ThorFire TK18 REVIEW, short and sweet with lots of pictures. PROMO CODE!!!
10 posts / 0 new
MechEngVictor
Last seen: 1 year 4 months ago
Bottom line: This is one of the brightest single XPL / 18650 lights I have tested.
Construction, fit and finish are as good as any equivalent light costing 2 or even 3 times as much. This light is SOLID.
No complaints with interior quality of components. Springs are thick, diffuser is solid aluminum, switches are heavy duty, PCB is thick copper, lens is AR coated, (Couldn’t get driver out).
Rainbow looking light color separation is present but noticeably less than other lights with similar led/reflector.
I wish the low was lower, but the turbo is nice and bright.
PROMO CODE 30% off:D4TCRM4C
AMAZON LINK: http://a.co/eMWBQ14
This is for the TK18 SET
Edited by: MechEngVictor on 07/03/2018 - 01:52
bushmaster
bushmaster's picture
Last seen: 1 hour 8 min ago
Sounds like a very nice light. It’d be really nice if Thorfire somehow got around to manufacturing them again and then delivered some to Banggood and they sent me the one I ordered a couple months ago.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Lightbringer
Lightbringer's picture
Last seen: 1 hour 45 min ago
Keep checking Amazon. Might be a 40% coupon-code popping up every now and again. Might not hurt to check freeme’s code in that particular thread, too. Never know if it still works.
wle
wle's picture
Last seen: 20 hours 36 min ago
review is too short
what did you think of the ramping?
- on mine it was too slow, though they may have fixed that
what about having 2 switches? – i never got used to that
what about the length of the thing?
what about the special modes?
    Daniel Behrman, "The Man Who Loved Bicycles".
-Greg Lemond.
Lightbringer
Ramping’s too slow on mine, too, and is linear, not logarithmic, so it kinda flies through the low end and seems to hover without much change on the high end.
2 switches, fine by me. Takes some getting used to, but it’s not a big deal.
Length is fine, as I’ve used an F1, UT20, etc., which are about as long (the UT20 is even longer with the usb charging), but definitely swap the come-with clip for a deep-carry clip, so it sits deeper in your pocket without riding too high.
Really like the pineapple knurling, as it’s different. Grippy, without sanding away your fingerprints with each use.
If TF would fix the ramping to be more like the Q8 or SP32A, faster and logarithmic, it’d be a killer light. Until then, I’m using it in stepped mode, as they’re pretty well-spaced.
wle
wle's picture
Lightbringer wrote:
Ramping’s too slow on mine, too, and is linear, not logarithmic, so it kinda flies through the low end and seems to hover without much change on the high end. ===exactly – needs to be logarithmic and faster
==yes the stepped mode is what i would use too, if it weren;t too long Smile
wle
-Greg Lemond.
Lightbringer
Wellp, I was teethed on stepped modes, so it’s not a big deal to me.
Anyone questioning that should just ask, “If it were stepped with no mention at all of ramping, would I still buy it?”.
The answer to that should be “Absolutely!”, especially at the price I got ‘em for.
wle
wle's picture
wait, what was ‘the price you got em for’? Smile
they actually are super well-made.
wle.
-Greg Lemond.
Lightbringer
It was for a group-buy… not sure if it’s kosher to mention details even after the buy’s over. (If someone else wants to jump in, go for it; just that I’m not gonna be the one to blab.)
Let’s just say a bit less than advertised prices.
wle
wle's picture
i get it, mine was a review sample.. they are still, i will say, made better than any light i have, though the UI isn;t perfect
why can;t someone just make the perfect UI, then everyone could copy it, and BDWI
_Urban Dictionary: BDWI
https://www.urbandictionary.com/define.php?term=BDWI
BDWIwork.
Be Done With It.
just BDWI already!
cf, danny llewellyn 1990 · #be done with it#quit it#get it done#fix it#get the job done. by wle February 25, 2010._
-Greg Lemond.
