GearVita Daily Deal: Boruit D25 Double-head LED Headlamp with Detachable Design
87 posts / 0 new
cathy
cathy's picture
Last seen: 36 min 40 sec ago
The Sunwayman C41CT flashlight is a compact and powerful EDC light featuring a stylish design. Weighing less than 4 ounces and measuring just 4.33 inches long, this flashlight is easy to store in your kitchen drawer or carry with you wherever you go! The torch's unique body is constructed from aerospace aluminum alloy and comes with a unique wavey knurling for a secure grip, also it is completely waterproof, so it's safe to use in any weather conditions. The Sunwayman C41CT can be powered by either a pair of CR123As or a single 18650 and can even be recharged internally when equipped with a 18650. When charging, the side switch doubles as an LED power indicator, letting you know when it's fully charged. The flashlight can emit up to 1000 lumens of light, provide up to 60 hours of runtimeand can produce a total of 6 outputs to cover any lighting needs.
Main Parameters:
LED: CREE XM-L2 U3
Color BIN: Cool white
Power Source: 1 x 18650 or 2 x CR123A
Max Output: 1000lm
Peak Beam Distance: 307 meters
IPX Rating: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 1 meter
Outputs Mode:
Turbo - 1000 lumens
High - 580 lumens ( 150 mins )
Med - 130 lumens ( 800 mins )
Low - 16 lumens ( 3600 hours )
Two Hidden Modes: Strobe and SOS
Product Features:
● High quality LED of CREE XM-L2 U3, with lifespan up to 50,000 hours.
● Rugged anodized aluminum body is waterproof.
● Unique wave knurling provides secure grip.
● High-powered LED and smooth reflector provide maximum throw.
● Pair of tactical outputs for emergency situations.
● Easy-to-use pushbutton side switch lets you effortlessly cycle through outputs.
● While equipped with 18650, light is internally rechargeable through micro-USB charging port.
● Side switch doubles as LED power indicator, flashing green while light charges, glowing solid green when fully charged.
● Constant current circuit, uses one single 18650 battery or two CR123A batteries.
● The circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Reverse polarity protection prevents damage caused by improperly inserted batteries.
● Tail-stand capable, can be used as a lamp.
● Waterproof accords with IPX-8 standard.
● Memory funtion, the last mode used will be memorized for next time use.
Compact and versatile, the Sunwayman C41CT rechargeable LED flashlight is a powerful light that features all the qualities in a top EDC. Take the coupon code "SWMC41CT" before Oct 20th, get this top EDC flashlight from GearVita with the coupon price of $45.99: https://gearvita.com/sunwayman-c41ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-g20c-tactical-led-flashlight-1000-lumens.html
https://gearvita.com/sunwayman-c23c-multi-functional-flashlight-1000-lumens.html
sunwayman c41ct flashlight
Best Brand Consumer Electronics Provider GearVita
cathy
cathy's picture
Mi IR night light is equipped with an infrared motion sensor with up to 120-degree and 7-meter motion detection range. Using advanced photosensitive sensor and human infrared sensor technology with anti-infrared interference function, the sensor instantly reacts to the movement and turns on the light. It will last 15 seconds after you walk out of the sensing area. The Mi IR light is powered by batteries and making it a low power consumption, energy-saving and environment-friendly device.
Product Features:
● Extraordinary Sensing Function
120-degree sensing angle and sensing distance is 5 to 7 meters. Adopting light-sensitive and body infrared induction technology, the light can turn on automatically in the dark environment, 15 seconds duration, with anti-infrared jamming function.
● Two Brightness Modes
There are two brightness modes to switch: with 0.7 lumens mode and 3.8 lumens mode, you can adjust the brightness according to your needs.
● Extremely Low Power Consumption
Powered by 3 x AA battery, free you from socket trouble. The choice of ultra-low power consumption of the sensing program ensures only 0.25mW power consumption when in standby mode. 0.7 lumens mode can be used for about 12 months, 3.8 lumens mode can be used for about 6 months time.
● Safe Environmental Material
Selecting environmental-friendly ABS material and high-density polyethylene material, the light has a small body with flexibility, which is more durable, practical and safer.
● No Socket Constraint
With 3m glue on its back, you can stick it on wardrobe, stairs, bedside, etc. And it has an adjustable hook, provides brightness for you anytime.
● Soft Warm Light
2700K color temperature without visible strobe lights, protect the vision of your eyes especially your baby's eyes.
● Cool Lampshade
Total reflection structure of fish scales, can make the light equably reflect to the diffusion shell, provide a good visual experience for families.
● Freshnel Ultra-thin Lens
Equipped with a Freshnel ultra-thin lens which enhances the performance of the sensor.
● Minimalist Design Adds Unique Flavor to Life
The light adhering to minimalist design style, external soft round design encounters silkily-touching edge, easily matches with a variety of furniture style.
When talking about an ordinary night lamp that turns on when motion is detected, it wouldn't gain much attention from most human beings. Fortunately this is not just a night lamp running on AA batteries, it is an original Xiaomi Mijia night light! Never bump your foot in the middle of the night again for it can be put anywhere in your home. Apply coupon code "MIYSENSOR" on GearVita to get this night light with the price of $7.99: https://gearvita.com/xiaomi-mijia-yeelight-sensor-night-light.html
Related products:
https://gearvita.com/seenda-dual-usb-port-wall-charger-with-led-light.html
https://gearvita.com/official-international-version-yeelight-ylfw01yl-smart-atmosphere-candela-light-support-bluetooth-control.html
mijia sensor night light
cathy
cathy's picture
Sunwayman C22CC is an inventive flashlight, which uses the 18650 battery, the two lights equipped can work as well as simultaneously. C22C comes with charging instructions and low voltage protection, full care of flashlight "heart" to make it healthy. The main light can be controlled by a button, it's easy to operate and hand feel smooth. Unique side light can be used as a corner lamp which is full of yellow ray, so it is suitable to read at night or at camping. The head of Sunwayman C22CC flashlight is designed with multi-slot to make it cool, so that effectively increase the cooling effect. The charging's design of flashlight's tail is hidden in extreme to make the whole flashlight more beautiful and easy to use. The stainless steel attack head is located in the tail, and install a quick hole, so it can be connected to universal tripods quickly to meet various function's request.
Main Parameters:
Emitter: Cree XM-L2 U2 LED(primary), Cree XP-G2 R5 LED(side)
LED Lifespan: 50,000 hours
Estimated Usage Time: 42 hours
Luminous Flux: 820 lemens
Beam Distance: 310 meters
Battery: 1 x 18650 or 2 x CR123A or 2 x 16340
Waterproof: IPX-8 (waterproof and submersible up to 2 meters)
Impact Resistant: 2 meters
Output Modes and Runtime:
● Primary Light
Turbo (820 lumens) - 3 minutes
High (510 lumens) - 2 hour and 10 minutes
Mid (130 lumens) - 10 hours
Low (35 lumens) - 42 hours
Strobe
SOS
● Side Light
High (160 lumens) - 5 hours
Mid (46 lumens) - 13 hours
Low (16 lumens) - 68 hours
Product Features:
● Main light Cree XM-L2 U2 LED, side light Cree XP-G2 R5 LED, with a lifetime of up to 50,000 hours.
● High quality metal smooth reflector for main light maintains great throw diatance and spread with an ideal beam pattern, able to generate an 820 Lumen beam that can reach over 1000 feet away.
● Special secondary side LED produces up to 160 lumens of soft white light for close-range lighting.
