Emisar D4S review
2431 posts / 0 new
iamlucky13
Last seen: 11 hours 43 min ago
A part of me wants to call it overkill, but that aux LED board with its own regulator and balance resistors sounds sweet.
Lexel, can you clarify, which one is expected to become available assembled from intl-outdoor?
djozz
djozz's picture
Last seen: 3 hours 12 min ago
Lexel wrote:
Oshpark 2Oz are 0.8mm thin, this should be enough
on chineese fab on panel I would go to 0.6mm
Thanks, Cool , ordered!
Lexel
Lexel's picture
Last seen: 1 month 6 hours ago
has not been decided yet
The resistors and the LDO costs in serial production less than 20 cents so why not stick it on it
Of course a sort of LVP like I am planning on my tail boards would be possible as well, but that costs like 0.6$ more
Tom Tom
Last seen: 1 year 4 months ago
Lexel wrote:
also made a programming adapter for my future drivers same order in 2 Oz! Fits those pogo pins from banggood https://www.banggood.com/100Pcs-P50-B1-Spring-Test-Probe-Pogo-Pin-Dia-0_...
Way to go!
But pogo pins do need some support, they are long, thin and bendy. Which is why I suggested a 3D printed support.
Perhaps a big dollop of hot glue might suffice.
Back in the day my kit was designed for ATE on a GenRad/Teradyne bed of nails, with guided probe for detailed stuff. Everything made extremely precisely and solidly.
Not necessary for a torch. Just a common flashing interface.
Nitetime
Last seen: 1 week 3 days ago
I love it
hodor
hodor's picture
Last seen: 6 min 16 sec ago
Thanks for the review, loving the aux lights!
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 7 hours ago
I fear, you won’t have fun soldering pogo pins aligned with your design, lexel, something like this with a notch for automatic alignment might be better. Was still difficult to solder though, especially with iron, I was successful with hot air finally. But hot air might cause problems with a 2-sided design.
Tom Tom
A SIM card connector (mini, micro, nano) could work, but is OTT. And no room.
Pogo pins onto vias or pads is the obvious way forward, at the moment.
This has to come, since MCUs will have no external pins to clip on to, even if there is keep-out area for a clip.
ToyKeeper
ToyKeeper's picture
Last seen: 9 min 24 sec ago
I’m hoping Hank might offer a flashing kit too, but I don’t know if that will happen. For now, I could stand to get some pogo pins (or really any pins) to put into my ribbon cable, since I haven’t had a chance to try out the flashing pads yet.
voip
Last seen: 1 month 1 day ago
such a cool light, hope it won’t be too pricey. thanks for the first look
melainotype
melainotype's picture
Really hope this will be available in the new white surface as well as a floody optic option!
fixed it
Last seen: 7 months 1 week ago
And red or amber aux LEDs. We can always dream can’t we? Smile
ToyKeeper
ToyKeeper's picture
The pink surface-mount LEDs are nice. I built a clock with those… one LED per pixel.
I’d love to see a mixed LED board with two resistors to adjust the relative brightness of two channels. They’d both still be on at the same time, like the current design, but the colors could be a lot more interesting. Like doing half-and-half with royal blue and photo red emitters, to make a really vivid purple.
But TBH, I don’t care all that much about the aux LEDs. I’d much rather have the option to get a primary MCPCB with two LH351D 4000K 90CRI and two LH351D 5000K 90CRI emitters. I think that would be just about ideal, both on the D4S and the original D4. This sort of mixing doesn’t work as well on a triple, but a quad is a perfect host for it.
Man Without Shadow
Man Without Shadow's picture
Last seen: 42 sec ago
Purple anno and purple LED’s (blue/red)!
When I'm spending mony foolishly, I like to do it wi$ely...
I have all the flashlights I need, but not as many as I want...
Eraursls1984
Last seen: 4 weeks 23 hours ago
Or 2700K/3000K and 5000K. The problem with that is there is no optic for that. Mule only?
