[BLF special edition light] new Sofirn AAA twisty high CRI 5mm LED (CCT 3400K)
2999 posts / 0 new
djozz
djozz's picture
Last seen: 2 hours 17 min ago
polarweis wrote:
crap haha. If you temper it after the hardening it should be better. and tempering doesnt take away any of the hardness if im correct. It just realines the carbon atoms.
Will try Smile
Hondo
Hondo's picture
Last seen: 1 year 9 months ago
Yes, quench hot and fast – you want a 100% transformation from austenite to martensite, and slow cooling will result in retained austenite or pearlite at room temperature. The tempering will lower the hardness, but if done right not below the properties of a proper spring. Not knowing the steel, I would try tempering at 500 – 600 degrees Farenheit, or perhaps as much as your oven can reach. Let it cool slowly after reaching full temperature. The structure will still be martensitic, but it will relax the carbon and iron matrix adding ductility, as in making it less brittle, which is your problem after the quench.
tastewar
Holy crap! I came here for flashlights, dammit, not to learn about hardening/annealing/tempering steel!! Silly
Noctiluco
Noctiluco's picture
Last seen: 2 hours 29 min ago
djozz wrote:
I do not know how he knows, well, actually Sofirn folks tend to talk all the time about their new projects Smile But yes, there will be a C01 pro, but it may get a different name in the end. No idea if it will get a TIR optic or a reflector, but the led will very probably be SST-20 95CRI (4000K and/or 3000K), and there will be two or three simple modes (it being a twisty). I have not seen a design yet so I would not expect this light within the next few months.
Please, Sofirn, only Two modes, 10/15 % — 100 %. Smile
hank
hank's picture
Last seen: 1 hour 39 min ago
Quote:
I managed to convince Sofirn that their clips are faulty, they admit that the heating process was wrong and they sent what is left of the batch back to the manufacturer for improvement.
Is that an assumption, that it was the heating process?
I think I recall someone suggested earlier that the sub-contractor’s sub-contractor had substituted the wrong metal to make the clips?
Sofirn needs to somehow extricate their company from the usual corner-cutting approach.
Sofirn needs to decide to work, as the saying goes, in the early years of a better nation — in which no party in the chain of supply is trusted without QA and QC being done routinely.
teacher
teacher's picture
Since a couple of people have been able to heat treat their clips (although still searching for the exact formula) …. it stands to reason it was the heat treat that was woefully lacking. Whether is was wrong or did not happen… who knows.
But from the look of djozz’s clip that was bent… it looks like heat the treat process was skipped altogether by the supplier.
hank
hank's picture
My reasoning differs, I can’t rule out the possibility the sub-subcontractor supplied the wrong alloy.
You can heat treat any alloy and get some improvement, but you can’t get the desired results from every alloy.
If their subcontractor supplied the wrong metal then they’d get an unexpected result, and leave the metal in an unanticipated condition so another heat treatment cycle would give an unwanted result. It doesn’t appear easy to undo then redo heat treatment to get it right the second time, even starting with the right steel.
http://www.engineeringenotes.com/metallurgy/steel/heat-treatment-of-spri...
Quote:
Any metal, or alloy which can be hard drawn, or rolled to fairly high strength and retains sufficient ductility to form, may be used for springs, or any alloy which can be heat treated to high strength and good ductility before, or after forming may be used. For special spring properties such as good fatigue life, non­magnetic characteristics, resistance to corrosion, elevated temperatures and drift require special considerations.
No, I’m not a materials scientist, I’m just reading what I can find online. As with most tech stuff, I find that it’s far more complicated than I’d have thought.
jon_slider
jon_slider's picture
Last seen: 26 sec ago
djozz wrote:
pocket clips are generic, further searching will find them cheaper than this (pic is a link):
iamlucky13
Last seen: 21 hours 23 min ago
djozz, have you received any updates on when the red and blue colored versions are expected to be available? Thanks in advance.
tastewar
I’m going to go out on a limb and predict…
…Not in time for Christmas.
jon_slider
there are 49 left in 3200k and 45 left in 5600k
I predict no red or blue until this Black batch sells out
teacher
teacher's picture
Could very well be, either way the heat treat was:
  • 1not done at all
  • 2not done properly for the steel used
  • 3the steel was a wildcard (an unknown) from the supplier.
In case #3 there would be no way to heat treat it properly because the steel is not what it is supposed to be.
No matter which it was, a crappy clip was the result for some of the CO1’s.
As far as heat treating a second time or even a third. It can be done with no problem at all if the steel has not been super heated past it’s limit on the first heat treat & ‘burned’ the Carbon out of it. So… if you ‘miss it’ on the first go around, try again.