● Aerospace-grade aluminum body with military-grade Type-III hard anodized finish, stainless steel retaining ring on the top to prevent any ingression of water and dust.
● Ultra-clear tempered glass lens is both impact and scratch resistant.
● Single pushbutton side switch uses optical lens to access all outputs.
● Stainless steel crenulated tailcap used as glass breaker, self-defense tool.
● Tail with three feet design, also used as tripod mount for hands-free illumination.
● Use one single 18650 lithium battery or two CR123A/16340 lithium battery for constant current circuit and constant brightness.
● Micro-USB charging port underneath tailcap for recharging battery internally (18650 and 16340 only).
● LED power indicator above side switch glows when charging, flashes when fully charged.
● Inverted on the plane to be used as candle lighting.
● Precision IPX-8 waterproof design, can continue to light under 2 meters.
● Stainless steel clip, can be linked to clothing at any time, flexible and more use.
● Flashlight tail UNC 1/4'' screw hole, can be installed directly on most of the equipment used.
Applying the coupon code "SMWC22CC" when checkout on GearVita before Otc 24th, you can get this flashlight at the final price of $39.99: https://gearvita.com/sunwayman-c22cc-rechargeable-led-flashlight.html
Related products:
sunwayman c22cc flashlight
cathy
cathy's picture
Convoy S2+ flashlight is a powerful and cost-effective LED torch and used for many outdoor applications. It supports up to 1000 lumens output with the use of a 18650 Li-ion battery. Constant current circuit ensures constant output, with its ultra-long shooting function, its lighting range is about 50-100 meters. Moreover, it also has mode memory function, low voltage protection and battery reverse protection function.
Main Parameters:
Emitters: Cree XM-L2 U2
Lumens Range: 500-1000 lumens
Luminous Flux: 940 lumens
Circuitry: 2.1A
Color Temperature: 6500-7000K
Mode: Two kinds of mode - .three modes: low 5%-mid 50%-high100% and five modes: low 5%-mid 50%-high100%-Strobe-SOS
Power Source: 18650 battery
Beam Distance: 50-100m
Impact Resistance: 1.5m
Product Features:
● High Performance
Adopting XM-L2 LED light, with up to 1000lm high brightness and long service time, to light up your way in the dark.
● Two Group Modes Choice
Two kinds of mode group, group 1 (Low - Mid - High - Strobe - SOS) and group 2 (Low - Mid - High) to meet your different demands.
● Mode Memory Function
Convoy S2+ can memory the mode next time when turn on for more than three seconds. If less than 3 seconds, it will goes into next mode.
● Low Voltage Protection
When the voltage of battery is 2.9 - 3.1V, the flashlight flashes 2 times/sec with low brightness for alarm.
● Battery Reserve Protection
If your battery is reversed, it will not bright only, do worry about battery or circuit.
● Premium Material
Adopting high quality aluminum alloy material, durable and stable.
● Widely Applicable
Idea for cycling, hiking, camping, fishing, working, repairing and other outdoor activities.
Get this LED flashlight from GearVita for multiple use, it is perfect for working, outdoor camping, emergency, repairing, and daily use: https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2.html
Related products:
https://gearvita.com/convoy-s3-xm-l2-led-flashlight.html
https://gearvita.com/convoy-t2-led-flashlight-320lumens.html
convoy s2+ flashlight
Boaz
Boaz's picture
Last seen: 10 min 53 sec ago
Hey Cathy does Gearbita offer free shipping ?
 I was looking at the mijia motion detection lights on sale for 7.99$ but saw shipping was another 6$ Which makes it no longer a great deal
   Interested in Diffuser film …  http://budgetlightforum.com/node/42208
cathy
cathy's picture
The Sunwayman C45CT flashlight is the powerful thrower searching flashlight. Wavy knurling design body ensures the light is easy-gripped. Charging Indicator Lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap. The tail of the flashlight is ingeniously designed to be used as an emergency spike.
Main Parameters:
Emitter: Cree XM-L2 U3 LED
Max Output: 1000 lumens
Runtime: 60 hours
Beam Range: 450 meters
Power Supply: 1*18650 battery or 2*CR123A(16340) batteries
Light Color: Cold white
Working Voltage: 3.7V
Waterproof: IPX-8
Turbo: 1000 lumens
High: 580 lumens ( 150 mins )
Mid: 130 lumens ( 800 mins )
Low: 16 lumens ( 3600 mins )
Product Features:
● High quality LED of Cree XM-L2 U3, with lifetime up to 50,000 hours.
● Powered by single 18650 battery or two CR123A(16340) batterries to provide constant current circuit.
● Max runtime up to 1600 mins, with the reflector of big diameter, Sunwayman C45CT is capable of reaching up to 450 meters effective range.
● One single switch provides access to all functions.
● Four brightness levels and two special functions available.
● Constructed from aero grade aluminum alloy with HAIII military grade hard-anodized finish.
● Wavy knurling design body ensures the light is easy-gripped.
● Memory function, the last mode used will be memorized for next time use.
● USB charging system, charging indicator lamp cleverly built in the user-friendly side switch covered by sub-transparent rubber cap.
● Low-voltage indication, the circuit CPU will detect automatically when the battery voltage lowers to 2.8V and the white light will flash slowly five times and turn off to protect battery.
● Electronic reverse battery protection effectively protects the flashlight circuit.
● Indicator lamp for charging is built inside the side switch, it turns on in green and flash when it's under charging, constant green when charging finishes.
● Twisting the rear part of the tail cap leftwards to use it as an emergency spike to break glass when needed.
● Waterproof in accordance with IPX-8.
Purchase this flashlight of $49.99 on GearVita with the coupon code "SMWC45CT" when checkout, the deadline is Oct 26th: https://gearvita.com/sunwayman-c45ct-led-flashlight-1000lm.html
Related products:
https://gearvita.com/sunwayman-c22cc-led-flashlight-820lumens.html
sunwayman c45ct flashlight
cathy
cathy's picture
Convoy S10 flashlight comes with stainless steel and aluminum alloy material which is durable and practical. Loaded with18650 battery, it also features with adjustable brightness and low voltage protection function. When the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
Main Parameters:
Light Source Brand: Cree
Light Source Model: XM-L2
Light Source Bin: T4-7A / T6-4C / T6-3B / U2-1A
Color Temperature: 3000K / 4200K / 5000K / 6500K
Light Color: Warm White / Neutral Light / Natural Light / White
Driver: 7135*8
Power: 11W
Voltage: 4.2V
Max Brightness: 1000 lumens
Modes: 1%-10%-100%
Waterproof Rating: IPX6
Product Features:
● High-quality tainless steel and aluminum alloy material, durable and practical.
● Waterproof to IPX-6 standard, available in all weather conditions, don't worry about the rainy days anymore.
● As long as a cigarette, Convoy S10 only takes up a little space in your bag, compact and small size for easy carrying.
● 10W strong power light with 6500-7000K color temperature, suitable for gambling stone jade identification.
● Powered by 1 x 18650 battery.
● Memory function, when the flashlight is on over 3s, the current mode is in memory.
● Low voltage protection, when the voltage is 2.9-3.1, the flashlight will flash twice a second at a low brightness.
● Stainless steel head, durable and shock resistant.
● Level-3 oxidation treatment shell.
● Battery reverse protection, battery will reverse, do not worry, no problem will occur.
