Found a Quality Battery Resistance Tester
98 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 hours 1 min ago
ActiveAl wrote:
FlashTom, for measuring resistance, it may be easier to lay the battery horizontally on a surface where it will not roll around. That way both ends of the battery are easily accessible. Recommend for this procedure that you have good light, patients, and, indeed, where your glasses! It may not be easy to do, but, yes, it can be done. The picture was taken with the battery vertical to better show positive probe placement. The negative probe placement will be like with any other Li-ion battery.  Cheers!
Thank you ActiveAl! So, now I’m well prepared. Wink
Meanwhile my order has been released for shipping. It seems this big delay of 24 hours for payment verification is a usual procedure at AliExpress. It was something new to me as I never had such safety steps at Banggood or Gearbest. The seller also confirmed that he/she ships the new version of the SM8124A with the two-prong probes.
klrman
klrman's picture
Last seen: 18 hours 37 min ago
FlashTom, this is how it looks when I wear my reading glasses.
Lux-Perpetua
Wow…that’s supersharp! If I get as close as this to the object my visual field becomes hazy. Maybe I get back to you guys for some recommendations about reading glasses… LOL
klrman
klrman's picture
nottawhackjob wrote:
Idle uniformed question....... Why not attach a wider magnet than the button top itself, compensating for the magnet's resistance if any, then attach the dual probes?
Good idea for the eneloops.  Have to try it on my liths and see how much it affects the numbers.
Lux-Perpetua
I recently recharged some of my eneloops from 1.24V to their cutoff voltage (1.55V) in my MiBoxer C4-12. According to the charger only 100-150mAh went into those cells. Recharging only took about 5-10min as voltage rose up instantaneously. Their iR was about 60mOhm. I assume these cells can be considered as worn out, right?
joechina
Last seen: 10 min 24 sec ago
Sorry d_t_a,
I don’t know the device.
You should mail the manufacturer. He should know Smile
Joe
klrman
klrman's picture
I got some Protected NCR18650B's from Banggood today and they are all reading 60IR on my SM8124A tester.  My other Protected NCR18650B's are all reading 48IR on my tester.  Would the difference be because they are probably two different protection circuits and therefore showing different resistance numbers?
I'm assuming Banggood is using some cheapo no name circuit whereas my other NCR's are  using genuine Seiko circuits.
BlueSwordM
BlueSwordM's picture
Last seen: 23 sec ago
Yep.
They are probably higher resistance FET on the Banggood cells.
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
klrman
klrman's picture
Thanks!  Any negatives you know of from the BG cells other than more resistance?
BlueSwordM
Hmmm no.
I actually have no protected cell, except for the one from my Imalent HR20.
klrman
klrman's picture
I'm waiting nearly two months for my 30Q's from BG.  They will be my first set of unprotected batteries.
BlueSwordM
Oh.
The customs must have seized your package.
They seize 4×18650s worth 25$CA, but not a phone with a pouch cell, much more dangerous, worth 250$CA.
ImA4Wheelr
Last seen: 23 hours 30 min ago
FlashTom wrote:
Can anyone please post a link to the *SM8124A* we can 100% trust? I mean there are how many sellers on AliExpress....six, seven?...who offer this nice device, sometimes with different brand names, sometimes without the "A", sometimes with two cables on both probes, sometimes just one cable. I find it hard to decide whom to trust. I was unfortunately unlucky with some of these Dolidada batteries...claimed to be IMR-55A cells (like Shockli/Keeppower) but they turned out to be of rather poor quality with much less capacity and even less power drain capabilities.
Mine arrived yesterday.  I didn't get a chance to use it, but it looks like the good model.  It came in a plain white box  with a decent pouch (maybe a holster, didn't look on back for belt loop).  I got it from here.
