ENEDED
525 posts / 0 new
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 hours 14 min ago
NKON (nkon.nl) is going to have the Keeppower 6000mAh (same cells as Shockli uses) back in stock as of August 23, 2018. I‘m not sure how much shipping (plus customs) will be to the US.
RobertB
RobertB's picture
Last seen: 4 hours 45 min ago
Heck, a 4200mAh cell will keep this SC26 lit all night, and then some.
Jagger
Last seen: 2 weeks 4 days ago
Interested if it’s still available. Thanks.
mortuus
mortuus's picture
Last seen: 1 hour 2 min ago
XHP35 HD CW
XHP35 HI CW
heads up those 2 tints/emitters on banggood shows as sold out in all colors… only XHP35 HD NW and XHP35 HI NW shows as available..
@freeme i asume as with mt09r once colors are sold out its for good?
...where Frugal meets with Flashlight!
hIKARInoob
hIKARInoob's picture
Last seen: 13 sec ago
mortuus wrote:
XHP35 HD CW
XHP35 HI CW
All colours of the SC26 are production colours, unlike with the MT09R. At least this is what I’ve understood.
patmurris
patmurris's picture
Last seen: 2 days 16 hours ago
I received my second SC26 yesterday – Blue HI CW.
The first was Brown HD NW so i can compare both tints and emitter version. From a couple beams outside and side by side, i can tell there is quite a difference between HD and HI. The former has a wider hot spot, more flood but still some throw. The HI has a tighter hot spot and does throw further. I do like the HD beam because it is more balanced (some flood and some throw) and more useful to me.
Apart from that, i noticed the 18650 (long) tube must have a smaller OD at the tail because the tail cap is not flush as it is with the 18350 tube…
mortuus
mortuus's picture
sounds great, i chose the HD for a more wider hot spot, seems more useful too me but we all have our own preferences which is good.
Newlumen
Newlumen's picture
Last seen: 1 day 12 hours ago
I like both HD and HI actually.
delete
Last seen: 5 hours 32 min ago
Is a sc26 can fit in 21700?
mortuus
mortuus's picture
No only, 1×26350 / 2×26350 / 1×26650 works.
delete
26650 can use 18650 and spacer
21700 has diameter lower than 26650
But the long is 70mm
Is so close to 65mm
Is it could be to fit it?
PBWilson
Last seen: 1 hour 10 min ago
I just measured my two blue 26350 cells and they are 34.9mm long.
Multiply that by 2 and you get 69.8mm.
I would suspect that there’s enough room in the spring travel to make up .2mm so a 21700 should fit.
mortuus
mortuus's picture
ok but why use a cell type that is not advertised that u can use? i dont get it if u really want a light for e special type of cell then why not buy something else then?
PBWilson
Greater flexibility and just curiosity in general I’d guess. Also if new 21700 cells are produced with greater capacity and have increased performance, it’s nice to know that there is one more light on the market that could use them.
mortuus
mortuus's picture
yea i agree, but 26650 cells have also decent capacity compared to 18650, u will get some good runtimes on a 5000mah cell.
clemence
clemence's picture
Last seen: 1 week 2 days ago
Being able to use 21700 is simpler for some people like me who doesn’t want to carry/buy multiple battery types. I’m getting used to 18650 because this size fits my headlamps, EDC, and power bank without having to check which battery to get from my backpack during travelling.
Once 20700/21700 becomes widely popular I’ll do the same to all my travel gears.
- Clemence
Gebe
Last seen: 17 hours 31 min ago
Since we’re discussing 26500 cells, I had a couple of extra unprotected 4000mah yellow, flat top unbranded 26500 cells that I purchased from mtnelectronics awhile back.
At the time Richard described them as “King Kong” brand cells though they are unbranded and are not labeled as such.
I’ve been using them in my SC26 and they seem to work fine. With all these higher capacity 26500 cells around now, do you folks think I can get the most out of the SC26 capabilities using these cells?
mortuus
mortuus's picture
well u get more or less only more runtime using cells with higher capacity. Not like this light draws that much amps anyways.
pennzy
pennzy's picture
Last seen: 1 hour 48 min ago
I have been learning as much as I can about 26650s waiting for my SC 26 to come in. The Shockli 5500 will give the longest run times right in it’s discharge sweet spot at 6+ amps . Now trying to buy one stateside is the challenge. The only US supplier is Mtnelectronics and they are out of stock .With all the fake cell talk from China I am afraid to order from them. Might have a light without a battery soon.
clemence
clemence's picture
Try this: https://www.aliexpress.com/item/2pcs-VAPCELL-INR26650-5900mAh-20A-HIGH-P...
Shopping via mobile phone is cheaper by few cents.
I’ve been using its 18350, and probably it’s the best 18350 available today. Looks like Vapcell uses new battery chemistry.
http://budgetlightforum.com/comment/1361467#comment-1361467
- Clemence
Agro
Last seen: 21 min 29 sec ago
I purchased my cells from Shockli directly, by e-mail. The experience was very good.
Agro
- Clemence
There is some data that hints on availability of a better 18350:
http://budgetlightforum.com/comment/1360676#comment-1360676
But unless there’s more evidence I suspect that’s just a test fluke.
clemence
clemence's picture
- Clemence
Thanks, I’ll check it
- Clemence
pennzy
pennzy's picture
I purchased my cells from Shockli directly, by e-mail. The experience was very good.[/quote]
I just sent a message on their website. Sounds like they email back with the price?
pennzy
pennzy's picture
- Clemence
Know of any tests on the Vapcell5900?
clemence
clemence's picture
- Clemence
Can’t find any. But I’m pretty sure some already queued in HKJ’s to do list.
- Clemence
Agro
- Clemence
I’m not aware of any tests of this cell, but I would expect it to be exactly the same as Shockli 5500 under the wraps.
I just sent a message on their website. Sounds like they email back with the price?[/quote]
Yes.
patmurris
patmurris's picture
For those who have trouble getting cells shipped to their country, check your local vape shop. They usually have quite a choice of high drain 18650, 26650 and now 21700.
mortuus
mortuus's picture
pennzy why dont u just buy a similar battery from them? it will work just as good. No reason to not buy anything else if that brand is sold out u will atleast have a battery and can later buy when them get them back in stock.
http://www.mtnelectronics.com/index.php?route=product/product&product_id...
pennzy
pennzy's picture
I figure if I am going to step up in size I want to get the long run times. Shockli returned my email. I have to tell him what country I live in and if it will be used in a flashlight or e-cig. ? Most of Mtn’s 26650 are out of stock. I could probably run a 18650 30Q in the SC26 with a filler of some sort.
