir's picture
I don't think that is the case. A lower temperature limit is just a different value that is set in the firmware and has nothing to do with advancements in technology.
Technology is also not the limiting factor when it comes to improving the driver slightly. I am not talking about huge leaps like 5 A more in turbo or twice the efficiency, but small improvements that would allow the turbo to be sustained down to 3,3 V or maybe 3,0 V instead of just 3,5 V. Small things like for example double or shorted springs (lower voltage losses) would already help in this regard (for some reason Acebeam didn't bother doing this), or simply a slightly lower maximum (turbo) mode which can be sustained better.
As it is the EC65 (or rather its driver) is IMHO a bit too "on a knife's edge" (for lack of a better term).
JasonWW wrote:
I think building your own light is the only way you'll get it to your personal liking.
Very true. If you want it done right, you have to do it yourself. One of the reasons I'm into modding smile.
Pete7874
Pete7874's picture
Last seen: 5 hours 37 min ago
Thanks for the great and exhaustive review!
maukka wrote:
- Throw spec is overrated (16600 cd vs. 11100 cd)
Not sure if it was mentioned earlier, but the photo of the package you posted shows peak beam intensity of 10,600 cd.
maukka
maukka's picture
That is for the Nichia version.
maukka
maukka's picture
Good news, the Samsung 21700 30T not only didn’t break anything, it was able to cycle full turbo seven times before stepping down to the lower turbo level of 3150 lumens. Initial turbo lasts for 40 seconds before stepping down, which is quite a lot better than on one of my original Acebeam 21700s with 12 seconds.
The internal dc resistance of the 30T is only 13 mOhm.
JasonWW
JasonWW's picture
I’m sure performance would be even better with that updated version like Toobadorz got. Have you talked to Acebeam about getting a replacement?
maukka
maukka's picture
Mine is already a replacement after the first one broke on turbo, just like Toobadorz’s. I’m sure the difference in performance is due to the battery sample difference as that is already large between the two I have.
JasonWW
JasonWW's picture
Okay, I must have forgot you mentioned it.
Is your turbo still at 3700 lm? Toobadorz said his was now closer to 4000 lm on the replacement light (for some reason).
maukka
maukka's picture
I don’t have numbers for the first light. It could have well been lower than the 3750 on the new one.
edit: scratch that. The first sample was 3456 lm @ 0 sec.
JasonWW
JasonWW's picture
I’m still thinking this light could benefit from spring bypasses.
I’m not an experienced tester and I’ve only ever tested one light that had a boost driver. I did however notice that as I was using a heavy wire across the tail cap and a clamp meter to measure the amp draw on turbo that it extended the turbo run time.
I further could watch the amp draw decrease as I compressed the driver spring.
Have you noticed any similar behavior?
JasonWW
JasonWW's picture
Also, what battery do you think is best for this light.
The Acebeam doesn’t give much full power turbo runtime, but does give extra run time at lower levels.
The 30T gives a lot of full power turbo run time, but it’s 3,000mah capacity runs out pretty quick.
Maybe the Lishen/Liitokala 4000mah is a good compromise?
Also, that 20A protection circuit is the biggest I’ve heard of. To answer Noirs question, that’s probably why they set that 3.5v turbo stepdown limit. If they tried to set it to a lower voltage it would probably try to draw well over 20 amps from the battery and maybe burn up the driver in the process.
hIKARInoob
If there is a measurable difference using different batteries, then a spring bypass should lead to enhanced performance or not?