Tempering after heat treat is very important…. otherwise you just have a hard, brittle piece of steel. Facepalm
Heat treating is a science. There are standard formulas for known steels that give optimum results if followed.
If you’ve never heard of Paul Bos (Buck Knives) & are interested in heat treating, do some reading… he was & is a master at it.
djozz
djozz's picture
I have no update about the coloured C01’s after it was announced for “early december” which obviously has passed already.
Slim Pickens
Slim Pickens's picture
Last seen: 22 hours 40 min ago
Just received my first 2 of 4 and want to commend all parties for the hard work.
These would have remained an idea but for the passion of BLF leaders and a company like Sofirn who listens to and (more or less) delivers exactly what we want.
I’m really impressed with the quality. I’ll have to snag a couple more of these little gems for friends. I think mine will pull double duty as an EDC and a bug-out bag/emergency light.
Ozythemandias
Last seen: 2 hours 24 min ago
Got mine and I’m please, thanks goes out to everyone involved in making this happen
How about a limited run of (preferably Grade 5) titanium? I can’t be the only one wanting that
djozz
djozz's picture
You are actually the first to come up with that. Twisties in titanium tend to suffer from gritty threads, but I have a ITP i3 in titanium that works very well. Does Sofirn do titanium editions at all? What would be nice is if the “pro” edition is there, to have that one in titanium Smile
dealgrabber2002
Last seen: 5 hours 28 min ago
I was comparing the C01 and the E01 last night. I really wish the C01 has a more narrow degree LED to give it the throw like the E01.
Geuzzz
Geuzzz's picture
Last seen: 46 min 39 sec ago
Titanium body and a brass head Smile
buck91
buck91's picture
Last seen: 6 days 8 hours ago
How drastic is the difference? I think the E01 with the Nichia GS was a good balance with a nod towards throw making it useful for maneuvering. Is the C01 THAT much floodier? Hoping it will make a good emergency neck light or backup light for camping.
maukka
maukka's picture
Last seen: 8 hours 33 min ago
You should probably keep an eye on Clemence’s Jetbeam modded with an Optisolis/E21A if you want an ultra high CRI AAA light with some output/throw. Of course it will be much more expensive than the C01.
dealgrabber2002
C01 has no hotspot. To me, it’s like a zoomie on flood. If you want to use it as a tent light; it’s fine. But if you want to walk around or look for things; I find it harder than using the E01. Using indoor to walk around is fine as well because of reflections from walls.
I was thinking exactly what you’re thinking about neck light or camping light last night when comparing the 2 lights. I would put the E01 around my neck, not the C01.
iamlucky13
Very different. The Yujis at 25mA are great for navigating around the house at night, in my opinion. It’s bright enough to use at close ranges without dark adapted eyes, but not so bright as to be obnoxious if you have dark adapted eyes, especially the 3200K version. The floody beam extends into your peripheral vision, so you can have good awareness of what’s around you. That means necessarily that it doesn’t throw like the E01.
Outdoors, I think it’s reasonable for walking with dark adapted eyes, but you won’t be seeing very many paces ahead with it. It should be great around the campsite, but if you were using it as a backup on the trail, you’d want to walk slowly.
Your mileage may vary, of course. There is a lot of variation in what light level is comfortable to different people.
teacher
teacher's picture
Why did they use the wider beam in the CO1 instead of the more narrow beam?
If this has been discussed I missed it.
defloyd77
Last seen: 18 hours 49 sec ago
If I remember correctly, Sofirn goofed up and ordered the 60° Yujis instead of a narrower one.
dealgrabber2002
It would have been the perfect light for me had they use a narrower one.
teacher
teacher's picture
Ouch…. Facepalm
Random Dan
Last seen: 5 days 20 hours ago
Ouch…. Facepalm
The 60 were supposedly the only ones available
jon_slider
Yes Sofirn is using 60 degree Yuji’s
djozz wrote:
Before I got these samples I was concerned by the wide 60 degrees leds but now I like that nice even floody beam, it is really pleasant and nothing like the ugly Fenix E01 beam.
fwiw, the McGizmo Sapphire also offers a 60 degree Yuji.. we are in good company Wink
The E01 beam is not to my liking at all, plus the tint sucks, and it has terrible CRI
the C01 beam is MUCH nicer in every way
Gunga
Gunga's picture
Last seen: 1 hour 3 min ago
I’d buy a titanium or titanium / brass one.
wolfstyle
Last seen: 53 min 18 sec ago
Titanium/ Copper would be good.