ToyKeeper
ToyKeeper's picture
Er, it could do 3000K + 5000K if you wanted it to be a 4000K light. There’s no problem with the optic which would interfere with that.
I want it closer to 4500K though, and neither the 219c nor the LH351D comes in that tint. So I may try to mix 4000K and 5000K emitters. Plus, it’ll probably look a bit better than a native 4500K emitter would anyway, because tint mixing is cool that way.
Or I could go even wider like I did on my wide-spectrum BST, with four different tints ranging from 3000K to 6500K, but that’s trickier to get right, looks weirder up-close, and makes rainbow shadows. The result on mine is pretty fantastic though, and it really makes colors look vivid.
Eraursls1984
Ah, I just re-read your original comment. I thought you said 4 of each (kind of like the BLF LT1).
maukka
maukka's picture
Last seen: 9 hours 28 min ago
Has anyone tried mixing the 4000 and 5000 K LH351D with the clear Carclo quad? Does it blend well or are the corners visibly different and you should swap to a frosted one? And does the angled quad board help compared to the old version?
JordanZHP
Last seen: 50 min 46 sec ago
Do we think this will support 26350 with a short tube?
djmcconn
djmcconn's picture
Last seen: 11 hours 15 min ago
Please hurry!!!!! I can hardly wait to spend money I don’t have on another light I don’t need!!!!!!!!!!!! Thanks to all involved. I really want this one!
Lexel
Lexel's picture
The board I dersigned for the D4 can technically run each LED on a different color does not change brightness down to 2.8V
but I guess there is not much demand in a board for the D4S that can do that
staticx57
Last seen: 8 hours 14 min ago
I’d certainly like one Big Smile
djozz
djozz's picture
I will make one! But no matter the demand, the design is already a joy to look at Smile
patmurris
patmurris's picture
Last seen: 1 hour 50 min ago
Lexel wrote:
The board I dersigned for the D4 can technically run each LED on a different color does not change brightness down to 2.8V …but I guess there is not much demand in a board for the D4S that can do that
I honestly never cared about any “aux” light coming out of any flashlight other then the main beam… Then came GITD orings and tape under the optic, lighted switch, tritium, and now this!
Why do i care now? Facepalm
Note that if those aux leds where located under the optic, close to the main leds, they may allow for tint tuning somehow?
ToyKeeper
ToyKeeper's picture
My 5D+3D+3D+2B light is now using a MCPCB with rotated pads under a clear optic, and it looks pretty decent. The center blends well, and instead of four blatant corona petals it has a bunch of much less obvious petals. The frosted optic is of course much smoother, but the clear optic works okay and throws better.
Polyesterboy
Last seen: 1 year 11 months ago
Do we have any timeframes to go by here? Will this be on the market by end of year? Or is this a longer term project?
ToyKeeper
ToyKeeper's picture
I got the impression he was planning to make them available for purchase at the beginning of last week. He seemed to be in a hurry for me to get a review up before my trip, so I’m not sure why the D4S isn’t listed at the store yet.
Maybe it’s taking longer than expected to get the O-rings or a new box or something, but I think it should be available for purchase very soon.
ven
ven's picture
Last seen: 1 month 1 week ago
Late to the party, only just read this, thanks for the excellent(as always) review TK. You always go above and beyond in detail, always perfectly written and great pics to boot!!! Big thanks for your time and effort Cool
Love the 26650 form factor, for me personally its the most comfortable in hand size………………..very comfy to hold. Little extra size, more in the tank=win win. I have no doubt i will be adding 1(cough or more) to my little emisar family.
AgentWhiteBread
Last seen: 13 hours 31 min ago
Hey Toykeeper, when he releases the light, which site should we go to, to grab it?
Thank you!
hIKARInoob
hIKARInoob's picture
Last seen: 3 weeks 1 day ago
Thank you!
Here: https://intl-outdoor.com/led-flashlights-c-1.html?zenid=42dd8b87da9743f4...
Or here (USA): http://www.mtnelectronics.com/opencart/index.php?route=product/category&...
