Faradeus : self-charging flashlight
59 posts / 0 new
Anna_Landik
Anna_Landik's picture
Last seen: 11 months 2 weeks ago
Enderman wrote:
If a lithium battery is left attached to a circuit for extended periods of time, even if the circuit is off, it will slowly discharge and drop below minimum capacity causing permanent damage. Hopefully the flashlight has a physical battery disconnect or that lithium cell will be dead long before 5 years pass.
It is physically disconnected with button with fixed positions.
WalkIntoTheLight
Last seen: 20 hours 4 min ago
That’s a good point. Hopefully the parasitic drain is very low. It could be very low; I have a Zebralight that has a parasitic drain of only 2.4uA. That would last for decades, depending on the size of the battery (it’s probably something like 300mAh).
How long do glow sticks last in storage? It seems that a bunch of those might make for useful emergency light, when every other light source is dead. They’re about 10 cents each on Amazon. But if they only last a few years before the chemical breaks down, then that’s not much use.
Or a road flare. Good for light, and scaring away bears and wolves and zombies.
Ronin42
Ronin42's picture
Last seen: 3 months 4 weeks ago
Korean girls try Shake Weight (ENG Sub)
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Couchmaster
Last seen: 2 weeks 1 day ago
That’s so awesome! Good luck with the sale, fantastic little project, thanks for sharing it. Put it up on Candlepower as well.
Tom Tom
Last seen: 3 months 1 day ago
Here’s another idea, make it reverse, i.e. pulse the coil to make the magnet shake. Good vibrations …
Vegas LED Fan
Last seen: 3 weeks 20 hours ago
Sorry about being the cynic here but I have yet to see a Kickstarter project that I would put a dime toward. Sometimes it just that they are a solution in search of a non-existent problem, sometimes they are an overly complicated solution for a very simple problem, and often the eventual price is way out of line with the value received. Sometimes it is even a well known company that doesn’t want to put their own funds toward R&D but go the the public instead. I admit that I don’t purposely go to Kickstarter but have followed a number of links to the site.
I tried at least two Faraday lights that I picked up cheaply at garage sales or second hand stores. Both were conventional flashlights with LED bulbs. The most recent one actually had two lithium ion batteries in it but they were two rechargeable 40 mAh button cells. I have no idea how long it would power the light before needing to be recharged as I gave it away. It did put out a decent amount of light. The most annoying thing was the slide made the flashlight unbalanced, much heavier at one end than at the other. When I want a flashlight, I use a cheap XML-T6 LED flashlight which sell for less than $8 and is powered by a single 18650 battery. Cheap, lightweight, bright, rugged, and feels right in my hand. The flashlight, two high quality Panasonic batteries, and the charger were way under $25. If I want something small it is the 100 lumen chip-on-board key chain light that operates on three AAA batteries. It is lightweight, compact, runs for hours on one set of cheap carbon batteries and cost me about $2.
xxx
xxx's picture
Last seen: 1 month 4 weeks ago
Why not?
Normal people see us who have more than 2 flashlights is weird Big Smile
Why need flashlight in big city? why need flashlight if we have electric power sources? why need more than 1 battery
I think with this flashlight we never forget to charger battery anymore.
Walk around, and you charger faradeus Smile
Enderman
Enderman's picture
Last seen: 1 hour 9 min ago
Good Smile
will34
will34's picture
Last seen: 36 min 33 sec ago
I got clickbaited into this thread thinking that someone has come up with a “self charging flashlight”. But by “self” it clearly meant you charge it yourself, literally.
Maybe I was hoping to see a flashlight that converted WiFi and celullar signal into DC current. Perhaps it would take one month to charge 100mAh, but it charges itself.
I had a hand crank emergency light and at the time the concept seemed to be nice, but given the size of the unit one could’ve fit batteries that provided 200+ hrs of light. Ask any search and rescue personnel and they would rather take a ready to use light with long runtime than a “infinite runtime” light that requires physical user input.
This might come in handy in a long term survival situation, but one has to consider if it’s worth wasting your energy in exchange of illumination.
Sorry but as many have stated above this is another solution to a non-existing problem, real innovation is not about selling “here’s why you need this”.
Truck
Last seen: 2 hours 28 min ago
if this works it would be the perfect light for the glove box!
Anna_Landik
Guys, this project is not about inventing something HUGE (though I have some ideas about real SELF charging power-source). This is a small camapign focused on making classic flashlight on modern quality components.
As I’ve shown on model in video – several shakes and you already have a light.
Enderman
Enderman's picture
Lithium in a glovebox isn’t a great idea.
Plenty of threads about the temperature changes inside cars and why alkaline/nimh is what people use to keep in a vehicle.
Anna_Landik
Enderman wrote:
Lithium in a glovebox isn’t a great idea. Plenty of threads about the temperature changes inside cars and why alkaline/nimh is what people use to keep in a vehicle.
You’re talking about Li-ion, Li-pol is absolutely another pair of shoes.
Enderman
Enderman's picture
I’m talking about all lithium batteries. Lipo is a type of lithium ion battery.
Lipo packs are the same thing as a cylindrical lithium cell except with a slightly different name because of the pouch format.
If anything it is more dangerous because it does not have a metal outer shield.
https://en.wikipedia.org/wiki/Lithium_polymer_battery
Real polymer-electrolyte batteries don’t exist in the consumer market.
I would have expected someone designing a flashlight to be aware of the different types of battery technologies that exist and don’t exist…
patmurris
patmurris's picture
Last seen: 5 hours 6 min ago
Anna_Landik wrote:
patmurris wrote:
…i fear the Li-Po battery will be dead from aging when i finally need it.