Lux-Perpetua
That’s exactly where I ordered, too. So, I‘m confident to get the new version, too. Unfortunately, the shipping address in my Aliexpress order is missing the country even though it was correctly assigned in my account. Maybe just an displaying error.
klrman
klrman's picture
ActiveAl wrote:
contactcr wrote:
I think it's worth mentioning that the resistance values from this $50 AC tester should not be compared to other chargers and things that give resistance. AC resistance measurements are pretty far apart from DC load resistance measurements. Article: http://batteryuniversity.com/index.php/learn/article/how_to_measure_inte... So while this device is still useful it is not giving you the same measurement you might find in other sources. Also, I don't think it is as good of an indication of the max discharge a battery can sustain. (like what HKJ or Mooch are giving you)
I read through the article you linked and it was helpful. Thanks. Fortunately, there is a lot you can do with AC resistance measurements, such as:
  1. Measure new cell when you first get them, and then take periodic reading afterward to monitor their health.
  2. Compare measurements against the battery's  datasheet to determine if it is in specification. For example, the Samsung 30Q datasheet identifies a typical 1 kHz AC resistance specification of 13.13 ± 2 mΩ. The  SM8124A  I recently purchased measured my six Orbtronics 30Qs with an average resistance of about 11.5 mΩ (See Table 2.), which is within the datasheet specification. I was shocked that my $50 AC tester was able to provide measurements with this seeming accuracy. Perhaps this is a one-off fluke.
  3. Compare a known battery with one that is suspected of being a fake. For example, if a battery measures considerably more AC resistance than a real 30Q, then it is probably not a 30Q.
Update: I saved this post too quickly and had to make edits. Thanks!
I finally got 4 x 30Q button tops from Bangood today after waiting for over two months.  They all test at 12.0 IR with the SM8124A tester so they are real samsungs!
Zebretta
Mine finally arrived today.
It’s the newer 4 prong model.
Someone said the measurements you get with this meter are not the same you get with your Battery Charger / Testers.
Yeah, I found that to be very true.
How would you convert between the two in order to determine if your charger/tester gives readings consistent with the SM8124A?
klrman
klrman's picture
They measure differently so there probably is not a reliable conversion method.  The SM8124A should give results close to the battery data sheets which use the same method as this meter to determine resistance which is a good start to see if you got originals or fakes.  What I have found so far is that if I add 60% to SM8124A readings of protected cells, they match up with the battery charger IR readings.  So far, different types of protected cells from different companies still seem to be 60% more or close enough across the board but for unprotected cells like the Samsung 30Qs, the difference was 200% higher  with the battery charger than this tester.
Zebretta
Good stuff there. Thanks!
Zebretta
BlueSwordM wrote:
It’s actually quite easy to calculate DC internal resistance.
The problem is that you need a battery holder that does not have piss poor resistance like you see with the cheap ones on eBay and Aliexpress.
If you just want, you just need some power resistor of a determined load, a multimeter, a soldering iron, and some 18AWG wire, and perhaps some brass buttons.
1. Solder one end of 30cm 18AWG wire to 2x brass buttons for nice contacts.
2. Solder the other end to the legs of a 5 Ohm resistor.
3. Wire a switch through the wires.
4. Clamp the brass buttons to the cell with the switch off.
5. Put your multimeter on voltage reading mode.
6. Measure the open circuit voltage of the cell. For example, it will be 4.2V.
7. Flip the switch, and measure the voltage of the cell instantly, then flip the switch again. The noted voltage will be 3,9V
8. Do math:
ΔV = voltage delta = 0,3V
R = 5r = resistance used
V = cell voltage = 4,2V
VL= Voltage under load = 3,9V
C= current flowing
V-VL = ΔV= 4,2V-3,9V = 0,3V
C= VL/R = 3,9V/5t = 0,78A
Internal resistance = ΔV/C = 0,3V/0,78A = 0,38R = 380 milliohm
Yeah, that is the real internal resistance of a cell, and how you calculate it.
Did you build a rig for this purpose?
Any pics?
BlueSwordM
I did build something like this before, but I used bypassed spring holders instead of brass buttons. That was very hard to do though, unlike the more refined method I presented to you guys.
However, now that I have made my Beryllium copper springs, I am going to do one that is much simpler to do for everybody, and is much easier to set up.
