ENEDED
303 posts / 0 new
HONDARIDER
HONDARIDER's picture
Last seen: 1 week 2 days ago
Seems inexpensive enough. I’ll take one.
BlueSwordM
BlueSwordM's picture
Last seen: 8 min 28 sec ago
Wait, the tube is titanium and the head is aluminium right?
If so, I am interested in having the light.
geetee03
Interested.
sherman2k
Last seen: 1 year 3 months ago
interested
freeme
freeme's picture
Last seen: 2 hours 45 min ago
Deal is alive now!
Please wait for our pm...
djozz
djozz's picture
Last seen: 1 hour 5 min ago
Interested after all! Smile
Phantom1
Last seen: 7 months 1 week ago
interested
freeme
freeme's picture
I just finished running some errands. I will send out in 2-3hrs time. Our AT40 group buy price is $27.99!!
However, there are some things that you guys need to know about AT40 before you make your purchase:
  1. Light consume about 3A max from tailcap reading on HIGH.
  2. Actual output seems to lower than 1200lm when I compare to other 1000lm lights. Need to reconfirm again.
  3. Temperate reaches high temperature of ( XX°/ XX F) in few minutes time.
  4. Limited modes - Low, Mid, High
  5. Amutorch is known for their B grade finishing/ quality.
  6. Plastic aspherical lens. You might be able to look for a replacement if lucky.
  7. Bezel no sealed.
  8. Manual in Chinese.
djozz
djozz's picture
I’m actually looking for a 3A light and not more, for using an Optisolis quad in it, so the limited power is an advantage for me.
With the lens as a flooding optic, scratching it will not be harmfull to the beam, it may even improve it over time.
It looks like the bezel can be sealed with 1 or 2 o-rings, a bit weird that it is not designed like that.
SKV89
Last seen: 26 min 8 sec ago
Isnt 3A too much for the Optisolis which Clemence said should be limited to 0.5A each emitter so we should be looking at 2A. I also wonder if the screw locations will fit the 21mm optisolis board. Freeme do you know the diameter of the pcb?
djozz
djozz's picture
750mA per led is steep but my test shows that they can handle it, at least for a short while Big Smile
I’m not going to use an Optisolis board but a 20mm XM-board, like I did with my S2+ with Optisolis.
http://budgetlightforum.com/node/59478
freeme
freeme's picture
Nichia vs XP-G3
freeme
freeme's picture
If the response is good for AT40, i will get them to prep for AL1. cool
MascaratumB
MascaratumB's picture
Last seen: 4 hours 8 min ago
freeme, how much moddable is the light? Is there room to use a Carclo optic + lens above the MCPCB?
Also, is the driver: a) 20mm diameter and b) glued ?
BTW, what do you mean by “B finishing grade”?
Thank you in advance Wink
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
freeme
freeme's picture
Some measurements for references. Carclo Quad Optic is 24mm x 7.5mm from Hank's site.
MascaratumB wrote:
*freeme*, how much moddable is the light? Is there room to use a Carclo optic + lens above the MCPCB? Also, is the driver
My unit did come with minor dings. Some people may feel that this is "unacceptable" for modern manufacturing. cool
MascaratumB wrote:
BTW, what do you mean by "*B finishing grade*"? Thank you in advance ;)
SKV89
Thanks for the info. It may actually work with the 20mm 4x noctigon boards or the 21mm optisolis boards from clemence. Probably need a washer under the screw, but there will be a annular gap so might not be pretty.
g_damian
g_damian's picture
Last seen: 9 hours 43 min ago
Tried to order from link provided in PM, but Banggood says: “Under Restocking”. Why?
Firelight2
Firelight2's picture
Last seen: 3 min 56 sec ago
Interested
teacher
teacher's picture
Last seen: 6 months 3 weeks ago
g_damian wrote:
Tried to order from link provided in PM, but Banggood says: “Under Restocking”. Why? Sad
Yep… I was gonna order the 4 Nichia version but a pop-up said “No Stock”.
So I guess the answer is… none are in stock at the moment. Big Smile
shirnask
shirnask's picture
Last seen: 2 hours 33 min ago
I asked to be put on the list in Post #138 – did not get a pm
geetee03
Would like to buy one unit.
MascaratumB
freeme wrote:
Some measurements for references. Carclo Quad Optic is 24mm x 7.5mm from Hank’s site.
MascaratumB wrote:
freeme, how much moddable is the light? Is there room to use a Carclo optic + lens above the MCPCB? Also, is the driver
My unit did come with minor dings. Some people may feel that this is “unacceptable” for modern manufacturing. cool
MascaratumB wrote:
BTW, what do you mean by “B finishing grade”? Thank you in advance Wink
Thanks for your answer and photos freeme Wink I guess this would be nice for a mod.
About those “dings” Facepalm …I guess Amutorch is failing a bit in finishing lately Sad Too bad because they have excellent anodizing and finishing in other lights. Is it possible that you got a sample and not a “final” model?
We gotta tell Shirkey about this so that they improve these aspects…
Thanks again!!
OL Contest 2019
GIVEAWAY: 1 / 2
freeme
freeme's picture
Cannot fit protected cell.
vresto wrote:
question-is possible to use protected? is it not too low output for 4 nichias? 1200 lumens?looks very nice this torch..
bansuri
Last seen: 34 min 19 sec ago
Thanks Freeme! Gave me a “preorder” option, good enough. I’ve paid more for less, this looks like a winner for the price!
Like the look and idea behind the cast aluminum head.
freeme
freeme's picture
Fixed.
g_damian wrote:
Tried to order from link provided in PM, but Banggood says: "Under Restocking". Why? :(
shirnask
shirnask's picture
Preordered the 4 Nichia version
Thanks freeme
geetee03
Pre-ordered the nichia, pretty happy. Thanks.
g_damian
g_damian's picture
Preordered. Thanks!
Just a Guy
Last seen: 3 weeks 2 days ago
I placed my pre-order for one 4 x Nichia.
Thanks!
djozz
djozz's picture
I got an email that mine is shipped.
I’m sorry about that, I was about the last to sign up and apparently the first to order, I guess they had just a few in stock.
