[SALE] lighted tail boards, rainbow or custom color combination
21 posts / 0 new
Lexel
Lexel's picture
Last seen: 1 hour 33 min ago
I am finally starting sales on my lighted tail boards
how it began can be read here
http://budgetlightforum.com/node/59061#comment-1355514
each generation adds more features
Generation 1
simple 2×3 LED with balance resistors optional trimmer
each LED has its own balance resistor so different LEDs can be combined
2 channels can be dimmed with optional trimmer
it is advised to use LEDs with similar forward voltage (CW, WW, blue, ice blue, pink or red, orange, yellow)
if different colors used the LEDs with higher forward voltage dim out with lower battery voltage, this can be used as battery indicator
Generation 2
2×4 or rainbow added voltage stabilisation
2.8V 18uA LDO used to keep brightness stable down to about 3V battery voltage
trimmer optional
Generation 3
2×3 +1 LED added low battery warning and LVP
inner ring lights up with constant brightness
low battery: inner ring gets switched off and one red LED turns on to indicate low battery
LVP: all LEDs are switched off 2.8V LDO and IC standby current of 21uA remain
low battery and LVP can be set to custom voltages
The tail boards run with an 1kOhm resistor as bleeder this works with relative low current drawn from LEDs
Note the more current the LEDs draw the more voltage drops on the bleeder so battery voltage is higher than the calculated values
With standard hysteresis there is a fade between both LED groups and LVP shut down
this is PWM because when the comparator switches the LED off, then the voltage drop on the bleeder is gone,
so it switches on again just to notice that with the voltage drop again it is too low, aso
with battery voltage dropping the PWM cycle gets shorter and fades out
[Sizes]
OD 17, 20, 22mm Omten 1288 (6.5mm hole)
Gen 1-3 available
OD 17, 20 9.5mm switch hole for bigger switches
Gen 2 8 LEDs or Rainbow no trimmers
OD 20mm Convoy L6
Gen 2 Rainbow or 2×4
Gen 2 rainbow
[LED colors] (top are most efficient, bottom inefficient)
LED color and each single LED current based on my “0.5mA” brightness level
green 14.1uA
blue 21.2uA
ice blue 25.2uA
pink 37.7uA
WW 40.2uA
red 50.9uA
CW 66.7uA
orange 124uA
yellow 206uA
emerald green 349uA
my LED brightness scale is based on my Rainbow+WW boards total current while LEDs seem same brightness
basically I have 4 levels “1mA”, “0.75mA”, “0.5mA”, “0.3mA”
this does only reflect on rainbow boards with WW the total current drawn
on 2×3 or 2×4 boards the total current depends on used colors and brightness level (“0.3-1mA”)
for example you order a “0.5mA” pink/green 2×4
18uA LDO + 151uA pink + 57uA green
total current 225uA
now we add 20k trimmers for brightness adjustment
total current at min trimmer level 95uA
It is possible to define a total current consumtion with trimmers on max position
I got a very complex table to calculate the needed resistances
Edited by: Lexel on 08/13/2018 - 08:12
Lexel
Lexel's picture
Prices:
single and 2 colored
1. Generation 2,75€
trimmers optional 0.4€
2. Generation 4,5€
3. Generation 6,5€
20mm 2×3 trimmers optional 0.4€
Rainbow
+1€ per order and + 0.4€ per board
for custom mix of more than 2 colors
1.5€ per order for each different color combination
+ the fees for commercial PayPal which are quite high on small amounts
Shipping:
priority air mail worldwide
1€ bubble wrap envelope
2,7€ optional tracking with 25€ insurance
DHL (Express) worldwide parcel
Hermes EU
on request, but relative expensive
Lexel
Lexel's picture
First prototype of Generation 3 working
all 3 on a 1kOhms bleeder
First a big voltage jump you see
- generation one changes brightness with voltage
- Generation 3 gets in LVP shutting down completely (The switch point needs likely to set a bit lower)
vinte77
Last seen: 2 days 16 hours ago
Nice, does this mean you’re ready to sell a complete tail light switch?
Nichia
Last seen: 3 weeks 5 days ago
Awesome work!
what are the lights this will work with?
will it fit 6p, malkoff, boss...etc?