There are four options for you to choose from on GearVita, T4-7A, T6-4C, T6-3B, U2-1A, all of which can enjoy a discount of $3 with the coupon code "CVS10" when you checkout. The following is the price after the discount:
T4-7A - $14.99
T6-4C - $14.99
T6-3B - $13.99
U2-1A - $12.99
Product link: https://gearvita.com/convoy-s10-led-flashlight-1000lm.html
Related products:
https://gearvita.com/convoy-s9-xml2-flashlight-580lm-natural-light.html
https://gearvita.com/convoy-s2-led-flashlight-cree-xm-l2-u2-7135-6-2-mode-groups.html
convoy s10 flashlight
cathy
cathy's picture
The Klarus XT32 flashlight is specially designed for tactical and hunting. Using a US CREE XP - L HI V3 LED lamp beads with a max output of 1200 lumens and a long lifespan of 50000h, it has two settings - classic tactical setting and hunting setting, and 6 brightness modes to meet your luminous needs. This flashlight uses 2 × 18650 lithium-ion battery or 4 × CR123A battery which is easy to buy to eliminate travel troubles in charging. Equipped with a lanyard and a holster, it's easy to carry.
Main Parameters:
Emitters: Cree XP-L HI V3
LED Lifespan: 50000h
Luminous Flux: Max 1200lm
Luminous Intensity: Max 250000cd
Power Source: 2 × 18650 or 4 × CR123A
Working Voltage: 5.0 V-12.8V
Six Outputs:
Turbo (1200 lumens) - 3 hour runtime
High (400 lumens) - 7 hour runtime
Medium (100 lumens) - 34 hour runtime
Low (20 lumens) - 120 hour runtime
Strobe (1200 lumens) - 6 hour runtime
SOS (100 lumens) - 102 hour runtime
Two Programmable Settings:
Tactical Setting: One-touch turbo, one-touch strobe
Hunting Setting: One-touch turbo, one-touch low
Product Features:
● Cree XP-L HI V3 LED, max brightness up to 1200 lumens.
● Precision manufactured reflector with optimized design for extended range illumination, improved spotlight performance, max beam distance up to 1000 meters, exceeds current industry level.
● Patented dual tactical tail switch and side switch design to meet different user need, easy and intuitive operation.
● Two programmable settings and six brightness modes.
● Perfect for hunting, hiking, camping, search and rescue operations and more.
● Newest ITS intelligent temperature protection system, monitors internal temperature and adjust output for maximum brightness, protects LED and internal components to ensure safety, stability, optimum performance, and user comfort.
● Lock-out function of the side switch prevents accidental or unnecessary activation.
● Intelligent capacity indicator monitor remaining battery capacity anytime.
● Front and rear mounted springs protect against shocks and drops.
● Aerospace aluminum alloy construction, CNC precision machining, mil-spec HAIII anodizing, rugged and anti-abrasion.
● Hardened and AR-coated lens, anti-abrasion and high light transmittance.
● Waterproof IPX-8 ( underwater 2m ), suitable for rainy weather.
This particular flashlight has a 1000 meter range, is programmable, and has a host of other features that make it really stand out from your average searchlight. This flashlight is really excellent for outdoor activities such as hunting or search and rescue or even professional work. It's really quite versatile and can be used in a myriad of situations. Get Klarus XT32 of $89.99 by appling the coupon code "KRXT32" from GearVita, it's definitely powerful enough to get the job done: https://gearvita.com/klarus-xt32-led-flashlight-1200-lumens.html
Related products:
klarus xt12gt
klarus xt11x
klarus xt32 flashlight
cathy
cathy's picture
The Xiaomi Mijia 1S Walkie Talkie is packed with some powerful features – a huge 10km range, 8 days of standby time and up to 17 hours of talk time, GPS positioning and even an FM radio function. It has a detachable antenna for easy storage and has a micro-USB port for charging that can also be powered with a power bank. It supports the Very High Frequency (VHF) range spanning from 136MHz to 174MHz, also comes with support for the Ultra High Frequency (UHF), i.e. the frequency range between 403MHz and 470MHz. Xiaomi walkie talkie can be used almost anywhere, including metropolitan areas with a high degree of radio interference. On top of that, the device comes with support for FM Radio, allowing you to tune in to your favorite radio stations, also capable of location sharing.
Product Features:
● 41% thinner than last generation, 43% lighter, built-in back clip, one hand handling.
● Not only support 3.5mm earphone port, but support Bluetooth headset with dual mode Bluetooth chip.
● Micro USB charging port, no need to worry about loss of charger, convenient and practical.
● Quick to form a team, once one starts a team, the others can click to join the team without putting complicated frequency.
● Location share function, in the range of calls, it can check the location of teammates by the screen or App even there is no Internet.
● 2190mAh big capacity battery, micro-USB charging design.
● Long time to use, 8 days stand-by time,17 hours for normal use.
● Auto detection function during charging, prevent the risk of overcharge, over discharge, over voltage and other issues.
● FM radio function, it can search channel in 87 - 108MHz, providing entertainment apart from communication, but the talking between walkie talkie have priority when listening to radio.
● Digital filtration, good talking effect even in various complicated environment.
● In order to achieve clearer and louder call sound, the speaker has a speaker volume that is 65% larger than the effective radiation area of the previous generation. The maximum volume is increased by 162%, and in a noisy environment, good call performance can still be maintained.
● Sending voice without pressing talking button when your volume is reached to a certain level,free your hands.
● Suitable for two-way communication from different locations.
● A maximum power of 3W and a call distance of 1-5 kilometers in order to meet the call needs in a variety of scenarious.
● Comes with UHF frequency range of 403-470MHz, and VHF frequency range of 136-174MHz., give it the ability to be used in a densely populated area as well as in the wild where there is little or no obstruction to the radio waves.
● Comes in black and white colors with along with handy display and some buttons on the surface for controlling the device.
Applying the coupon code "MIJIA1S" when checkout on GearVita, you can get this Mijia 1S walkie talkie with the price of $41.9: https://gearvita.com/xiaomi-mijia-1s-smart-walkie-talkie.html
Related products:
xiaomi smart walkie talkie
xiaomi mijia d301 walkie talkie
xiaomi mijia 1s walkie talkie
cathy
cathy's picture
Lumintop Tool AA 2.0 is a portable mini AA flashlight, which is the upgrade version of bestseller Tool AA. With the incredible handy and compact size, it emits a max output up to 650 lumens with the compatibility with one 14500 rechargeable Li-ion battery. Four output levels for various lighting demands, and additional Strobe for emergency situations. The included diffuser makes it best for reading, campings and so on by creating a soft and pleasant beam. There are two tail versions for options, tail switch and magnetic, capable for tail standings to serve as a candle or magnetic suctions on a metal surface for different position lightings. Two positions body clip offers various wearing manners, such as clip on your pocket or on a cap to free your hands. Tool AA 2.0 is essential for camping, touring, home using, gifts, EDC gears, and emergency lightings.
Main Parameters:
LED: Cree XP-L HD LED
Power Source: 1 × AA or 1 × 14500 rechargeable Li-ion battery
Max Output: 650 lumens
Peak Beam Intensity: 3420cd
Peak Beam Distance: 127 meters
Waterproof: IP68
Impact Resistant: 1.5 meters
Output and Runtime:
● Powered by 14500 Li-ion Battery
Low: 16 lumens ( 37hrs )
Med: 85 lumens ( 6hrs 9mins )
High: 360 lumens ( 1hr 19mins )
Turbo: 650 lumens ( 33mins )
Strobe: 360 lumens ( / )
● Powered by Alkaline Battery
Low: 3.7 lumens ( 2.5 days )
Med: 25 lumens ( 11hrs 50mins )
High: 140 lumens ( 49mins )
Turbo: 220 lumens ( 21mins )
Strobe: 140 lumens ( / )
● Powered by Ni-MH Battery
Med: 25 lumens ( 12hrs 30mins )
High: 140 lumens ( 2 hrs 33mins )
Turbo: 270 lumens ( 43mins )
Product Features:
● Utilizes XP-L HD LED with a lifespan of 50,000 hours.
