BLF Interest list for Very High Current Beryllium Copper springs Pt1(ENDED)
722 posts / 0 new
teacher
teacher's picture
Last seen: 26 min 33 sec ago
BlueSwordM wrote:
So, other than TA, has anyone received their springs or not?
Nothing yet, but I am expecting them to show up any day now. Smile
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 6 hours 46 min ago
If the offer still stands i would be in for 20 big springs and 10 small (if shipping is not to much)
BLF D 80 LT and Longer D80 Tubes for Sale http://budgetlightforum.com/node/62463
Jtm94
Last seen: 1 day 23 hours ago
I’ve been a little absent looks like everything worked out!
So if I understand it’s 30 cents per small spring + 5% for paypal for US orders?
If so bump my order up to 16 springs and inbox me when you have the time. Thumbs Up
Matchoo
Last seen: 1 hour 37 min ago
I wonder if it’s too late to ask for 10 of these springs? I’m about to take the leap into modding my first flashlight! Thanks so much.
JasonWW
JasonWW's picture
Last seen: 2 hours 16 min ago
All 2000 big springs have been sold. There are still some small springs available.
LichtAn
Last seen: 4 weeks 1 day ago
Is there a second batch planned anytime?
BlueSwordM
BlueSwordM's picture
Last seen: 4 hours 36 min ago
Probably after I sell both the 1st batch big and small springs.
I will also tweak the design for slightly higher current using slightly thicker wire at 1,1mm, and a better coating, probably gold if we can afford it.
The main difference would that I would make a 5000pcs batch instead of a 2000pcs batch since I have a battery holder project in the works that could be amazing!
My very own high current Beryllium Copper springs: http://budgetlightforum.com/node/64047
vestureofblood
vestureofblood's picture
Last seen: 11 hours 14 min ago
vestureofblood wrote:
BlueSwordM, Would it be possible to order a batch of springs like this that will fit the switch tower of a maglite?
I would pay for the 2k batch. The dimensions of the spring are
L: 32.76mm
OD: 8.15mm
Thickness: 0.83mm
The most critical dimension there is the OD since there are metal caps that go over each end we cant go larger. Any of the others could be adjusted a bit as needed.
In Him (Jesus Christ) was life; and the life was the light of men. And the light shineth in darkness; and the darkness comprehended it not.
http://asflashlights.com/ Everyday Carry Flashlights, plus Upgrades for Maglite.
DB Custom
DB Custom's picture
Last seen: 4 hours 6 min ago
Hey Matt? Will it help to gain electrical conductivity in replacing that spring when the ground is still the long steel contact slider? It only makes surface contact on the outside of that pillar, gotta be losing a lot there. I know it is as I just built up a triple in a chopped 1D and am not impressed with the result, even bypassing that center spring, pretty sure if I rig a bypass around that ground it’ll do a LOT better…
vestureofblood
Yes, bypassing that little strip would also help. Part of the reason I want to get the springs is also because under 8 amp continuous load sometimes the factory ones loose their spring. The internal switch contacts seem to hold up better than it. In the fully assembled lights I sell I always wire bypass it but that gets tiresome quick Smile
teacher
teacher's picture
http://budgetlightforum.com/comment/1359467#comment-1359467
Wed, 08/01/2018 – 15:33…………. #358
BlueSwordM wrote:
Well, I finally shipped the springs to 4 people now:
- DBCustom
- teacher
-Texas Ace
- vestureofblood
(snip)
http://budgetlightforum.com/comment/1363542#comment-1363542
Thu, 08/09/2018 – 15:33……….. #371
Texas_Ace wrote:
My springs just showed up today! They look good and are real heavy duty. The nicest springs I have used that is for sure.
@ DB Custom & vestureofblood……. Have either of you received your springs yet??
TA’s were delivered to him 8 days ago. I have nothing yet & wondered if it was just me.
All 4 of our springs were shipped at the same time and although a few hundred miles apart for some of us, we are all in the same area of the USA.
Just curious & hoping my springs were not eaten by a wild hog… Big SmileBig Smile
Texas_Ace
Texas_Ace's picture
Last seen: 7 hours 20 min ago
I installed one of these springs in an SC26 the other day but since it uses a boost driver all I can really report is that it solders fine and held up to the moderate power fine.
Have not had time to mess with the MT09R yet.
DB Custom
DB Custom's picture
I haven’t seen my springs yet, was thinking maybe today? I’m only a 2 hour drive from TA, seems odd that the packages are so far apart…
Texas_Ace
Texas_Ace's picture
It is strange indeed, I was really surprised when mine showed up so fast, I did not expect them until about next week to be honest.
vestureofblood
Mine are not here yet. Not worried at this point though. For me to mail a letter to a town 30 miles away, often that letter goes clear to St Louis. (passing thought that town on the way) and then back.
teacher
teacher's picture
Alright gentlemen, thank you for the info. I just wanted to make sure I was not odd man out. Wink
Yours does indeed seem very “odd” ‘DB’ since you are only 2 hours from TA…. VOB & mine are slightly less “odd”.
Maybe USPS reverted to Pony Express for ours. Big SmileBig SmileBig Smile
BlueSwordM
@AFS, I saw your request for your springs. I’ll try to do a drawing for it Sunday.
Also, I really hope you all receive your springs in due time, especially since TA already received them.
