ENEDED
303 posts / 0 new
g_damian
g_damian's picture
Last seen: 4 hours 59 min ago
Got mine. Unfortunately DOA: http://budgetlightforum.com/node/61852
AgentWhiteBread
If I could get a code for the AT40 nichia?
Please and thank you!
freeme
freeme's picture
Last seen: 21 hours 37 min ago
With the sudden surge in demand, QC issue can arise from smaller manufacturers is inevitable. If you got a DOA, just contact customer service for full refund.
bansuri
Last seen: 33 min 18 sec ago
Ugh, jelly from all who’ve received theirs. Mine is stuck at this: 2018-07-22 11:26 Origin Post is Preparing Shipment
I DO appreciate all your comments and pictures though!
will34
will34's picture
Last seen: 1 week 4 days ago
Got mine today.
The good:
-Much better build quality than expected
-Decent output and lots of room for modding
-Nothing is glued (except for driver)
-The clip is extremely solid
-Aluminum pill does an good job, but this light is not ready for some FET action. I’ll be keeping the stock driver.
The bad:
-Rear switch doesn’t have a spring but a brass plate that is very thin and rather large in diameter, so if you’re using batteries that are wrapped a bit more towards the center or have double wrapping it won’t work. Maybe this is why many are reporting DOA units. Fortunately that can be fixed with a spring but you’ll have to take the light apart.
-Front oring needs to be thicker
For those who can’t remove the tail cap, it’s most likely the clip that is pressing against the body. Just take off the clip and you’re good.
Overall a very nice flashlight and great value for the money. I’m modding mine soon and post the outcome here.
pinkpanda3310
pinkpanda3310's picture
Last seen: 11 hours 9 min ago
I wondered what was going on with my light last night. Turned out to be low voltage warning. Last night I checked the battery and it seemed to kick in the warning (on high mode) about 3.6v. Today at work I played with it again and the frequency of the dimming seems to have increased as the voltage gets lower. I don’t know if the light will shut off at some point and am reluctant to run the battery down to find out as it is unprotected and I have no multimeter or charger to check the battery voltage.
Low the voltage higher the frequency
Edit: when I was able to check battery voltage I kept running the light. Voltage got down to 2.7v with no shut down.
teacher
teacher's picture
Interesting…. thanks pinkpanda3310!! Thumbs Up
Good video & good music…… Beer
Cereal_killer
Cereal_killer's picture
Thanks for the disassembled view, can you easily get a photo of the pill / what’s under the MCPCB.
ErgonHilux
ErgonHilux's picture
HELP!
I just got my Amutorch AT40 Nichia from the mail and its DOA! It is Not working… Can somebody tell me what can possibly be wrong with it? I’ve searched the internet and it seems to have some problems and I just can’t get it to light up… Sad Thanks in advance!!!
djozz
djozz's picture
Last seen: 8 hours 6 min ago
ErgonHilux wrote:
HELP!
It is DOA is always a very difficult question to answer. It helps enormously if you start by checking the obvious yourself first (like does the battery make contact on both sides)
teacher
teacher's picture
ErgonHilux wrote:
HELP!
As dojzz said… check battery connections. Especially at the rear switch.
See the quoted post below for more info.
http://budgetlightforum.com/comment/1363337#comment-1363337
Thu, 08/09/2018 – 09:15………. #247
will34 wrote:
Got mine today.
The good:
The bad:
  • -Rear switch doesn’t have a spring but a brass plate that is very thin and rather large in diameter, so if you’re using batteries that are wrapped a bit more towards the center or have double wrapping it won’t work. Maybe this is why many are reporting DOA units. Fortunately that can be fixed with a spring but you’ll have to take the light apart.
ErgonHilux
teacher wrote:
ErgonHilux wrote:
HELP!
will34 wrote:
Got mine today.
The good:
The bad:
Yes, I’ve checked and both positive and specially the negative on the tail do have contacts. I’ve also checked to see if the battery is working and it is working.
teacher
teacher's picture
Darn… was hoping that would be it. Sad … Have you got voltage to the LED’s?
teacher
teacher's picture
Are all the ‘extras’ in the picture below supposed to be included in the box?