● Powered by one AA or one 14500 rechargeable Li-ion battery.
● Two ways to select outputs: Tail switching or twist the head.
● Four output levels plus Strobe with max 650 lumens output.
● Mode memory function recalls the last use output when turning on next time.
● Super long runtime up to 2.5 days in Eco mode.
● The optional magnetic tail cap is capable for tail standing to serve as a candle.
● Light-weight and compact, best for EDC use.
● Made of aircraft-grade aluminum alloy, premium type Ⅲ hard-anodized anti-abrasive finish, toughened and wear-resistant.
● IP68 rated dust-proof and waterproof, submersible to 2 meters.
Applying the coupon code "LMTAA2" on GearVita, only $18.99 needed, you can get this best-selling mini AA flashlight: https://gearvita.com/lumintop-tool-aa-2-0-flashlight-650-lumens.html
Related products:
lumintop odf30c
lumintop gt mini
lumintop tool aa 2.0
cathy
cathy's picture
The Imalent MS12 is one of the latest and brightest torches, also known as "the king of light". It is powered by 12 American Cree XHP 70 LEDs and can produce fan cooled 53000 lumens with a max beam distance of 913 metres. Built in high power cooling fan, silent, waterproof, heavy wind, which is a perfect combination of great energy and technology.
MS12 is extremely compact and comfortable to hold, utilizes 6 side lights for camping, fishing and more other outdoor lighting experience. It features Imalent's signature high-grade side pressure switch, this ergonomic design provides an unprecedented level of grip. Eight output levels ensure long runtimes with low or high output in any situation. The "hide strobe" feature keeps you safe by starting quickly at critical moments.
Main Parameters:
LED: Cree XHP 70 LED
Power Source: Built-in Li-Ion battery pack
Max Output: 53000 lumens
Peak Beam Intensity: 208000cd
Peak Beam Distance: 913 meters
Light Temperature: 6000 - 6500K
IPX Rating: IPX-8
Impact Resistance: 1.5 meters
Output and Runtime:
Turbo: 53000-15000 lumens ( 3+78mins )
High Ⅲ: 30000-15000 lumens ( 4+80mins )
High Ⅱ: 15000 lumens ( 1hr 36mins )
High Ⅰ: 7500 lumens ( 2hrs 45mins )
Middle Ⅱ: 3800 lumens ( 5hrs 45mins )
MiddleⅠ: 1900 lumens ( 11hrs 10mins )
Middle Low: 900 lumens ( 22hrs )
Low: 300 lumens ( 55hrs )
Product Features:
● Utilizes 12 pieces of American XHP70 LEDs, Imalent MS12 LED Flashlight comes with a lifespan of up to 5000 hours and a maximum output of 53000 lumens.
● Built-in self-testing intelligent charging circuit which is convenient, fast and safe.
● Eight power levels which can be changed quickly with instant turbo available.
● Six battery capacity indicators around the flashlight head, 360-degree shows the capacity any time.
● High efficiency constant current circuit maintains consistent brightness.
● Features a lock and unlock function. With the flashlight off, press the switch button 3 times, the red indicator will flash twice to indicate the flashlight is locked. Press the switch button 3 times again, the green indicator will flash twice to indicate it is unlocked.
● Built-in thermal control module automatically adjusts the brightness output to keep the unit from overheating.
● Combination of toughened ultra-clear mineral anti-reflective coated glass.
● Aluminium orange peel reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type Ⅲ hard-anodized surface treatment.
● Waterproof to IPX-8 standard (2 meters submersible)
Learn more about it on GearVita, if you are interested in it and want to bring it home, remember to use the coupon code "IMMS12" to get the $100 discount, which will give you a lowest price of $389.99 compared to any other websites. And when you received your MS12, it will bring you absolute shock in the night: https://gearvita.com/imalent-ms12-led-flashlight-53000-lumens.html
Related products:
nitecore concept 2
nitecore tm10k
imalent ms12 flashlight
cathy
cathy's picture
The Imalent RT35 flashlight has a maximum output of 2350 lumens from the Cree XHP35 HI LED and is powered by 4 x 18650 Li-ion batteries. Offering excellent output and an incredible throw up to 1338 meters, the torch is the ideal searchlight for applications requiring a far throwing beam.
The RT35 features innovative magnetic charging, simply attach the included cable to the magnetic plate on the side of the torch to recharge the batteries. Removing the requirement for an external charger makes the torch more portable and allows for quick and convenient charging on the go.
Five output levels, ranging from 50 to 2350 lumens, and a hidden Strobe mode ensures you can have a long runtime with low output or high output when required, so you can prepare for your night time outdoor adventure well in advance. The RT35 is fitted ith a user-friendly side pressure switch to operate the output selection. Tucked neatly below the switch are three multi-functional charging indicators which flash red when the battery voltage is lower then 3.2V and change from red to green when the batteries are fully charged at 4.2V.
Main Parameters:
LED: Cree XHP35 HI LED
Power Supply: 4 × 18650 battery
Beam Distance: 1338 meters
Peak Beam Intensity: 449000cd
Max Output: 2350 lumens
Waterproof: IPX-8 standard
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 2350-1500 lumens ( 8+162min )
High: 1500 lumens ( 3h 45min )
Middle: 750 lumens ( 6r 10min )
Middle Low: 350 lumens ( 12h 45min )
Low: 50 lumens ( 60h 162min )
Product Features:
● Utilizes one American XHP35 HI generation LED, with a lifespan of up to 50000 hours and a maximun output up to 2350 lumens.
● Built-in safety self testing intelligent charging circuit, convenient, fast and safe.
● Exquisite, powerful, extremely long throw at over 1300 meters.
● Built-in intelligent temperture control module can automatically adjust the brightness output.
● Built-in magnetic charging, higt grade and portable.
● 6 levels which can be exchanged quickly and instant turbo.
● Battery capacity indicators besides power switch, shows the capacity any time.
● High efficiency caonstant current circuit will maintain constant brightness.
● Combination of toughened ultra-clear mineral and anti-reflective coating glass.
● Aluminium OP reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment.
● IPX-8 standard waterproof (2 metres submersible).
● Built-in multi-functional charging incicators.
▹Function 1- Lower power warning:
When the battery voltage is lower than 3.2V,the red indicators will turn on.and if users try to activate turbo mode,the red indicators will flash three times to remind users battery too low to activate it.
▹Function 2 - Charging:
The indicators will be red when it is charging and turn green when it is fully charged to 4.2V.
This light is incredible for spot lighting and adventure sports requiring a long distance throw. With the coupon code "IMRT35" of GearVita, you can get this throw king of $74.95. Look at it, you will find out the discount is super: https://gearvita.com/imalent-rt35-led-flashlight-2350lm.html
Related products:
nitecore concept 2
imalent ms12
imalent rt35 flashlight
cathy
cathy's picture
IMALENT DX80, "The End of Darkness", is a rechargeable LED flashlight with intelligent design that focused on maximum brightness and runtime that can be applied to all kinds of environments. Its 8 pieces of American Cree XHP70 2nd generation LED make it capable of a max output of up to 32000 lumens. With its advanced circuit design, the OLED display can show the output, voltage and modes, the ease of use that this brings for outdoor activities will change your world. It allows you to plan effectively, and lower the risk of ever running out of light in the dark.