Zebretta
Awesome. I’d like to make one. But since you know what you’re doing I’ll wait to see how you did it.
klrman
klrman's picture
BlueSwordM wrote:
+1 I forgot to mention. The resistance measurements are at AC 1kHz sine wave. So while accurate, the resistance numbers are often measured to low. A 4-wire constant current tester is the only way to measure the real DC load resistance measurement.
When you decide to use your new springs to build your new tester, it won't test IR the same as the SM8124A will it, but instead the second method you mentioned above to give real IR readings?
Zebretta
I have doubts about this device.
I need to do some tests using the DC Calculation method to verify but I’m getting results that aren’t consistent.
That said, I removed the cable separator because the leads were too short to get to both sides of my batteries.
Does anyone know if there is some magic in that simple plastic separator that could affect the readings?
Lux-Perpetua
Today, I tested some new cells with my SM8124A. This is the impedance I measured:
Format Name Impedance (mΩ)
 21700  Samsung 30T  6.0
 21700  Samsung 40T  7.4
 21700  Samsung 50E  22.0
 21700  Sofirn 4.000mAh  13.6
 20700  Acebeam 4.250mAh  21.6
 18650  Sony VTC6  11.8
 18650  Samsung 25R  12.2
 18650  Samsung 30Q  12.5
 18650  Imalent MRB186-P30  19.3
 18650  Wuben 2.600mAh  23.4
 18650  Sofirn 2.600mAh  41.9
 18650  Sofirn 3.000mAh  45.2
 18650  Xanes 2.600mAh  45.3
d_t_a
Last seen: 14 hours 43 min ago
Thanks for sharing! That would be a useful baseline reference.
I only have a few of those batteries from your list. I don't have the SM8124A, but instead got the YR1030. I wonder how different the measurements taken by the SM8124A compared to the YR1030...
klrman
klrman's picture
Nice chart thanks.   My Samsung 30Q from Illumn read 10 and 30Q from Banggood read 12 so close enough.
Lux-Perpetua
FWIW, it takes a lot of patience and two calm hands to get useful values with the SM8124A. Especially, with button top batteries it's quite a nightmare to align the probe correctly in order to get useful information. Facepalm I guess it's the same with the YR1030 from Vapcell. They had it for a very decent price on Black Friday. Unfortunately, I forgot to buy one as I would have liked to verify my values with a second device.
klrman
klrman's picture
Major PITA to align the probes on button tops.  I use my desk lamp with the magnifying glass otherwise it takes too long.
Lux-Perpetua
LOL..."PITA"...that's exactly what it feels like. Thumbs Up Later on, I try to amend my chart with values I took from my 26650s (Shockli 5.500mhAh, Keeppower 6.000mAh, Dolidada Fake PLB-55-As, Thrunite 5.000mAh, etc.).
Lux-Perpetua
I have now added some more batteries. All cells were measured in new, unused condition. However, the 26650 cells I bought had some differences between them.
Format Name Type PCB Impedance (mΩ)
 21700  Samsung 30T FT   6.0
 21700  Samsung 40T FT   7.4
 21700  Sofirn 4.000mAh FT   13.6
 21700  Efest 5.000mAh FT   20.6
 21700  Samsung 50E FT   22.0
 21700  Acebeam 5.000mAh BT x 30.4
 20700  Acebeam 4.250mAh BT x 21.6
 26650  Shockli 5.500mAh FT   12.5 - 12.6
 26650  Shockli 5.500mAh BT   12.7 - 13.0
 26650  Keeppower 6.000mAh FT   16.4 - 17.5
 26650  Keeppower 6.000mAh FT x 31.5 - 33.2
 18650  Sony VTC6 FT    11.8
 18650  Samsung 25R FT    12.2
 18650  Samsung 30Q FT    12.5
 18650  Imalent MRB186-P30 BT x  19.3
 18650  Wuben 2.600mAh FT    23.4
 18650  Sofirn 2.600mAh BT x  41.9
 18650  Sofirn 3.000mAh BT x  45.2
 18650  Xanes 2.600mAh BT x  45.3