Mine only had 2 O’rings & a switch cover… nothing else.
It arrived DOA also. Facepalm . Oh well…. Wink
I have not had a chance to check it out yet, besides the battery making proper contact…. it is too. Hopefully today I can check it out further.
Unloco
Last seen: 3 hours 51 min ago
teacher wrote:
… Mine only had 2 O’rings & a switch cover… nothing else. …
Mine too.
teacher
teacher's picture
Unloco wrote:
Mine too.
Hmmm… Ok, thanks for that info. Thumbs Up
Did yours work?? If so you are ahead of me…… Wink
BlueSwordM
BlueSwordM's picture
Last seen: 1 hour 28 min ago
I’m quite dissapointed by its build quality along with the lack of using R9050 Nichia 219Cs.
teacher
teacher's picture
/\…. Thumbs Up
freeme
freeme's picture
I got mine from Amutorch direct. I didn't know they packed differently for their resellers.
@will34 suspect it is the tailcap switch giving the problem. See if you are able to power up the light by connecting the tube and battery cathode with a wire?
teacher wrote:
Are all the _'extras'_ in the picture below supposed to be included in the box? Mine only had 2 O'rings & a switch cover... _nothing else_. !{width:100%}https://freedailydeals.org/wp-content/uploads/2018/06/freedailydeals-201...! . It arrived DOA also. Facepalm . Oh well.... Wink I have not had a chance to check it out yet, besides the battery making proper contact.... it is too. Hopefully today I can check it out further.
Unloco
teacher wrote:
Unloco wrote:
Mine too.
Mine works fine.
According to the lock review, it does not work with long batteries.
Quote:
Using particularly long batteries, it will not be possible to completely screw the head, therefore the light would be unusable.
Edit: It doesn’t work with 30Q button top , this battery is too long.
teacher
teacher's picture
Unloco wrote:
teacher wrote:
Unloco wrote:
Mine too.
Mine works fine.
Edit: It doesn’t work with , this battery is too long.
Good, glad yours works. Thumbs Up .. Nice review you linked to also.
Sadly, long batteries are not my problem…. mine just does not work. Smile
MascaratumB
MascaratumB's picture
Last seen: 2 hours 13 min ago
teacher wrote:
Good, glad yours works. Thumbs Up .. Nice review you linked to also. Sadly, long batteries are not my problem…. mine just does not work. Smile
Can it be any connection on the top (head, driver, MCPCB), not the tail? Hope you can solve it and put back to work! Thumbs Up
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
teacher
teacher's picture
Well… I took it apart, checked all the connections, gave it a good cleaning, put it back together, and it works just fine now.
Pretty neat light too…… Thumbs Up
MascaratumB
teacher wrote:
Well… I took it apart, checked all the connections, gave it a good cleaning, put it back together, and it works just fine now. Pretty neat light too…… Thumbs Up
Eheh, you know what they say: “from dusT till dawn” Big Smile Cool
I’m glad it works now Wink Hope you enjoy it mate Beer
OL Contest 2019
GIVEAWAY: 1 / 2
teacher
teacher's picture
Yep… that about sums it up. Wink
And thank you my friend… I am liking it pretty well. Thumbs Up . Wink
JasonWW
JasonWW's picture
Last seen: 25 min 22 sec ago
SKV89 wrote:
I also saw an Amutorch 26650 version of the Sofirn C8F
I think you mean the Sofirn C8F is an 18650 version of the Amutorch 26650 which a “copy” the Shadow SL-3 which came out way back in 2012.
Pardon if this was already mentioned, I haven’t read the whole thread.
Click this to go to signature links.
MascaratumB
Amutorch and Shadow are the same company, just renamed Wink Maybe the similarities come from that Wink
OL Contest 2019
GIVEAWAY: 1 / 2
nfetterly
nfetterly's picture
Last seen: 8 months 3 days ago
Please pm me code, thanks in advance.
freeme
freeme's picture
Anyone still facing QC issue for this model?
freeme
freeme's picture
All replied.