Main Parameters:
Emitter Type: Cree XHP70.2
Light Color: White light
Battery Configurations: Built-in 8pcs 3000mAh battery pack
Luminous Flux: 32000 lumens
Max Range: 806 meters
Color Temperature: 6500K
Waterproof: IPX-8 waterproof 2 meters
Output and Runtime:
Turbo: 32000-7000 lumens ( 3+100min )
High: 13000-7000 lumens ( 8+122min )
Middle High: 13000-7000 lumens ( 2h 25min )
Middle: 5000 lumens ( 5h 40min )
Middle Low: 500 lumens ( 40h 46min )
Low: 120 lumens ( 168h )
Product Features:
● Utilizes 8 pieces of American Cree XHP70 2nd generation LEDs, with a lifespan of up to 50000 hours and a maximum output of 32000 lumens.
● The shot distance is up to 806 meters with wide beam range.
● The multi-functional OLED display can show various parameters and settings.
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance.
● High efficiency constant current circuit will maintain constant brightness.
● Anti-reverse battery protection.
● Intelligent temperature control, when the body's temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning. It will also automatically adjust the current to keep the flashlight to work under 50 Deg.C for long time.
● Low power warning, when the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery.
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant.
● Waterproof level up to IPX - 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms.
● 1.5m impact resistant.
● Tail stand function.
IMALENT DX80 can be used in all kinds of situations, such as adventuring, search and rescue, night fishing, industrial use, etc,. Applying the coupon code "IMDX80" on GearVita, you can get $120 discount, it will definitely become your good helper: https://gearvita.com/imalent-dx80-led-flashlight-32000-lumens.html
You may like:
xiaomi mi pad 4 plus 4g review
xiaomi mi box s tv box global version review
imalent dx80 flashlight
cathy
cathy's picture
The Xiaomi FZ101 flashlight features with 3 adjustable brightness levels and 2 function modes of Strobe and SOS. With zoomable function, it can provide you with most suitable light, meeting your various needs of lighting, such as night camping, running, observation or exploration and more. Premium aluminum alloy body provides a long service life.
Main Parameters:
LED Lifespan: 50000 hours
Brightness Range: 500 - 1000 lumes
Typical Luminous Flux: 672 lumens
Light Range: 365 meters
Beam Power: 10W
Color Temperature: 5500 K
Battery Capacity: 2600mAh
Waterproof Standard: IPX-6
Product Features:
● Lightweight Mini Design
With its mini size, it is portable for you to bring it outside.
● Aluminium Alloy Shell
Minimalist design, full of texture. The body is made of premium aluminum alloy, lightweight and durable for use.
● Max 1000 Lumens Brightness
With high brightness, meets your various needs of lighting, such as night camping, running, observation or exploration and more.
● 5 Modes Dimming and Zoomable Design
With 3 adjustable brightness levels and 2 function modes of Strobe and SOS, as well as the zoomable function, it can provide you with most suitable light.
● 2600mAh Large Capacity Battery
Comes with a 2600mAh large capacity battery, bringing you a lighting endurance up to 2375mins, longer working time and power bank discharge time.
● USB Rechargeable Function
No need to remove the battery repeatedly. With the USB Type-C charging port, providing convenient and fast charging for you.
● Unique SOS Mode
It is unique with the SOS mode. Press the function button to send a distress signal, quite practical.
Applying the coupon code "MiFZ101", you can get this Xiaomi zoom flashlight with the price of $27.99 from GearVita: https://gearvita.com/xiaomi-fz101-zoom-flashlight-1000lm.html
In addition, there is the Black Friday promotion on our website now, prices are very affordable, you can go to see: https://gearvita.com/black-friday-sale
You may also be interested in:
xiaomi mi portable mouse
xiaomi 70 minutes wifi car dvr
xiaomi fz101 flashlight
cathy
cathy's picture
Lumintop EDC01 is a mini keychain LED pocket AAA flashlight which emits a max 120 lumens with Cree XP G3 R5 LED by a single AAA flashlight. Four color options, tail standing ability, twisty switch operation, mini in body size, IP68 rated protection, EDC01 is the best for your every day carries, as well as a multi-function lighting tools.
Main Parameters:
Emitter Type: XP-G3(R5) LED
Max Output: 120 Lumens
Range: 37m
Peak Beam Intensity: 553cd
Battery Configurations: 1 × AAA battery
Working Voltage: 0.9-1.5V
Waterproof: IP68, underwater 2m
Output and Runtime:
Low: 5 lumens ( 36h )
Med: 32 lumens ( 4h )
High: 120 lumens ( 30min )
Product Features:
● Utilizes Cree XP-G3 (R5) LED with 50,000 hours lifetime.
● 3 modes with a max 120 lumens output and an up to 36 hours run-time.
● Runs on one always available AAA Ni-Mh or Alkaline battery.
● Compact and light-weight design, easy to carry.
● High-efficiency digitally regulated circuit maintains constant brightness.
● Bead surface optical lens for soft and balance beam.
● Glow-in-the-dark O-ring and optional diffuser easily locates the light in the dark.
● Simplify twisty switch makes it easy access all modes.
● Capable of standing up on a flat surface to serve as a candle.
● Make of aircraft-grade aluminum alloy with wear-resistance painting.
● IP68 rated protection, impact resistance to 1.5 meters.
Four colors optional of on GearVita, blue, pink, purple and golden, the exquisite package fits for applications such as gifts, EDC, tools etc.: https://gearvita.com/lumintop-edc01-mini-flashlight-120-lumens.html
Hot sale products:
oneplus 6t 256gb
yi 4k action camera floating grip
lumintop edc01 mini flashlight
cathy
cathy's picture
Xiaomi Yeelight YLDP06YL smart light bulb paints your home with colors anytime and anywhere, see the world in a new light. Provides light together with comfortable experience, it is a warm bulb with proper brightness could be used for reading, party and also help you get rid of the tired with soft light.
It supports WiFi control and brightness adjustment via the companion APP. The smart bulb comes pre programmed with over 16 million colours and different tones of white. Not only does this smart bulb has endless amounts of colours to choose from, you can sync the lights with your favorite music.
Product Features:
● Plug and Play
No hub required, just connect the bulb directly to your WiFi at home.
● Complete Control
Control your lights from anywhere using your smartphone and Yeelight APP ( download from Apple Store or Google Play ).
● Vast Color Options
Match any occasion with the 16 million colors and adjust the brightness as well as color temperature from warm white ( 1700K ) to daylight ( 6500K ).
● Sync Lights with Music
Syna the lights to your favorite song and explore how lights change with rhythm, spice up your party or holiday decoration with changing colors.
● Voice Control
Control your lights hands-free with Amazon Alexa and Google Assistant.
● Long Lifespan
With the brightness of 800 lumens in just 10W, the bulb provides you with 25000 hours of high-quality luminance and loyal companion.
● Energy Saving
Reduce energy use up to 83 percent without brightness or quality loss compared to a 60W incandescent bulb.
● Compatibility
Compatible with Android, iOS, Amazon Alexa, Google Assistant and IFTTT.
