[♛ FreemeGB] Haikelite MT09R 3x XHP70.2 25,000lm & 3x XHP35 Hi 6500LM Flashlight Group Buy -【 ACTIVE 】
425 posts / 0 new
Texas_Ace
Texas_Ace's picture
Last seen: 2 hours 59 min ago
It is possible that they used bypasses at first as they thought it would be cheaper. I kept telling them to do double springs but they didn’t seem to listen at first. My guess is that after doing a few they realized that the labor was going to cost more then double springs and be less reliable.
The good news is that any lights with bypasses should be the early ones if this is the case and thus they should have drivers made with the components I sent them that includes the correct FET.
If you get a picture of the FET we should be able to tell for sure. I know they have 100 drivers with all the correct parts floating around.
Wieselflinkpro
Last seen: 7 hours 24 min ago
We (german TLF) have a Sample in a Passaround. It has a green driver board an a bypass only on the main spring. I have made pictures of the FET, but they are now only on my camera, I have had no time to report my impressions and mesurements. I think only 2 legs of the triangle has the same length.
It looks more as on @Lexels pictures (http://budgetlightforum.com/comment/1360787#comment-1360787) and the double S looks more like a S and not like a 8 as on the fake FET. And the last line begins with a W.
Here you can see the green driver and the spring bypass: https://www.taschenlampen-forum.de/threads/kurzvorstellung-haikelite-mt0...
Texas_Ace
Texas_Ace's picture
Yeah, that is not one of mine for sure, I learned long ago to not do bypasses like that. This is what I was worried about when they said they would start doing bypasses.
My guess is that one also has the good FET.
joechina
Last seen: 37 min 39 sec ago
ZozzV6 wrote:
Brainsick67 wrote:
In your second pic, the 2 pegs that hold into the light to screw the tail cap in, does your guys fall off??? One of mine does..i have to pop it in.
No problem with them. They were soldered in well. I put the grease in the tailcap. They came dry. Maybe some grease will help with yours not breaking again. !{width:60%}http://img1.indafoto.hu/3/9/134029_e227dae7eadb61c0adb17748b381f0a8/2596...!
I made a big plastic washer for the whole tailcap out of some food container. The step in the cap cut into the solder.
Agro
Last seen: 5 hours 34 min ago
Got mine. Smile
I have the one with doubled springs.
JasonWW
JasonWW's picture
Last seen: 12 min 27 sec ago
I prob need to do that…its hard to screw on with batteries in it. Thanks man
Remember that you don’t need to screw it all the way down. Just enough to cover the rubber seals.
KSGER STM32 2.1S Soldering Station Videos - Review Soon
Convoy L6 thread with XHP70.2, Texas Avenger FET driver, Narsil v1.2 ramping firmware (old), lighted side switch, SMO reflector.
Supfire L5-S thread with XHP70.2, Texas Avenger FET driver, NarsilM v1.0 ramping firmware, 2 x 26350 cells, lighted side switch. My mini L6!
Thorfire S70S with MTN FET driver, RampingIOS (D4) and custom lighted side switch.
10 NarsilM user videos for BLF Q8, GT, GT70, GT Mini, Astrolux S43 and ROT66
Texas_Ace BLF Calibrated Lumen tube
Maukka Calibration Lights for DIY Lumen Measuring Devices - Headlight List with prices, specs and features
Jaxmnve M1 Stainless 10180 Keychain light Review  - Lumintop ODF30 Review - Sofirn C8F 21700 Teardown and Review, Sofirn SP33 v2 XHP50.2 Review - My Sofirn Q8 Results - Astrolux S43S 219C Test Results - Lumintop GT Mini Test Results
JasonWW
JasonWW's picture
Yes, this is the style I was thinking of with the bypass on the outside. The person changed it to an inner mounted bypass. It’s good to know I haven’t lost my mind. LOL
LichtAn
Is there a writeup of tips for doing proper bypasses? I don’t know if you want to keep your techniques secret, but I’d like to hear them if you’re willing to share. Thumbs Up
Now this may sound stupid to some of you, but what’s even a good way to hold the wire in place until it’s soldered?
JasonWW
JasonWW's picture
Fine tweezers is what I use. A set of them is cheap online. They are good for holding smd components as well.
Are you asking for soldering tutorials or advanced solder tutorials? Youtube is full of that stuff.
LichtAn
Tips especially for spring bypasses. There are some on youtube, but I doubt any of them shows the best way to do it. I do believe though texas_ace has a very good way figured out.
Texas_Ace
Texas_Ace's picture
Yes, Tweezers are the best idea to hold them in place. Although now days I generally just use my fingers, it ensures I get it done quickly lol.
Far as the technique, it is not secrete, there are a fair amount of pictures of my bypasses floating around.
In a nut shell the idea is to minimize the bending / flex of the wire when the spring is compressed. This causes failures over time as no matter how hard you try the wire will wick up solder and become hard.
So I find that wrapping the wire around the spring about ~90-180 degrees depending on the light to minimize the bending of the wire gives the most reliable bypass.
You end up with a longer bypass then other methods and a little more resistance but well worth the extra reliability IMHO.
I have had basically all my other styles of bypasses break over time but have not had one of these fail yet that I know of outside of a soldering mistake by me.
Agro
Any holster suggestions?
Wieselflinkpro
Here are more pictures and Measurements. And pictures of the FET: https://www.taschenlampen-forum.de/threads/kurzvorstellung-haikelite-mt0...
Texas_Ace
Texas_Ace's picture
Thanks, looks like the Green drivers have the real SIR800 and the red drivers must of been when they switched over to the knock off I would guess.
Jarms
Last seen: 2 months 1 day ago
Interested, XHP70.2 NW, have not received PM code yet
djypo
Last seen: 22 hours 45 min ago
My XHP35 CW has arrived a week ago. But I notice that there is a purplish glare inside the glass when the flashlight is on and my friend also notice this. If I unscrew the head and pull out the glass, it’s gone. So definitely the glass has a problem.
JasonWW
JasonWW's picture
Are you talking about the anti reflective coating? This increases the output of the light.
djypo
Yes, that’s what I’m thinking. This is the only flashlight I have with that purplish glare. Maybe my glass has no AR coating I guess..
baustelle
When is it expected to be available again on Banggood?
freeme
freeme's picture
Last seen: 1 hour 9 min ago
Let me check with them.
freeme
freeme's picture
Instock NOW! Limited sets.
Aleister
Aleister's picture
Last seen: 1 hour 48 min ago
Ordered one XHP 70.2, thank you freeme Beer
Let a flooder be my wife and a thrower be my mistress
Minakoff
Last seen: 6 hours 59 min ago
Disappointed, if it’s not too late, I’m interested in XHP 70.2, thank you , freeme
silicoon
silicoon's picture
Last seen: 3 months 2 days ago
I can not use the code…
When will it become available?
silicoon
silicoon's picture
I received a PM from Freeme.
Taschenrechner
Last seen: 8 hours 14 min ago
Does anybody know a good holster? I tried a bootle cage… but this solution wasn’t very nice…
ssbowtie1
Last seen: 4 months 4 weeks ago
Is this still available? Interested if so.
Sherbona
Last seen: 1 hour 42 min ago
I like how the FLYYE PH-M004 1000D fits my MT09R. I got mine at hkequipment, but I’m sure other places also have them.
Gr8Swammee
Last seen: 3 days 9 hours ago
If available, I am still interested in a code please.
patmurris
patmurris's picture
Last seen: 2 weeks 1 day ago
If still available, i’d be interested in the triple XHP 70.2.
Thanks