Nichia 219B
Lexel
Lexel's picture
GEN 1, 2 are ready to build and sell
as usual custom color combinations possible, like rainbow up to 8 different colors
GEN 3 atm only with 6+1 colors,
17+20mm mm one channel no trimmers
on the 20mm with trimmers in 2 different groups
I have made one with 8+1 with cut out boards for easier production 20mm will be mouse bites
but this will take about 10-12 days to get the boards delivered
of course the further the development goes the more it will cost (parts, labor and development time)
Fady
Nice! looking to get my hands on some generation 3 boards.
Fady
Nichia wrote:
Awesome work!
will it fit 6p, malkoff, boss…etc?
Electrically should work with any driver that’s not effected by adding a 1kohm bleeder.
Should fit in 6P and 6P clones tailcaps, can’t install in malkoff MD or boss tailcaps as the switch is inserted from the top.
Lexel
Lexel's picture
Nichia wrote:
Awesome work!
can replace basically all switch assemblies that use a washer on top of the switch to press the switch boot against the tail hole
adjusted the prices as building those took more time than thought
time to assemble those is more than on drivers, trimmer price reduced
JasonWW
JasonWW's picture
Last seen: 2 hours 25 min ago
Lexel wrote:
Nichia wrote:
Awesome work!
Lexel, can you explain how these pcb wire up?
Also, does it effect the driver circuitry in any way?
Click this to go to signature links.
Lexel
Lexel's picture
is wired in parallel to the tail switch
and a 1kOhm bleeder on the driver
not all drivers like bleeder resistors
JasonWW
JasonWW's picture
Okay, that’s what I was thinking.
JasonWW
JasonWW's picture
We are talking about them on the Convoy L6 thread here if you want to see.
Do you know what drivers need the resistor and which don’t?
Do your L6 FET drivers need the bleeder resistor?
Lexel
Lexel's picture
Most 2S drivers LDOs act as bleeder
Victorio
Last seen: 4 weeks 1 day ago
How about a gen 3.1 idea?
3 + 3 (or 4 + 4) LEDs would be placed alternately. 3 blue for “normal operating” light, 3 red for low voltage indication. The red LEDs would be blinking type like this.
So if the battery voltage is low then the signal will be conspicouos.
Lexel
Lexel's picture
if i would find time to update
gen 3.1 is already produced and here
it is 8+3
but atm i can barely spend any time to flashlight most gets eaten up by mails and PMs I am even behind like 2-3 weeks on old orders
Lexel
Lexel's picture
Gen3 20mm with trimmer
2×4+3
inner LEDs in 2 groups star pattern with 2 trimmers, mainly for 2 different colors
outer Low battery fixed brightness
JasonWW
JasonWW's picture
Do you use 10k or 100K trimmers?
I just bought some 100K 3×3×2 to try out on some of my lighted switch mods. It should definitely beat having to constantly swap resistors to find that sweet spot between brightness and current consumption.
Edit, looks like you use 20K. I wasn’t sure if that would be enough.
Lexel
Lexel's picture
I got different values from 2-50k
clientequator
clientequator's picture
Last seen: 1 month 5 days ago
Lexel wrote:
Gen3 20mm with trimmer 2x4+3 inner LEDs in 2 groups star pattern with 2 trimmers, mainly for 2 different colors outer Low battery fixed brightness !{width:70%}http://www.metronixlaser.de/bilder/flashlight/20mm_pot_Gen3_2x4+3.png![/...
Will the R7 - R12 resistor hit the shelf? I look at some common flashlight and the LED may hit the shelf for those. Can it be put somewhere like the back? I guess the back need to have space for the top of the switch though..
Lexel
Lexel's picture
clientequator wrote:
Lexel wrote:
Gen3 20mm with trimmer 2×4+3 inner LEDs in 2 groups star pattern with 2 trimmers, mainly for 2 different colors outer Low battery fixed brightness !{width:70%}http://www.metronixlaser.de/bilder/flashlight/20mm_pot_Gen3_2×4+3.png!
Will the R7 – R12 resistor hit the shelf? I look at some common flashlight and the LED may hit the shelf for those. Can it be put somewhere like the back? I guess the back need to have space for the top of the switch though..
on the flashlights the switch boot will touch them, but thats not a problem as its soft
