Help-How to Convert Light From x3 To x1 Battery ?
11 posts / 0 new
202bigmike
Last seen: 10 hours 50 min ago
I have a Defiant flashlight—Listed as 850 Lumens , it has (x3) LED’s , uses “C” cell Alkaline batteries (x3) that
was sold by Home Depot. I want to convert flashlight to use (x1) 18650 battery. Other then using a battery extender,
what else should be done to the light , in order to accomplish the change to the use of one lithium battery for it ?
Edited by: 202bigmike on 07/10/2018 - 23:53
toddcshoe
toddcshoe's picture
Last seen: 6 hours 34 min ago
Sounds like a battery extender is all you really need. I have seen guys use short pieces of copper pipe with caps on the ends to finish off the connections and using some tape or shrink wrap to keep the copper tube from hitting the flashlight tube. Then maybe using some plastic spacers on the 18650 to make up for the larger diameter of the C cell.
Or maybe run it with 3 Eneloops with C sized spacers they use. That would work I think.
202bigmike
RollTide , Thanks for your reply. I was thinking , will I maybe have to change a driver on the light ?
toddcshoe
toddcshoe's picture
I don’t think you would have to change the driver as long as you are happy with it. The voltage of 3 C cells in series vs 1 18650 is so close that it won’t matter to the driver I wouldn’t think. The driver doesn’t know the difference between LiIon and Alkaline as long as it sees it’s DC voltage tolerance.
202bigmike
I asked the driver question because I remember somewhere
and somehow something was said or written about changing
the drivers on this type of battery swap. If this function could be
named a battery swap.
mmalive
Last seen: 11 hours 33 min ago
Read the thread about this flashlight. I did MODs to accept 18650, 26650. CR123A. I only use “ C” alkaleaks for emergency.
toddcshoe
toddcshoe's picture
Doh! Forgot about that thread. Here it is I believe. http://budgetlightforum.com/node/52834
202bigmike
I replied to that thread back in 2017—Posts #4 & #7 and just flat-out forgot about it because of nothing after #8.
As you can see , there were NO other posts/answers on it from 2/19/2017 until 11/17/2017.—-Nine months !!
It has grown after that.
202bigmike
Question [quote=mmalive]Read the thread about this flashlight. I did MODs to accept 18650, 26650. CR123A. I only use “ C” alkaleaks for emergency.[/quote
What & How did you do it Question
Firelight2
Firelight2's picture
Last seen: 7 hours 58 sec ago
Any light that will run on 3 alkalines should run just fine on 1 lithium ion cell with no change in driver. All that’s necessary is using a spacer so that the battery or batteries can physically make contact with the ends of the battery tube.
202bigmike
Do you have recommendations for any types of spacers ?