Li-po battery will start degrade after ~5 years but supercap is almost eternal. It has capacity for ~ 2 minutes of light.
A flashlight that lose 96% of it’s capacity after 5 years sounds more like disposable rather then eternal. Not different from all the consumer electronics we get these days. I strongly suggest the battery should be easy to replace, which implies using some standard format like CR123 or AA.
From the prototype pictures on your project page, there does not seem to be any kind of circuit board with electronic components, except for the rectifier bridge. Are you planning some kind of charging circuit for the battery and a driver for the led, or is it going to be all on direct drive?
Anna_Landik
Change the battery after 5 years. What’s the problem?
It will be replaceable.
Simple driver is inside. It stabilizes current to achieve same brightness on most % of charge.
Anna_Landik
Ok, ok. English isn’t my native language (which is clear) and I don’t know exactly all needed technical terms in this language.
I mean that Li-pol battery doesn’t have liquid electrolyte.
Enderman
Enderman's picture
That doesn’t really matter, it’s still as dangerous as regular li-ion cells and keeping it in a vehicle that could get to -30C or +70C is a bad idea.
Another issue is that lipos lose 20% capacity after a few hundred cycles (up to about 500 cycles for the highest quality ones), so a flashlight which needs to be recharged every 60 minutes isn’t going to last very long.
If the flashlight is used for an hour every day it would drop to 80% capacity in less than two years.
It seems like this product is just for a “once-in-a-while” type of use, not something for everyday work.
WalkIntoTheLight
A couple of 18650 batteries will give you the same energy that would take hundreds of thousands of shakes to generate in a shake light. You’re just never going to shake it that much. Certainly not in the 5-year time-span that the internal battery lasts in the shake light.
A single 18650 light (such as a Zebralight or other efficient light) will give you almost 100 hours of run-time at 20 lumens.
You’d shake yourself to death before you’d generated that much energy from a shake-light.
If you want an emergency light, get a real flashlight and decent battery for it. Even a AA will do fine.
This shake-light might be a fun toy, but it’s not going to be practical for emergencies.
Lightbringer
Lightbringer's picture
Last seen: 27 min 51 sec ago
Actually, I can see this being a sort of keychain light, if small enough. No need to worry about coin cells, alkaleaks, etc. Just give it a coupla shakes to be able to light up a keyhole, grubble through a purse, etc.
Limited niche, but still probably quite handy if marketed as such.
Anna_Landik
Enderman wrote:
Another issue is that lipos lose 20% capacity after a few hundred cycles (up to about 500 cycles for the highest quality ones), so a flashlight which needs to be recharged every 60 minutes isn’t going to last very long. If the flashlight is used for an hour every day it would drop to 80% capacity in less than two years.
I can’t imagine this to be an edc flashlight.
You’re absolutely correct.
Anna_Landik
Can’t make it efficient and very small at the same time. I need many coil turns and big magnets to generate energy.
WalkIntoTheLight
Well, it’s far too big for a keychain light, but I get your point. Still, a small 1xAA light with a Energizer Lithium cell in it, will provide about 24 hours of light at 20 lumens. And, the battery will last for 10 years or more, double the length of time that the internal shake-light battery will last. And work better in the cold, etc. You’re just never going to shake the light enough to generate what even a single AA cell provides.
Gebe
Last seen: 1 week 1 day ago
I guess I’m the guinea pig then. I’ve had multiple flashlights with lithium cells in both our cars for years with temps ranging from 0 to 100 degrees with no ill effects.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 1 hour 51 min ago
Most men have a lot of experience doing this motion already should be no issue for the average male to charge this light lol
WalkIntoTheLight
I think it depends on how long the battery sits at very high temperatures. I think there’s more worry about leaving lithium-ion cells in hot cars than is warranted.
It is true that long-term storage at hot temperatures will degrade lithium-ion cells much more rapidly than room-temperature, especially when stored at full-charge.
However, your car does not stay hot all the time. It doesn’t even stay hot most of the time, even in hot climates. It’s not hot at night, and it’s not hot in the morning. It’s also not hot unless you park in the sun. Oh, and it’s not hot on cloudy days. Nor is it hot all winter, and most of the fall/spring. And it’s not hot when you’re driving.
I suspect most people’s cars are hot less than 10% of the time. So, over the course of a year, it probably equates to less than a month in “hot storage”. That’s not great for your battery, but it’s not going to kill it anytime soon.
Gebe
Sounds reasonable WITL. Our cars do sit outside in the open all year and in the summer get plenty hot for several hours a day.
Didn’t mean to derail the thread. I apologize and carry on.
P.S. Seems like Anna_Landik’s covering all bases with this and it does look interesting.
wle
wle's picture
Last seen: 7 min 24 sec ago
patmurris wrote:
Interesting project indeed.
One thing i’m worried about is i’ll never use it… unless i ran out of every other possible light source, including a lighter or matches. And then, years after, i fear the Li-Po battery will be dead from aging when i finally need it. How long will the battery last unused? In most situations i’d rather carry a couple AA lights and spare batteries rather then this somewhat big light.
Still, if i was stuck in a remote cabin for days and was out of every other power source, i’d be glad to have it.
Eternal flashlight? Will it be serviceable to change parts or upgrade it?
Tom Tom wrote:
Well, if the shaking action is similar, it could be easily used by the male population, and provide an ECO alternative to onanism.
Considering this shake-me light dimension i’m sure some 3D printed add-on/sleeve could easily turn it into an eco adult toy… Love is energy! Love Don’t forget to remove the add-on before going out with your light during a blackout though… Facepalm
—all you have to do is add a little solar unit and the reg ones will go forever til the li ion dies
wle
