Still looking -but getting closer with some better ideas...
All you "spamers" from manufacturing companies... please have a read!
My son and some friends are in Law enforcement and are "experimenting" using a small X2000 and other flashlights for their everyday carrying use on their belts. There is a GREAT amount of interest here (I and about 500 police departments and 150,000 officers)...but...we need something better...
So what I want:
Something like this: (perhaps a little smaller)
http://www.cnqualitygoods.com/goods.php?id=1329
BUT –with an aspheric zooming lens
OR .... something like this SS-A100: (very good on flood to throw) -but that can accommodate a 26650 like the Shadow JM07 as well... with a good sized 30mm glass optic (no bigger)… seems to work well
http://kaidomain.com/product/details.S020028
or this:
The barrel needs to travel like this light...(SS-A100 –I only mention this because we are presently testing this light) - from right close to the led for maximum FLOOD –(when you walk into a room –you want to see everything –wall to wall) -to way out for tight focused hot spot (in this light about 23mm of travel)...The SS-A100 seems to do both these well.
Parameters of what we need:
-High brightness, and long life –which means being able to use an 26650, (like the Shadow JM07) – 18650/18700 –with sleeve, or 3 AAA as back up –we need several hours use on a charge… …(option for second ad on tube for addition battery –if possible?)
-Prefer 3 Run modes – High(1.5-2amps)...VERY low (just for reading)... Stobe... with memory
-Packaged in a small size...120-130mm long (the SS-A100 if there) –similar in style perhaps to the Solarforce L2T (or preferably shorter yet- but thick enough for the 26650) frame
-A Flood to Throw light, with easy SLIDING function...the “push and pull” must work in the design -one hand SLIDING zoom out/in function -your other hand stays free, -can’t be a “tube” as it is too hard to move the head back and forth... -the optics tailor made for the XML (Not -too many “rings” -not just a rehash of some old lens used for XRE’s or XPE’S) –design something that works!
-Rear button on/off –Glow in dark
-High quality for everyday use… BUT -does not have to be super heavy duty… if it is too big, even as big as a c8 size it will not be used as it is not very accommodating for everyday belt carry use.
-Large easy to use threads.. the battery will be changed daily... must still be fine after many changes.
-Of course –water resistant for use in rain... o-rings...
-High quality pouch that fits a 2” belt loop, flashlight goes in and out of pouch easily.
-option to add a small compatible diffuser wand to the head
-be relatively inexpensive… $30 bucks seems reasonable(between the price of the above two lights) , this cannot be an “expensive” flashlight... this is an every officer light so must reflect that in the budget or simply will NOT be purchased
This is NOT the multi cell “beat” light… we are examining them for other purposes… this is the convenient “keep on belt until I need it” –but when and if I do –it will work well for the given situation…
NOW… before I get flamed on this… This may seem like a lot… but really many of the lights currently available have some, but not all of the parameters we need… and are selling in the $20-40 range…some “combination” of the two lights I have mentioned above should seem like a good start… it seems to me –it really can be done… just a matter of design.
Someone do this and a million law enforcement personal and a few other millions like me will snap these up in a second!