Play with light, you can choose from different colors to match the light to your mood. One color, one mood. GearVita provides E26 and E27 options, let you experience different atmosphere everyday: https://gearvita.com/xiaomi-yeelight-yldp06yl-smart-light-bulb-10w-rgb-w...
You may also interested in:
best xiaomi huami amazfit bip smartwatch
best xiaomi redmi note 6 pro
xiaomi yeelight yldp06yl smart light bulb
cathy
cathy's picture
This Xiaomi Mijia Yeelight Sensor Light adopts professional optical design and its soft light protect eyes from dazzling at night. With infrared sensor technology, the light turns on in the dark when it is detected a movement at a side margin of 2-3 meters or a distance of 5-7 meters, and after 15 seconds when you leave the sensing area, the light turns off automatically. Built-in 750mAh lithium battery, capable of running for more than 120 days at auto mode after fully charged.
Product Features:
● Easy to Install
▹ Suspension: Open the rear hook, Hang it in any position you need, easy and practical to operate.
▹ Pasteability: Tear the adhesive tape on the back and stick the light in any corner you need , such as hallways, stairs, lockers, headboard and entrance.
▹ Magnetizability: The product has a built-in magnet, can be adsorbed on the surface of a refrigerator or other magnetic access furniture.
● Long Operating Time
With a built-in 750mA high capacity lithium battery, charged by USB port once it can be used up to 120 days, it frees you from frequent charging problems.
● Human Body Infrared Sensor
120 degree detection angle, 5-7 meters detection distance on the front, 2-3 meters on the side. With the advanced photosensitive function, the light will turn on automatically in a dark environment.
● Two Lighting Modes
▹ Detection Mode: with a photosensitive and infrared human body sensor, the light comes on when people close and turn off when people are remain for 15 seconds.
▹ Constant Lighting Mode: clearly illuminate your night without pressure to find items at night.
● Warm White Light
Use of 2700K warm light, comfortable and warm light color temperature. Professional optical design, away from the reflection, do not disturb the night sleep in the family.
The intimate functions are placed in the yeelight sensor light with the distribution of soft petal-style light, built-in Fresnel lenses and photosensitive sensor. The price on GearVita is also very intimate, only at $15.19. Simple design that matches various decorations for the home, it is not only a light, but a perfect decoration: https://gearvita.com/xiaomi-mijia-yeelight-sensor-light.html
Hot sale products:
xiaomi mi 8 pro 128gb
xiaomi mijia yeelight sensor light
cathy
cathy's picture
This Xiaomi Mijia smart bedside lamp uses high CRI osram LED, offering16 million RGBW lights for your year-round choice. With simply touch and slide, you can adjust brightness and colors as you deisred. Also, special lights design provides you different scenarios. Moreover, you can control the lamp for more fun using delicated App.
Product Features:
● Magic Colors
A tremendous range of 16 million colors for choise.
● Dimmable
Adjust color temperature and brightness for suitable light.
● Color Temperature
1700K-6500K color temperature gradual change function.
● Perfect CRI
Professional optical design with high-quality Osram LED that of high color rendering index.
● Touch Control
Simple touch to adjust brightness/change color/delay switch off/switch light mode as you desired.
● Smartphone Controls
Can be controlled by smartphones through WiFi or bluetooth. Built in multiple scene modes, the porprietary APP lets you get access to your desired lighting easily.
● Mi Band Linkage
Through the MIJIA APP, the bedside lamp and your Mi band binding, then it will be based on your sleep state to determine whether or not to turn off the lights, no longer interrupt your hazy sleepy.
● High-quality Manufacturing
Uses high-precision CNC anodized blasting and cutting techniques to ensure flawless construction.
Every bedroom requires something a little different, this Mijia bedside lamp's minimalist design is perfect for every bedroom. Get it from GearVita and start a colorful life: https://gearvita.com/original-xiaomi-mijia-led-smart-light-bedside-touch...
Hot sale products:
cheap xiaomi mi 8 lite 64gb
cheap xiaomi mi band 3 smart bracelet heart rate monitor
xiaomi mijia smart bedside lamp
cathy
cathy's picture
Yeelight YLFW01YL Candela Light features metal candlestick base design with brass lampwick, full of sense of art, can present you an unrivalled visual experience. It adopts BLE Mesh technology, allowing up to 30,000 units candelas to communicate with each other. The LED candela light with compact and lightweight design, portable to carry, can bring you a warm and cozy vibe for your bedroom, living room, workplace and etc.
Product Features:
● Candela Light
Metal candlestick base design with brass lampwick, full of sense of art, can present you an unrivalled visual experience.
● Stepless Dimmable
Clockwise and counterclockwise rotate the lamp to adjust the light brightness, easy to operate.
● BLE Mesh Technology
Allows up to 30,000 units candelas to communicate with each other. If you rotate one lamp, other candela lamps will automatically change the brightness at the same time.
● Warm Light
Holds a 1600K color temperature, the same color temperature as a candlelight, will not hurt your eyes, brings a warm and cozy lighting atmosphere.
● Long-lasting Life
Built-in 2100mAh lithium battery, allows for up to 8 hours of continuous use after a full charge. Hidden USB charging port, protect the plug from external impact force.
● Smart Control
You can control your candela light and other Yeelight smart lights by your phone via Yeelight app, making your life easier.
● Distinctive Design
The glass like naturally transparent poly-carbonate (PC) lamp chimney tube allows light to distribute evenly and beautifully.
Candela is the world's only smart candlelight using the latest Bluetooth (BLE) Mesh technology, combining the warm comfort of candlelight with the convenience and control of smart technology. Do you want to make your place more attractive and create a warm and soft atmosphere to those who you love? Come to GearVita, here is your ideal choice: https://gearvita.com/yeelight-ylfw01yl-smart-atmosphere-candela-light-su...
You may like:
buy xiaomi 70 minutes smart wifi car dvr
buy xiaomi mi band 3 smart bracelet heart rate monitor
yeelight ylfw01yl candela light
cathy
cathy's picture
The Xiaomi smart LED desk lamp comes with four lighting modes for different needs: Focus mode, read mode, PC mode and kid mode. Further, you can set the temperature and brightness of the lamp via the connected Mi smart home App, this is definitely handy for all your lighting needs. As for the design, the lamp has a very minimalistic design - a super thin stand and a thin tube, so it should be easy to place it anywhere you want without taking a lot of space.
Focus mode
You can set up a "focus time" and "rest period", each completed a "focus time" lamp, the lamp will remind the you to take a rest via "breathing light", which helps you improve work efficiency, reduce eye fatigue.
Read mode
Provides you with a more neutral color temperature (4000K) and 100pct brightness, which improves your attention as well as prolong reading time without tiring.
PC mode
Blue light from computers can be damaging to your eyes. 2700K color temperature pleasant light is designed to reduce the proportion of blue light when using computers, protecting your eyes.
Kid mode
Since the eyes of children haven't developed completely and can be easily hurt, Mi Smart LED lamp, designed for children, has passed the Biosafety certified to meet the latest safety standards, silently protect the children from damaging eyesight.
Product Features:
● Flicker-free Lighting
Patented optical design that combines numerous light reflection and refraction, producing light that is close to natural lighting.
● Four Lighting Modes
Focus mode, read mode, PC mode and kid mode fulfill every need of yours.
● Simple Intuitive Control
Easily switch on and off, adjust color temperature and brightness via a knob.
● App Remote Control
Search "Mi Smart Home" in the "App Store" or "Google Play" to download the APP and connect your device, then start your Mi smart life.
