Small flashlight with red light
16 posts / 0 new
Anthon
Last seen: 5 hours 53 min ago
Is there a small AA or 18650 light with red light and at least three modes with moonlight (for the red light)
I need one but I think I’ll have to build one using a S2+ host or similar
Edited by: Anthon on 07/04/2018 - 10:22
bmengineer
bmengineer's picture
Last seen: 3 hours 33 min ago
What’s your budget, and your definition of small? What form factor do you want?
Zebralight makes the H502r . There’s also the Armytek Dobermann in red, and the Jaxman E2L color . You could also order a red build from PFlexPro, but at that point you could save a lot of money building your own.
Find all my reviews of flashlights and more gear at www.bmengineer.com
bushmaster
bushmaster's picture
Last seen: 1 hour 43 min ago
Nitecore EC21 might be a possibility. I found one for under $30 a year ago but they seem to be going for $60 on most sites now.
Keep your nose in the wind and your eyes along the skyline.
Del Gue
Anthon
bmengineer wrote:
What’s your budget, and your definition of small? What form factor do you want? Zebralight makes the H502r . There’s also the Armytek Dobermann in red, and the Jaxman E2L color . You could also order a red build from PFlexPro, but at that point you could save a lot of money building your own.
my budget is very small
I found a deal for a eagletac D25A Ti with xpl HI, I could order a red XP-E2 from kaidomain and swap it
It has moonlight mode and always start in the lowest level, which is fine
Anthon
just received the D25A Ti, but it’s so nice that it’s a pity to mod it to red light only. I think I’ll swap the emiter to a NW one and keep looking for a cheaper host
2 DOGS
Last seen: 6 hours 42 min ago
Maybe a P60 drop-in would work for you.
Just pick up a cheap 501B or whatever.
Red p60)
Itsme
Last seen: 2 days 10 hours ago
Not sure what you’re expecting from the red light but the nitecore EA 11 and EC 11 both have a multiple white light mode’s as well as a single red light mode
Lightbringer
Lightbringer's picture
Last seen: 5 hours 54 min ago
BE CAREFUL trying to swap a red LED where a white one exists now.
The voltage drop for a red LED is around 2V, and about 3V and change for a white one.
If the driver is linear, and has, say, a bunch of 7135s which have to eat the excess voltage and burn it off, you can cook them. 4.2V from the cell minus 3.2V from a white LED means a 1.0V drop. 4.2V from the cell minus 2.2V from a red LED means a 2.0V drop, or the 7135s will have to burn off twice the voltage, thus twice the wattage.
If the driver is cheap and just has a bunch of parallelled resistors as a ballast, then twice the voltage difference means the red LED will be hit with twice the current of the white LED. Ouch.
It sounds like a simple swap, but there are lots of potential problems doing it. Best to either get a drop-in made for a red LED, or just get a light with a red LED designed-in, or make your own drop-in from scratch. Even a simple contact board with a hardwired resistor would be better than cooking a driver or the LED.
azj
What about something like this? Doesn’t have 3 modes, but it’s variable brightness..
https://www.amazon.com/Orion-5755-RedBeam-LED-Flashlight/dp/B0000XMUZA
I use red flashlights for my astronomy hobby. They don’t kill your night vision.
I have too many hobbies…
Anthon
I didn’t know this, I thought they were 3v leds
So if I put a red led to a normal light like the sofirn SF10, lumintop tool AA, etc it’s bound to fail someday? I think the lumintop uses PWM
puglife2
Last seen: 1 hour 24 min ago
why not just tape a red filter on it?
Firelight2
Firelight2's picture
Last seen: 1 hour 23 min ago
Not cheap, but you could get an Acebeam UC15. It’s powered by 2× 10440 and is about the size of a small 1× 14500 light.
Comes with a very bright red LED with one mode. Also has a white LED with several modes (max 1000 lumens), and a UV LED. Interface is quite nice.
Anthon
I have one, but the red is too bright
Pete7874
Pete7874's picture
Last seen: 2 hours 4 min ago
Yup. You could get a red diffuser cap for less than $2.
Lightbringer
About 2.0V-2.2V or so. Old-timey red LEDs were about 1.6V.
It probably wouldn’t be too happy.
PWM still would send high-current spikes to it, and accidentally hitting “turbo” might fry it.
dw911
Last seen: 1 week 3 days ago
Are you sure you need a red light? I remember a thread on here, where in testing a low luminar white light was better at persevering night vision and gave a more usefull light than using a red light or red filter.
Cant find the thread at mo