I also took all pictures of the packages, and the shipping labels correspond perfectly with the addresses you all gave me.
teacher
teacher's picture
Not doubting you at all BSM. Smile . It is just weird that TA got his over a week ago & the rest of us have nothing. Just goes to show the inconsistencies that can occur with shipping & receiving….. With no apparent rhyme or reason considering they were apparently all shipped at the same time on the same day. Big Smile
vestureofblood
Look forward to the drawing. +1 for what Teacher said. I don’t think anyone is doubting you sent them etc. The fact that you still show up to the thread is evidence enough for me Smile
DB Custom
DB Custom's picture
For me, things usually go to Dallas TX and then straight by here to Austin, TX and back to me. I’m about in the middle between Austin and Dallas (actually about a third of the way, closer to Austin…60 miles to Aus and 120 to D/FW) but the big trucks carry things between hubs then smaller trucks carry things to the towns. So it would be fairly normal for there to be a day or two difference once something hit’s Dallas and then to get here. A week? That’s odd. But then, this is the USPS we’re talking about and I’ve seen things ship to Florida then back to Dallas then to Austin and to me, when Florida was 1000 miles out of the line. Go figure.
Edit: To clarify on that, I’ve seen a package go from Illinois to Dallas, then to Florida, then back to Dallas, then to Austin and then to me. A machine read the zip code wrong. Happens all the time. With all the Automated stuff these days a smudge or bit of dirt and zoom! Off to the races…
BlueSwordM
Yeah. I know you guys are probably going to get your springs, hopefully.
BTW, I’m finally going to get a DPS5015 buck power supply so I can finally test the spring at higher currents, as my current power supply is limited to 6A before the voltage collapses down from 4V to almost nothing.
Also, I finally came back from my trip. I went to the Czech Republic as a stop, then directly to Turkey, back to Czech Republic, and then to Germany in Berlin, and then back to Prague in the Czech Republic and back to Canada.
It was a truly wild ride.
@DBCustom, wut? How could they actually miss a packet by that huge distance?
teacher
teacher's picture
That does sound like a “wild ride” BSM, I hope you enjoyed it thoroughly!! Smile
djozz
djozz's picture
Last seen: 10 hours 14 min ago
Interesting journey choices, certainly not mainstream. (kind of like Dale’s packages Smile )
BlueSwordM
Ok guys.
I just realized 2 things.
1. I completely forgot about Mr.Scott’s spring order, and by adding TomE, AEDe, and the TheOnlyDocc to the order list, there are only 25 big springs left for Mr Scott. We are at literally 1975 springs, which is the reason why I wanted to stop the group buy, so I could get myself 100 springs, but I split up my order by half so TomE, and TheOnlyDocc, along with AEDe could get them. So MrScott will only be able to get 25 big springs.
2. What kind of spring would your prefer as a smaller spring?
- One like the Fasttech Carobronze spring, only with thicker wire, a wider top, and less coils so there can be more spring movement while not sacrificing too much mechanical strength, while still being way better mechanically than the Carobronze spring, according to my calculations.
- One like an almost symmetrical driver spring.
The 1st choice would allow for a dual spring amount, and would allow for a full 20-23A of current to pass through a single entry point, rather than 13-15A like my current spring.
You could use it as a smaller spring, but you would have to flip the top and the bottom to allow it to fit single side driver boards.
The 2nd choice would allow for universal compatibility, but making it much harder to incorporate as a dual spring.
What do you think?
Also, the list has been updated.
Edit: The first point is null now.
Texas_Ace
Texas_Ace's picture
If needed I can give up some of my springs
I totally want option #1 for the small springs so I can use them as dual springs. In fact go ahead and up my small spring order to 100 total springs please if this is the case so I can use them all as double springs.
MRsDNF
MRsDNF's picture
Last seen: 4 hours 1 min ago
The Fasttech springs sag real quick.
shirnask
shirnask's picture
Last seen: 40 min 11 sec ago
You recently added 5 large springs to my order – its not much but you can take those off my order
skinny_tie
Last seen: 14 min 37 sec ago
BlueSwordM you can take 8 big springs off my order if that helps make up the shortfall.
JasonWW
JasonWW's picture
BlueSwordM wrote:
Ok guys.
Wouldn’t this mean that TheOnlyDocc, the last person, has asked for springs that are not available?
BlueSwordM
Yeaaah. However, I was willing to take off some of my springs so everybody could have them at least.
This is why I wanted to stop at 1950 springs: in case there are problems, there would still be springs that could be shipped.
Edit: Maybe I should have changed the title when I closed the GB. My fault. Facepalm
Also, there is a good reason for why the Fasttech Carobronze spring sags electrically and mechanically:
it has a way too wide top diameter, thinner wire, and probably uses a lower electrical grade phosphor bronze at 15% IACS vs the C54400 19% IACS of the djozz springs. It also has a bit too many coils. Removing one while widening the top diameter would help a bit in terms of mechanical strength.
Edit 2: I’m way too soft. I should have refused for his spring demand.
@shirnask and skinny-tie, I will put some extra things in your order so you will still have some good things in your package. Brass buttons and perhaps, some small extras Thumbs Up
@Mr.Scott, I’m really sorry for forgetting about your order. I’ve corrected the error now.
Edit 3: TheOnlyDocc, out of kindness and patience, will wait for the next batch. So you can get your springs back.
