BLF Interest list for Very High Current Beryllium Copper springs Pt1(ENDED)
722 posts / 0 new
BlueSwordM
BlueSwordM's picture
Last seen: 2 min 3 sec ago
Perhaps. But your lights are an absolute monster. Even my springs won’t be able to handle 25A each.
I’d love to make a spring that can handle even higher power. 1.2mm wire diameter, 15mm height to account for 21700 support, Beryllium Copper C17510 60% IACS, etc.
That would be one heck of a spring, and even a wire bypass would be jealous. Could probably handle 25A+, unlike my 15A spring.
BlueSwordM
Also, I will PM you guys gradually, so you guys don’t need to PM me.
Sorry again.
DB Custom
DB Custom's picture
Last seen: 32 min 32 sec ago
Uh, one spring at the top end of the series 21700 pair, so this driver spring is handling close to 50A here. I had to use a $25 Tofty switch which has a 1/4” brass screw for contact.
My first build will probably be in an Eagle Eye X6 to 4 Samsung LH351D’s, that should be more down these springs alley. I need to build up a driver, have the emitters on the new Noctigon 33mm Quad MCPCB so I’ll be ready when the springs arrive, hosts should be in hand by then as well. I don’t know what these new Samsungs can pull, 15A or so?
Edit: It won’t be that high, tested outside of a light direct drive to an LG HE4 fresh off the charger it pulled 11.38A to the 4 Samsungs, so the springs should easily deliver what they need.
BlueSwordM
Ooops. Thought you made a 2S2P light because you said you put 2×21700 in series, and thought you put 4 cells in total.
And they will probably pull 13-15A at that power level. So probably 4500+ lumens.
DB Custom
DB Custom's picture
That light is 3 XHP-70.2, it makes 20,000 lumens. Wink
I’m going to build a quad X6 and use these new springs, single 18650. Direct drive shows less than 12A so it’ll be all right.
Also, once I get components together, I plan to use 9 of these Samsung emitters in a 4P 18650 Sofirn SF34 (like an SRK) with a BLF Q8 driver, so I’ll use 4 of these large springs on the tail board and see how they do there. It’s making 5000+ lumens with XM-L emitters on an aluminum MCPCB and stock springs. Wink
Chatika vas Paus
Last seen: 2 min 11 sec ago
BSM when we can expect small springs? And shipping both at all?
BlueSwordM
When I’ll come back from vacation, I will order the small springs right away, and ship them as quickly as possible.
shirnask
shirnask's picture
Last seen: 3 min 48 sec ago
Thanks, have a good trip
Chatika vas Paus
Thanks. I just can’t wait Smile Have a nice holiday
Texas_Ace
Texas_Ace's picture
Last seen: 2 hours 48 min ago
My springs just showed up today! They look good and are real heavy duty. The nicest springs I have used that is for sure.
BlueSwordM
Yeah really nice springs.
I’d love to hear what are your thoughts on them by putting them in a real light, as springs behave differently when connected to a cell rather than a constant current load.
Texas_Ace
Texas_Ace's picture
Yeah, I am not sure what light to put them in, I have a new to me MT09R here that I might try them in, although I think I would double up on that light with the small springs as well, so I might wait for them. Otherwise I don’t have any un-modded lights here to put them in lol. I have not ordered a flashlight in almost a year. Just the prototypes I have been sent during testing.
DB Custom
DB Custom's picture
I have no qualms about modding modded lights, will have a spring party when mine arrive. Wink
vinte77
Last seen: 2 hours 5 min ago
Is it worth the time to replace all the springs in my existing lights with these new springs? Including the bypassed springs that I have? Or should I just save them for new lights? I’m curious as to what people think and are planning to do with their springs.
Texas_Ace
Texas_Ace's picture
It depends on what you want to do.
In my case the lights that are working properly will not gain anything with these springs since they already have bypasses, so there is simply no reason to pull them apart and swap them out.
Now going forward I will most likely swap these springs onto any new lights I built or during any repairs.
I tend to follow the if it ain’t broke and it will not gain anything, then don’t fix it mantra.
BlueSwordM
Yeah. Personally, I would only replace stock springs with bypasses if I either had two lights to compare light output between bypassed and high conductivity springs.
Or a light with a replaceable tailcap. Like the Q8.
However, I like these springs way better than any spring I’ve ever had my hands on. Not solely because they have very high conductivity for springs, but mostly because they are so easy to solder to compared to non copper alloy springs.
Trying to do bypasses on steel springs, is let’s just say, mind nerving and very annoying to do, since the chromium surface and steel itself form oxides and don’t adhere to tin well, if at all without flux.
Texas_Ace
Texas_Ace's picture
Hmm, I was thinking and I have 2 MT09R’s here. So I could have a direct comparison between 5x bypasses vs 5x of these springs in the same light. If I have some time next week I will try to do that.
vinte77
That would be great! I adhere to the “if it ain’t broke, don’t fix it” philosophy but that BLF modder in me can’t leave things alone if I know that the springs will yield me some more light (but I’m lazy enough that it has to be enough light to make it worthwhile).
Mark M
Mark M's picture
Last seen: 1 month 5 days ago
I will take 30 small springs, let me know if you ever order more large springs.
JasonWW
JasonWW's picture
Last seen: 35 sec ago
Wouldn’t you need to use the same head and just swap the battery tubes? Two different heads could vary a lot.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
Texas_Ace
Texas_Ace's picture
Yes, that is what I was thinking. Although I guess the 5th spring would not be part of the comparison come to think of it.
This should push the springs to the limit though, I might need to wait for the dual springs. At max power each spring would need to handle 15-20A.
moderator007
moderator007's picture
Last seen: 4 min 45 sec ago
We won’t know until somebody tries it. Big Smile
Update: I hope you know TA I was only kidding, I wouldn’t want you to weld your new springs
to the bottom of some perfectly good batteries. Big Smile
JasonWW
JasonWW's picture
After testing both battery tubes, then swap the driver spring.
Texas_Ace
Texas_Ace's picture
Yeah, there are some possibilities. I ordered some LED’s for the MT09R today, if I get some time I will put it together.
BlueSwordM
So, other than TA, has anyone received their springs or not?
Tom E
Tom E's picture
Last seen: 1 min 20 sec ago
These still available? Can I get qty 50? Didn't sign up for them, just heard about this.
DB Custom
DB Custom's picture
If for whatever reason you miss out on these here Tom I got enough that I can share some with you if you’d like. Wink
CNCman
CNCman's picture
Last seen: 3 days 3 hours ago
Tom E wrote:
These still available? Can I get qty 50? Didn’t sign up for them, just heard about this.
I have a 50 pc order that I can split with you, 25 pcs. Beer
CNC & Manual Machinist. Think outside the box too long , cannot find your way back in.
Good Intentions are no guarantee for Good Results.
BlueSwordM
I’ll also spare 25pcs for you TomE.
vestureofblood
vestureofblood's picture
Last seen: 10 hours 14 min ago
BlueSwordM, Would it be possible to order a batch of springs like this that will fit the switch tower of a maglite?
I would pay for the 2k batch. The dimensions of the spring are
L: 32.76mm
OD: 8.15mm
Thickness: 0.83mm
The most critical dimension there is the OD since there are metal caps that go over each end we cant go larger. Any of the others could be adjusted a bit as needed.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
