Enogear Copper Cube Teardown & Mods
8 posts / 0 new
CRX
CRX's picture
Last seen: 3 hours 45 min ago
Modded:Enogear Copper Cube Nichia 219C 4000K - FET15 - 14500 - Rv Clicky Sw - 870lm..
Stock:Nichia 219C 4000K on KD DTP MCPCB
14mm TIR optic
15mm MTN FET driver
Cyan GITD bezel & tail
Upgraded / recessed switch & cover
Max - 870lm OTF
Length - 75mm
Width - 17mm
Weight - 92g with 14500 cell
It took a fair bit of sanding/ polishing to get rid of the rough machine marks on the shell.
Original brass switch cover is not the best design as it can sort of half pop out at an angle when pressed on one side.
I was pleasantly surprised to find the brass bezel and switch retainer are threaded, nice threads in the body & pill.
These are also available in an 18650 version. Shipping was fast, taking ten days from ordering.
See Nicolicous review of this light here.
Slightly difficult to mod but worth it if you can Thumbs Up
Carbon fibre optional protective carry case with clip.
Made a new copper & brass switch cover.Enogear Copper Cube Nichia 219C 4000K - FET15 - 14500 - Rv Clicky Sw - 870lm..
Changed the emitter to Nichia 219C, FET15 driver and cut some lines into the body.Enogear Copper Cube Nichia 219C 4000K - FET15 - 14500 - Rv Clicky Sw - 870lm..
Edited by: CRX on 09/03/2018 - 16:41
Chatika vas Paus
Last seen: 5 hours 34 min ago
I’ve always wondered where everyone buy these GITD parts. I would like to buy a GITD gasket one day.
Btw, as always, nice mod. And another flashlight on my wish list…
Phlogiston
Phlogiston's picture
Last seen: 4 days 10 hours ago
Nice work!
How do you make the carbon fibre case?
CRX
CRX's picture
I just made that quick from some spare pieces I had.
It is 20mm x 18mm square tube I had left over from earlier builds with an 18mm brass ring jb welded in place at the front, some 2mm x 2mm magnets in the corners at the rear with a Zero Tolerance knife clip. There is some felt & kapton on the inside for a friction fit.
CRX
CRX's picture
The bezel has a tube of GITD tape stuck around the inside of the body above the pill.
The tail bits are powder mixed with UV glue. Thumbs Up
Figgy
Figgy's picture
Last seen: 3 days 22 hours ago
how much for one of this lights but instead fo 14500 battery can you make one that uses 18650?
CRX
CRX's picture
Enogear did have an 18650 version but they seem to have closed shop.
These are a pain to modify.
SKV89
Last seen: 13 min 52 sec ago
PM Fireflies. He owns Enogears too. Im buying a bunch of enogear Stainless steel from him.