● Minimalist Design
Clean and sleek appearance, precise spindle, the hinge is durably constructed with an all-metal design.
● Withstands Heat
Designed to dissipate heat better, ensures uniform luminance, and has a longer lifespan.
This Mi LED desk lamp is specially designed to reduce flickering which causes fatigue and other harmful effects on the eyes. Whether in daily life or at work, you need it. The price is also not expensive, only $44.99 needed on GearVita: https://gearvita.com/xiaomi-mijia-smart-led-desk-lamp.html
Hot sale products:
cheap oneplus 6T 4g smartphone 256gb
cheap xiaomi mi max 3 4g smartphone
xiaomi mijia smart led desk lamp
cathy
cathy's picture
This 2 in 1 smart Bluetooth music bulb brings you fantastic light and audio music enjoyment at the same time. Wake up in the morning to your favorite colors, come home to a bright or warm light environment, creat warm or romantic atmosphere for you.
It can be controlled by smartphone or tablet via App. As a smart Bluetooth speaker bulb, after connected, music will sync from your smartphones or tablets with lights you like, you can shift white or colorful light as you like, add colors to your family life.
It also supports timing alarm and sleep assistant, so you can set a lighting on definite time to sleep and set powering off in a specified time period, smart lights as you expected.
The Bluetooth light bulb not only 4 color models, but also can be added more different colors you preferred, you can add or delete the color as you like. What makes it different, the smart bulb can display the latest color you used last time.
So many functions, but...how much energy consumption? Please do not worry, the LED bulb is energy-saving.
Get this smart bulb from GearVita and let it light up your colorful life: https://gearvita.com/sunvito-smart-bluetooth-music-speaker-led-bulb.html
You may like:
best xiaomi mi a2 lite smartphone
best xiaomi mi max 3 4g smartphone
<p>smart bluetooth speaker led bulb
cathy
cathy's picture
This LED Bluetooth music bulb has a unique and exclusive two-in-one design, not only a smart LED bulb but also a speaker. Any bluetooth-enabled device can control music playing and the remote controller can adjust the light color. As a bulb, it adopted with high quality led light source, high standard brightness. Controlled by a remote controller, the light can change from smooth mode to flash mode or strobe mode, suitable for your using in different atmosphere.
Product Features:
● Connect your Bluetooth enabled device to play the music.
● Easy to install with E27 lamp base and suit for most bulbs using.
● Install it to floor lamp or desk lamp, make it to be a night light with music playing.
● 13 lighting colors can be adjusted with the remote controller.
● Four lighting modes:
- Flash Mode: flashing the light with fast speed.
- Strobe Mode: flashing the light with slow speed.
- Fade Mode: RGB fade.
- Flicker Mode: Color changing according to the music.
● One remote controller can control multi bulbs at the same time.
● Energy saving, environmental protection, low power, low heat generating.
The colorful light and pleasant music creats a magical and attractive feeling. Sold on GearVita, it is a best decoration for living room, bedroom and party, also a good ideal as a gift for Christmas: https://gearvita.com/texsens-led-light-bulb-with-integrated-bluetooth-sp...
Hot sale products:
best xiaomi redmi note 6 pro 32gb
best xiaomi mi 8 lite 64gb
led bluetooth music light bulb
cathy
cathy's picture
LJC-118 snowman LED light is a very cute touch control sensor night light with music, the light color will change with the music and you will see seven different colors.
Product Features:
● The light color is gradually change with 7 different colors, and will play music at the same time.
● Lovely shape brings happy time.
● Touch control.
● The accessories are removable.
● Soft silicone material gives a nice hand feeling.
● Rechargeable built-in 3.7V 1200mAh Li-ion battery.
● USB charging, easy to charge and carry.
● Suitable for many occasions, like Christmas party, kids room, etc..
Christmas is coming, this is a perfect gift for your children or lover, also a lovely ornament in your home. Only $9.99 you can get it from GearVita: https://gearvita.com/ljc-118-snowman-led-light.html
You may like:
xiaomi mi max 3 4g smartphone in stock
xiaomi mi box s tv box global version in stock
snowman led light
cathy
cathy's picture
The Lumintop HL AAA flashlight is a muti-function mini flashlight. Compact in size, it can easily carry in a pocket or in a pack-bag. Reversible two positions mounted clip offers various wearing ways. The strong magnetic tail cap can be easy suck on a metal surface, to meets different lighting demands such as vehicle maintenance etc. Bead surface optical lens, floodlight design for a soft and balance beam. Powered by one AAA battery, handy and compact yet multifunctional in use, surely you can trust on in camping, hiking etc.
Main Parameters:
Emitter: Cree XP-G2 R5
Luminous Flux: 120 lumens
Beam Distance: 30m
Luminous Intensity: 228cd
Battery: 1 × AAA
Waterproof Standard: IPX-7
Output and Runtime:
High: 120 lumens ( 0.5 hours )
Mid: 30 lumens ( 4 hours )
Low: 1.5 lumens ( 36 hours )
Product Features:
● Utilizes Cree XP-G2 R5 LED with a lifespan of 50000 hours and a max output 120 lumens.
● One switch control, easy to use.
● Made of aircraft-grade aluminum alloy with nickel plating on the surface, 1.5 meters impact resistant test.
● Magnetic tail cap, easy to be suck on the metal surface.
● Stainless steel clip can be mounted on two sides of the body.
● Powered by one AAA battery, 36 hours max run time.
● High-efficiency digitally regulated circuit to maintain constant brightness.
● Waterproof to IPX-7 standard, suitable for rainy weather.
It can be served as a mini flashlight or an angle light, there are two emitter models on GearVita for you to choose from, Cree XP-G2 R5 and Cree XP-G3 R5: https://gearvita.com/lumintop-hl-aaa-led-flashlight-120-lumens.html
buy xiaomi mi max 3 4g smartphone
buy xiaomi mi 8 lite 128gb
lumintop hl aaa flashlight
cathy
cathy's picture
Wuben L50 is a multi-function aluminum flashlight for outdoor use. Cree XP-L2 LED imported from US, simple function operation, stable circuit design, 18650 battery powered, built-in independent charging design, convenient, energy saving.
Main Parameters:
Emitter: Cree XP-L2 LED
Max Output: 1200 lumens
Max Beam Distance: 200m
Peak Beam Intensity: 10008cd
Max Runtime: 143 hours
Battery Configuration: 1 × 18650 Battery
Working Voltage: 2.8V-4.2V
Waterproof: IPX8, 2m underwater
Impact Resistant: 1m
Output and Runtime:
High: 1200 lumens ( 1.5h )
Med: 400 lumens ( 2.5h )
Low: 75 lumens ( 8.5h )
Eco: 5 lumens ( 143h )
SOS: 1200 lumens ( / )
Product Features:
● Fully press the tail button switch to turn on the flashlight and press it again to turn off the flashlight. When the flashlight is on, half press the tail switch to change the flashlight brightness.
● Turn on the flashlight, tap the tail switch to adjust the brightness: Eco-Low-Medium-High-SOS-Eco cyclically.
● Built-in 18650 battery, can be charged cyclically.
● High-tech smart constant current chip, to ensure smooth output brightness.
● Can be used immediately after charging, environmentally friendly, full of about 4 hours.
● With one folder, easy to carry.
● Grade III hard anodized aerospace aluminum body.
● Surface vibration grinding, beautiful design, feel more comfortable.
● Waterproof level IPX8, 2m underwater for 1 hour, cope with all kinds of harsh environment.
