Sofirn SP70 Alone $50, PM for AMZ US CODE(LIMITED)
2233 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 49 min 57 sec ago
10,500 is the most I’ve ever seen from an XHP-70.2… and this is with my lightbox calibrated and diffused so the meter reading is actual numbers, I really feel like my meter is showing a little low but it’s where I wound up with 6 diffusion panels, the Maukka calibration lights were almost spot on, but low on the S2+ even if only a little.
I get 253.25Kcd at start and 236.75Kcd at 30 seconds on the meter at a 5M reading.
This is on the box, sorry, I guess I flipped the i8 to landscape AFTER I started the video. Technology sometimes eludes me…
JasonWW
JasonWW's picture
Last seen: 6 hours 31 min ago
My light has a centering ring.
Click this to go to signature links.
lstmichel
Last seen: 4 days 19 hours ago
JasonWW wrote:
I hope that everyone who has recieved their SP70 is liking it. Big Smile
Mine arrived 1 week ago with the standard (non-HD) batteries.
I was thinking of ordering a couple HD’s – as I understand that will increase the output a bit.
If there is a BLF version in the works, I would just wait for that light.
So the question is – when might the BLF version might be available?
TIA
the4ds9
the4ds9's picture
Last seen: 3 weeks 3 days ago
Let the obsession begin. Again.
NMJoe
I’ve been trying to get the code via PM for the last few days. I wonder if they are out of the office?
BlueSwordM
BlueSwordM's picture
Last seen: 2 days 15 hours ago
Yes they are.
NMJoe
Thank you!
Funtastic
Funtastic's picture
Last seen: 2 days 5 hours ago
TIA
Disappointing news for the Sofirn 26650 HD cells.
Measured at 30 second with my calibrated lumen tube – 4970 lumens
So much for their 6800 lumen measurement they stated with these
Texas Ace Lumen Tube calibrated with maukka lights
contactcr
Last seen: 12 hours 10 min ago
You sure they are even the right ones?
Funtastic
Funtastic's picture
Yes, they have the 5000mAh 25A wrapper and have the new button top
BlueSwordM
Fully charged?
Funtastic
Funtastic's picture
BlueSwordM wrote:
Fully charged?
Yeah, they’re charged to 4.20v and checked again with my DMM.
I’ll test them later with my CBA because it seems they’re discharging unevenly. After 30 sec they were 4.14v and 4.18v
JasonWW
JasonWW's picture
TIA
Please provide some context.
How many lumens do a different set of high drain batteries produce? What other cells do you have?
Funtastic
Funtastic's picture
TIA
After bypassing the springs with 20awg I get 5900 at 30 sec.
I’ll charge up a couple 30Q’s as that’s the best I have
BlueSwordM
Ok what?
5900 lumens is nothing like we would expect.
Would be really sad if you got dud 26650s, and the 30Qs get around 8000 lumens.
Funtastic
Funtastic's picture
I have another SP70 that should be here either tomorrow (Fri) or Monday so I can check with those cells.
Sooooo I just noticed one cell has a dent on the negative and the nipple pressed in :/ I’m guessing this is causing the low numbers. I think Jason had this happen awhile back.
I’ll add some solder and report back. If this is the cause I’ll edit my original comment
BlueSwordM
Oh I’m relieved.
Good luck on it.
Funtastic
Funtastic's picture
Decided not to solder and use a neodymium magnet but that made no difference.
My tracking updated to show my other SP70 is due tomorrow.
JasonWW
JasonWW's picture
One of my cells also has a dented bottom. It’s a consequence of shipping big cells in series. When the box gets dropped or thrown around, the 2 cells slam into each other. I don’t think it would effect it’s performance. My HD cells pull slightly less amperage than my Black Liitokala’s.
As far as lumens, my L6 with Aspire 4300 measured 5500 lumen at turn on (19.6A) and 5250 at 20 seconds (18.4A).
With black Liitokala it measured 5300 lumen at turn on and 5100 at 20 seconds (17.6A).
This is with my Maukka calibrated TA Lumen Tube. I don’t know how some guys get these big lumen numbers.
I’ll try to measure the SP70 lumens tomorrow.
Funtastic
Funtastic's picture
At the end of the day the SP70 is much better than the Convoy L6 so I’m happy. Purchased 7pcs to sell. Don’t think I’ll be getting anymore L6’s now unless Simon changes the UI.
The 30Q’s only achieved 100 more lumens totaling 6000 at 30 sec
JasonWW
JasonWW's picture
Funtastic gained 1000 lumens by adding spring bypasses. That tells me the factory dual springs might be a bit high in resistance.
BlueSwordM
Yeah
They aren’t using steel springs, but they could be using the “lowest” conductivity BeCu at 22% IACS,, which would be limiting the current quite a bit compared to the C17530 alloy that I use at 38% IACS.
DB Custom
DB Custom's picture
I changed the MOSFET and upgraded to 16 ga wires. And bypassed the springs leaving them dual springs.
BlueSwordM
Doesn’t that make the spring array super stiff that way?
At least resistance isn’t an issue. Smile
Funtastic
Funtastic's picture
Mate, did you bypass both dual springs or just the single outer springs? I just bypassed the large outer springs
DB Custom
DB Custom's picture
As long as the bypass is in contact with the cell and the other end is on the driver pad that’s all that really matters. I thought about it possibly making the dual stack too stiff but it works with my pair of 30T’s so I can’t complain, figured stiff would be good for 26650’s (which I don’t have a matched pair of at the moment)
Funtastic
Funtastic's picture
Thank you for your reply. That’s exactly what I’ve done so that’s great.
I’m guessing you have the 16 ga wire on the outside of the spring? My 20 ga was hard enough to fit inside
DB Custom
DB Custom's picture
I used 20 ga in the springs, replaced the 18ga leads from the driver to the LED’s with 16ga. Wink
Scallywag
Scallywag's picture
Last seen: 16 hours 45 min ago
My 26650s are out for delivery today. Shockli 5500mAh, my favorite cell. Flat-top, so I'll figure something out.
Of all things, the wife is suggesting I keep the non-BLF SP70. Who am I to argue? I figure I'll probably get the BLF Edition too, and then gift this one to a friend in the Air Force. She wanted a copy of my L6, including the lighted button.
I tried looking, but didn't see a pic of the switch PCB. Has anyone had it out yet? I'm planning to swap the LEDs to different colors if possible.
EDC Rotation: ZL SC62 | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01
EagTac D25C Ti | DQG Slim AA Ti | UF-T1 by CRX | Olight S1 | Klarus Mini One Ti
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
In-progress: Supfire M6 3xXHP50.2
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
the4ds9
the4ds9's picture
I discovered by reading the Owner’s Manual the Group 1 (Non-ramping) has six brightness levels. The Turbo mode brightness in Group 1 (Non-ramping) is only available by double-clicking the side switch.