It is suitable for camping, fishing, hunting, hiking, searching, working and so on, get it on GearVita now: https://gearvita.com/wuben-l50-led-flashlight-xp-l2-1200-lumens.html
Hot sale products:
xiaomi lyej05lm in stock
wuben l50 flashlight
cathy
cathy's picture
The Nitecore HC65 headlamp improves more power to the popular HC60 headlamp by adding secondary red and high CRI LEDs. Equipped with a primary Cree XM-L2 US LED, delivers a 1000 lumen wide angle output beam, capable of a 120 yard throw, useful for mid-range illumination activities like hiking, biking and camping. A high CRI auxiliary white light renders colors more like sunlight and can be used for an upclose flood of light when reading or working while an auxiliary red light helps users preserve night vision in dark environments.
Main Parameters:
LED: Cree XM-L2 U2
Max Beam Distance: 110 m
Peak Beam Intensity: 3000cd
Battery: 1 × 18650/2 × CR123/RCR123 battery
Waterproof: IPX8
Output and Runtime:
Turbo: 1000 lumens ( 1h )
High: 550 lumens ( 2h 45min )
Mid: 280 lumens ( 4h 45min )
Low: 80 lumens ( 16h )
Ultralow: 1 lumen ( 800h )
Auxiliary White Light: 26 lumens ( 25h )
Red Light Illumination: 11 lumens ( 20h )
Red Caution Light: 11 lumens ( 32h )
Strobe/SOS/Beacon: 1000 lumens ( / )
Product Features:
● Equipped with high CRI auxiliary white light and red light.
● Integrated precision digital optics technology for extreme reflector performance.
● A maximum beam intensity of up to 3000cd and beam distance of 360 feet.
● Highly efficient constant current circuit runs for up to 800 hours.
● Intelligent memory functions stores last used lighting level.
● Intelligent Li-ion battery charging unit, built-in micro USB charging port.
● A flood lighting system provides 100 degree beam angle.
● Integrated advanced temperature regulation technology.
● Tilt mechanism allows for 180 degree adjustment.
● Power indicator displays battery voltage, accurate to 0.1V.
● Reverse polarity protection.
● Constructed from rugged aerograde aluminium alloy.
● Rugged HAIII military grade hard-anodized aluminium alloy.
Buy it from GearVita and get ready for your next adventure: https://gearvita.com/nitecore-hc65-u2-led-headlamp-1000-lumens.html
You may like:
cheap lenovo z5 pro 128gb
cheap yi 4k action camera floating grip
nitecore hc65 headlamp
cathy
cathy's picture
The Nitecore LR10 camping lantern with 9 high CRI LEDs offering a max output of 250 lumens up to 26.2 yards. With a CRI rating more than 90, the LR10 emits a beam that resembles natural morning sunlight to prevent eye fatigue and reveal subtle details of objects. A highly translucent PC diffuser evenly distributes light to provide 360 degrees of illumination for your surrounding environment. The LR10 also includes a built-in location light for finding the lantern in the dark as well as a battery indicator to let you know when power is running low. A magnetic base and metal hook provide multiple mounting and hanging options for this highly versatile lantern ideal for outdoor excursions, working at night, everyday carry and more.
Main Parameters:
LED: High CRI LED
Luminous Flux: 250lm
Max Beam Distance: 24m
Max Beam Intensity: 38cd
Color Temperature: 4500K
Output and Runtime:
High: 250 lumens ( 1h )
Mid: 65 lumens ( 5h 15min )
Low: 8 lumens ( 38h )
Caution Light/SOS/Beacon: 250 lumens ( / )
Product Features:
● Utilizes 9 high CRI LEDs (CRI≥90, temperature color of 4500K) to emit maximum output of 250 lumens.
● Built-in 1200mAh Li-ion battery.
● Integrated intelligent charging circuit for micro-USB charging.
● A single switch controls 3 brightness levels and 3 special modes.
● Takes advantages of highly translucent PC diffuser, allowing all light source to be well distributed.
● Built-in power indicator reports remaining battery power, doubles as a location signal.
● High efficiency constant current circuit.
● Magnetic base for multiple scenarios.
● Made from durable PC materials.
● IP66 waterproof with 1.5 meters impact resistant.
LR10 is a lightweight camping lantern that can even put into the pocket, get from GearVita, it will bring much convenience for you in your trip: https://gearvita.com/nitecore-lr10-led-pocket-camping-lantern.html
You may like:
cheap airdots headset
buy honor watch magic
nitecore lr10 camping lantern
cathy
cathy's picture
OEM CL018 LED light is a USB rechargeable night light which is very good for home use. It has 2 modes adjustable, constant light mode and human body induction mode, so you can choice as you need.
Product Features:
● 5 pcs environment friendly and energy-saving LEDs to light up your night life.
● Super bright LED bulbs, up to 20 lumens output, stays off during daylight hours.
● Automatic sensor auto-on within 10 feet, auto-off after about 25 seconds of no motion detected.
● Turn on only when it is dark and only when motion is detected.
● Included super strong 3M double-sided tape, just stick it to anywhere you want.
● No wiring, multiple ways of use, also can be hung on a nail in the wall, or put it on the table.
● 600 milliampere cycle rechargeable lithium battery.
It is placeable, pasteable, hangable, ideal for anywhere such as bathing rooms, hall, shoe closet, cellar, corridor, etc., and available on GearVita at only $7.49: https://gearvita.com/oem-cl018-mini-led-light.html
Hot sale products:
best airdots headset
buy huami amazfit 2 stratos
oem-cl018 mini led induction light
hank
hank's picture
Last seen: 57 min 29 sec ago
Quote:
Xiaomi philips zhirui bedside lamp
What emitter is used in this “bedside” light source?
Is there any blue in the emission spectrum of this light source that would interfere with sleep?
https://www.sciencedirect.com/science/article/pii/S0022395617308592
(Most LEDs do have significant blue emission, no matter what color temperature they produce.
cathy
cathy's picture
Last seen: 36 min 40 sec ago
The Xiaomi Aqara ZNLDP12LM smart bulb can adjust the brightness and color temperature freely, it has built-in Zigbee wireless communication module. After binding the gateway device, it can flexibly realize remote control, time switch, and multi-device control. E27 interface, high-energy-saving LED bulb, large light-emitting area.
Product Features:
● Acrylic material, strong light transmission.
● Simple bulb design, practical and durable.
● E27 holder, easy to match.
● 9W low consumption, safe, energy-saving and environment friendly.
● The brightness and color temperature can be adjusted freely to meet a variety of scenes.
● Intelligent linkage, achieve more intelligent scenes with Mijia or Aqara other smart products to make life a little cooler.
● When someone comes, the light will be bright; when someone goes off, the light will turn off.
● Intelligent voice control, through the Siri, you can turn on the lights, adjust brightness and color temperature with a simple command.
● Time switch, you can set different lighting modes at different times, such as get up mode, reading mode, relaxation mode, etc..
● APP remote control, just turn on your phone and you can control the light anytime, anywhere.
The smart bulb is suitable for bedrooms, living rooms, bars, hotels, gardens, etc., you can get from GearVita. Not only the the small body exudes a lot of energy, but also the nice appearance will bring you a good mood: https://gearvita.com/aqara-znldp12lm-led-smart-bulb.html
Hot sale products:
buy huawei honor band 4 running version
buy lenovo z5 pro 128gb
xiaomi aqara znldp12lm led smart bulb
